MT 35 Looks Like a Winner
Reply
Old 11-30-2010, 03:21 AM
  #426
tele1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: MT 35 Looks Like a Winner
I just haven't been flying much.  Kids are keeping me busy.  Otherwise I could give you a report as to how my engine is doing.  I am in the middle of a recovering job and  I am about 80% finished getting my Seagull Extra 260 flight ready.  The MT-35 should haul the Seagull around well.  I plan to fly it in my first IMAC contest next year.
tele1974 is offline
Old 01-30-2011, 04:23 PM
  #427
tele1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The MT-35 Seagull Extra is almost ready.  It is just in need of some servo upgrades.  I have HS645's on it that have become sloppy.  The search for a decent servo that I can afford is a difficult one.
tele1974 is offline
Old 01-30-2011, 04:43 PM
  #428
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Put new gears in your old servos? $17/ea
w8ye is offline
Old 02-15-2011, 08:33 PM
  #429
tele1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Replaced the gears and they are still sloppy.   I guess I am expecting too much from those servos.  I talked to Hitec about it and they told me that they are their lower end servos and I should get better servos.  I have 7955's in another plane.  But,  600 bucks for servos, not happening.
tele1974 is offline
Old 02-16-2011, 12:49 PM
  #430
CurtD
CurtD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: tele1974
Not to hijack the thread but...
Take a look at Hyperion Atlas servos. They're also made in Korea and appear to be very high quality at reasonable prices. I'm running them in my pattern birds with excellent results.
http://www.allerc.com/servos-hyperion-c-40_259.html
CurtD is offline
Old 02-17-2011, 05:37 AM
  #431
kerwin50
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do they even make the MT 35 anymore
kerwin50 is offline
Old 02-17-2011, 06:56 AM
  #432
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: kerwin50
YA! That is good to know before you get too excited !
captinjohn is offline
Old 05-23-2011, 03:05 PM
  #433
grossy2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've been toying with my MT-35 for about 6 months now and can not get it tunned wright......
It starts easy enough and I can set the top rpm no problem, but it's the idle and transition I'm having trouble with.
At idle the rpm tends to hunt. I can not tune it out. Now transition; I keep riching up the L needle untill I get a good tranisition on the ground and goog top end rpm.
I put it in the air and the transition sucks and the max rpm drops on the verticals.
It's ok to fly just normal pocking hoes in the sky, but try to do any 3D work and the enigne is just not responcive enough and I can not get max rpm unless you wind it up and just the dealy in throttle responce is a killer.
I'm using a flexi header and Can on this as well.
Any ideas??????
Cheers
Grossy
grossy2 is offline
Old 05-23-2011, 03:42 PM
  #434
Super08
Super08's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are losing rpm on verticals than the high end it too lean. As for a changing transition in the air you are getting some kind of cowl effect going on that is changing the mixture. This can effect the high as well as the low setting. It sounds like it is more of a set up problem than a tuning problem. You may have to change how it is baffled, add more exit area or even put a vent on the carb.
Super08 is offline
Old 05-29-2011, 10:19 PM
  #435
grossy2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I finaly got this engine sorted. Tryed flying it with out the cowl and tuned it on the go.
Had it running sweet. Just about to try it with the cowl fitted and in she went.
It's either the broken wire on the switch's soilder joint that I found, or the Assan 2.4 V2 Ghz RX went on me. All of a sudden I had nothing.
Here's the carnage.
ID:	1616603   Click image for larger version
grossy2 is offline
Old 05-30-2011, 04:09 AM
  #436
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: grossy2
Here's the carnage.
Sorry to hear about the loss! But from that, a lesson to be learned? I did the same thing (using a different brand radio) teaching me why I should convert my systems to 2 receiver battery packs and 2 switches. Lesson learned here... it was expensive enough to only want to learn one time.
ahicks is online now
Old 07-16-2011, 04:55 PM
  #437
tele1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Strange their is no MT gas engines in the MT gas engines web page. What happened their. I was looking for a flex header for my MT-35. I am going to install a EScomposite pipe on it and hopefully it will pull my EF Extra 300 78".
tele1974 is offline
Old 07-16-2011, 05:12 PM
  #438
PlaneKrazee
PlaneKrazee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It will pull it fine but you'll probably need to braze up a header of stainless parts from DA. Same flange pattern as a Zenoah 26 if memory serves. You'll need the exhaust flange, an elbow and a couple pieces of pipe plus silver braze.
PlaneKrazee is offline
Old 07-16-2011, 07:21 PM
  #439
tomyrcmodels
tomyrcmodels's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
www.mtengines.cn
tomyrcmodels is offline
Old 07-17-2011, 03:00 PM
  #440
aussiesteve
aussiesteve's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the link Tomy.
Is it possible to actually order engines from your site? and can we order parts for our other MTengines through that site too?
I want to get some parts for an MT57 and an MT62 (great engines but suffering from a hard life in my hands).
I see you have an authorised service centre in Florida. Is that still the right address?
aussiesteve is offline
Old 07-17-2011, 04:43 PM
  #441
tomyrcmodels
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
PM send
Old 07-26-2011, 01:41 PM
  #442
tele1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got it running. APC 18x10W at 7950. I need to compare that with the you guys have posted. The header is 11 inches long and the the pipe is 17" to the first baffle. I am not sure if I should shorten or not. I need to learn about pipe tuning. I am going to fly it anyway tommorow. I need to get out and practice for a IMAC contest in two weeks. So far so good. I think.
tele1974 is offline
Old 07-28-2011, 05:17 AM
  #443
tele1974
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got some practice in with my new pipe setup. 3 flight I fractured the head right before the turbo tube coupler to the pipe. Cheap flex header from milehighrc. I have some more work to do to get it mixed right. Problem, pucker factor kicks in when my hand is 3 inches away from a APC 18x10 turning at nearly 8000 rpms. Looks like the thread has been fairly quiet. Must mean that you guys are not having any problems.
tele1974 is offline
Old 07-28-2011, 05:40 PM
  #444
PlaneKrazee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make a stainless header and be done with it.
Reply
Display Modes
