oil mix ratios
#51
RE: oil mix ratios
I run a quality synthetic at 40-to-1 and have no issues with my engines. I have friends that run 100-to-1 and claim the engine produces more power. If that is true, just how much more power can reasonably be generated by running that percentage?
I mean, realistically, is a couple of hundred rpm's really worth it? The oil difference is about 1.28 ounces versus about 3 ounces. Oil is cheap when you consider all the other costs associated with our hobby. Why not run the engine with a little more oil? Heck, compared to the 20% I run in my glow engines, this is a minor point.
Just asking for the input from one of the experts like T.O.M. or Jody.
#53
RE: oil mix ratios
To add to the controversy.... I fly at a field shared with an ultralight club. From what Ive seen, none of those guys run less than 50:1 oil. And 'ol fashioned mineral oils like Penzoil seem to be quite popular.
If its good enough when your life can depend on it, its good enough for me.
Penzoil 32:1. Simple. cheap. Goes in everything including the weed wacker and the chainsaw....
#55
LA
RE: oil mix ratios
ORIGINAL: w8ye
The orange bottle is mineral oil like the Pennzoil
The Stihl Dealer near my house only had the Orange last year. Now he has both.
#56
RE: oil mix ratios
I use the local dino oil at 29:1. Its cheap, I am cheap so it suits me great. It must have a good dose of detergent in it. I replaced a muffler on a DL-50 after ~15gal and it was spotless inside except for a 5 o'clock shadow on top of the piston that could be rubbed off with a cotton bud.
At that point, had I been using redline or sthil at 40:1, I would have had to pay an extra $85 for the privilege. Incidentally, $85 is a 1/4 of the new price of the engine.
The engine has since burned another 25gal and shows no sign of quitting anytime soon.
On my DA-100 I save $1 per flight, 1200 flights I save enough to pay for a new motor.
The price you pay may be different so do your own calculatiions
#57
My Feedback: (16)
RE: oil mix ratios
ORIGINAL: Moki 1.8
Should I run a few gallons with the stihl mineral oil and then switch over to the ultra synthetic?
ORIGINAL: w8ye
#58
LA
RE: oil mix ratios
ORIGINAL: w8ye
Sounds good to me
ORIGINAL: Moki 1.8
ORIGINAL: w8ye
#62
NM
RE: oil mix ratios
If I were to switch now from a 100:1 oil ratio to a 40:1 ratio, in which direction could I expect to have to retune my engines ? Leaner, or richer ?
Ed
Ed
#63
RE: oil mix ratios
Leaner normally, but that depends on where it was at before.
Regarding a gain in rpm with less oil. Doesn't happen that way. The best power would be made with a cold engine since that would be the best ring seal. Lean ratio engines have proven to much more tuning tempermental that denser oil engines. Some big money flyers found that out at contests. Changing oils and ratios to more oil from less provided them better tuning consistency and more power. If we had larger engines with more inner surface and fin area we might benefit, or at least make the most of lean oil ratios but that is not the case. Oil is not just about lubrication. It seves several other very important functions as well. Short any one or combination of them and the engine suffers.
For some interesting reading people might want to do a search about service intervals with ultralight engines. Those running lean ratio Amsoil have to service their engines more frequently. However, those that that want to use the stuff should feel free to do so. The bottom line is the engine belongs to them and they can do whatever they want, as it should be.
#64
My Feedback: (41)
RE: oil mix ratios
ORIGINAL: Ed
Ed
Ed
PS: The above assumes it was tuned perfectly to begin with.
#65
NM
RE: oil mix ratios
TOM says leaner .................... Joe AP says richer ????????????? I'm using synthetic Amsoil at 100:1, and going to synthetic Red Line at 40:1.
Which way can I expect to adjust my Carbs guys ?
Ed
Ed
#69
My Feedback: (30)
RE: oil mix ratios
Hi,
If the oil burns as is the case with Pennzoil aircooled, the engine is tuned with needle valves more closed than mixtures which burn only (or mostly) gasoline. From some testing I conducted a few years ago, needles had to be opened when Amsoil 100:1 and non-burning synthetic oils like Belray 1HR were used compared to Pennzoil air cooled.
Hope this helps
Elson
Hope this helps
Elson
#70
NM
RE: oil mix ratios
ORIGINAL: rc bugman
Hi,
Hope this helps
Elson
Hi,
Hope this helps
Elson
Thanks > Ed
#71
My Feedback: (9)
IN
RE: oil mix ratios
ORIGINAL: Tired Old Man
As for why a DA likes more oil with some brands of oil is something I'm not at liberty to discuss. However, they function quite well and for a very long period of time at 40-1. More oil is always better anyway, so it's a moot point.
1st, thank you for all your knowledge that you share with all of us. I follow your forums and thanks to you and Jody I have made fine choice's. Im useing Stihl Ultra 50 to1 in a DA50R. only 2.5 gallons so far. If it was you, would u also go up to 40 to 1 with the Stihl Ultra in my DA?
Also 1 last ques. I did not do any break in, went right with this mix. please let me know if u think i did worng so i do not keep making the same mistake on future engines.
thanks,
ka9fax
#72
RE: oil mix ratios
I use one oil and ratio for break in and runnng. The only difference is how the engine is run. The more oil you ue the longer the break in. However, more oil removes break in wear particulates faster and more completely than less oil. This is one of those personal choice areas, like so many others.
Based on what I've seen I would run a DA on a 40-1 mix. It's not so important with a lightly loaded engine but is with a heavily loaded one. RC does not load an engine heavily, but their are long term benefits of a little more oil. Less piston scuffing being one of them.
#73
RE: oil mix ratios
ORIGINAL: rc bugman
Hi,
Hope this helps
Elson
Hi,
Hope this helps
Elson
#74
My Feedback: (30)
RE: oil mix ratios
Hi,
I think that the needles need to opened more with non burning oils because when oil burns it contributes to the power of the engine. Without the burning oil component, more gasoline is required to achieve the same engine power. In my tests run a few years ago, fuel consumption increased by about 15% with amsoil at 100:1 and Belray 1HR at 50:1. For most RC applications, extra fuel consumption is not a problem. For some of us, the extra 15% fuel load is an issue and we stay with oil which contributes to engine power by burning.
Elson
Elson
#75
My Feedback: (9)
IN
RE: oil mix ratios
