WT 201-1 vs. WT 201B ?
Hi All
Does anyone know what is a difference between a Walbro WT 201B and a WT 201-1 ?
I have a ZDZ 40 which comes normally with a WT 201B and needs a replecement carb..
However in the Walbro HP you can find only that WT 201-1. Are these two types exchangeable ?
Thanks for your answers.
IL
My DA 50 has a nipple pulse port and it is a 201-B. The 201-1 would work for it.
It is never that hard to make something work if you have to.
The DA has the pulse come from the insulator block, out a nipple to the nipple in the carb.
