If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 6 of 18 FirstFirst ... 4567816 ... LastLast
Results 126 to 150 of 444
  1. #126
    Join Date
    Jan 2007
    Olmsted Falls, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: MT 35 Looks Like a Winner
    Got my run in prop from Valley View today.  Also, got my EF Extra 300 78"... Absolutely, beautiful bird except for the shipping damage.   Set it up and tried to get the carb wet and it wasn't pulling fuel.  So, I replaced the line. Still no fuel pull.
    I removed the carb  (didn't pay attention the gasket fell off) to find out if I put it on backwards when I inverted the carb.    Replaced it the right way if it was wrong.   It began to definitely move the fuel but it wouldn't  creep up the line unless I totally hand choked it.   Their were no bubbles in the line to tell me if was drawing after that.
    I will hopefully fire it up tomorrow and see if its going draw fuel.
    \"He who makes the least inputs... wins!\"
    Patrick
  2. #127
    Rocketman_'s Avatar
    Join Date
    Oct 2003
    , MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm just curious as to how the MT-35 engine could be shipped directly from MT Engines USA with No user manual, no warranty information, not one word of instruction or answers to questions like,
    1. What type of oil to use?
    2. What break-in gas/oil ratio?
    3. What after break-in gas/oil ratio?
    4. What gasoline octane?
    5. What types of spark plugs can be used?
    6. Propeller size range?
    7. What is that extra wire and connector for in the ignition package?
    8. Was the ignition timing correctly set at the factory?
    9. Is there a manual that can be downloaded from the MT Engines USA website?
    I hope we're not expected to search the web and various forums to find answers while hoping that people are not just guessing at the answers.
    NORTHEAST R/C MODEL CLUB
    http://www.nrcmc.org/
  3. #128
    PlaneKrazee's Avatar
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rocketman,
    At least yours was packaged properly and complete with a new ignition. My ignition has no boot spring and doesn't have the extra tach lead.
    Take the cylinder off and flush the crankcase out with two stroke mix a few times and see what comes out. The swarf and grit covered the bottom of a coffee can in a thin layer, looked like between 80 and 400 grit. Not good running through a new engine Maybe this is why you need to run new engines with extra oil and slowly.
    Does your engine have one less cooling fin on the exhaust side and an unsupported exhaust flange on the bottom?
    Email Tomy or Jack they will answer your questions.
    a never-ending battle for truth, justice and the American way
  4. #129
    Rocketman_'s Avatar
    Join Date
    Oct 2003
    , MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    PlaneKrazee,
    My engine has no cooling fin underneath the exhaust flange.
    Did the second engine that you received contain the gritty contamination that you described above or was it in your first engine? In any case, that amount of grit will be a detriment to longevity and of considerable concern to customers and manufacturer alike.
    I'll bet its not a lapping compund.
  5. #130
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The second engine had more junk in it than the first! I've flushed and oiled both of them. The first engine will still lock up and you can't continue to turn it in the same direction and must reverse rotation and then turn it thru. The intake and exhaust port edges and port interiors are very rough, but that may not matter. With a bit of straight oil in the cylinder the engine has good compression.
    Anyway,
    Hopefully I'll get to run #2 tomorrow.
  6. #131
    Join Date
    Jan 2006
    Freeport, BAHAMAS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you think you can or think you can\'\'\'\'t, you\'\'\'\'re right.
  7. #132
    Moderator SunShyne's Avatar
    Join Date
    Dec 2002
    Centreville, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    crazy stories about QC. I hope Valley View checks them over before shipment. I also do not want to mess with timing and putting it together. All I want to worry about is needle settings and getting it mounted on my airframe
    I am holding out until Valley has them in stock and alerts us before I pull the trigger on one
    Revver Bro #86
    Visit RCU\'\'s E-flight Only Website: www.WattFlyer.com
  8. #133
    Antique's Avatar
    Join Date
    Jul 2002
    Somewhere, DC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Generic two stroke operation manual....
    The extra spring in the plug cap serves no practical purpose, it's a throwaway..
    If you buy a tach it comes with a "Y" connector no extra wire needed....
    ALL two stroke gassers are the same, use a good oil @ 32-1 forever...
    Prop sizes vary with the airplane, 17 to 19 inch diameter, 6 to 8 or 10 pitch...
    87 octane here in the US is just fine for ANY Chinese and most other engines..ZDZ might be the exception...
    What else can there possibly be ????
    RC Ignition
  9. #134
    apalsson's Avatar
    Join Date
    Jun 2003
    Coffs Harbour NSW, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: SunShyne
    As far as I'm aware of, South West RC Engines have the entire MT range.
    They have been the MT dealer for quite a while and if I know them right, they carefully QC check everything they send out
  10. #135
    Moderator w8ye's Avatar
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Attended the CutFinger Institute of DirtNap University for years but never did graduate....
    Recipient, Mangledhand award August 2008
    Club Saito Member #7
    Original AMA #31261
  11. #136
    Super08's Avatar
    Join Date
    Dec 2007
    Fort McMurray, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No Southwest RC, but it looks like all the Mt engines page has been removed.......
    http://swrcengines.com/default.aspx
    Quote: Hey, who put that tree there?
    Stik brotherhood #25
    Ultra Sport brotherhood #125
    Sig brotherhood #73
    Cub brotherhood #226
  12. #137
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I installed a cheapo plastic intake venturi on the 35 using longer bolts. Tomorrow will be the day to run this engine and the DLE30.
    My final concern about this engine is the lack of oil slots or holes at either end of the connecting rod. All other two strokes I've seen have some way of getting oil to the center of the con rod bearings. What do you guys think?
  13. #138
    Join Date
    Jan 2007
    Olmsted Falls, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Post deleted.
    Patrick
  14. #139
    Antique's Avatar
    Join Date
    Jul 2002
    Somewhere, DC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The extra wire is not a battery lead, it's for the tach...Newest ignitions are labeled...Just got 20 yesterday, I KNOW what it's for...
    RC Ignition
  15. #140
    Rocketman_'s Avatar
    Join Date
    Oct 2003
    , MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Antique and tele1974,
    Thanks for your information and opinions.
    I've been using Mobil Racing 2T synthetic at 32:1 in an MVVS 26cc (a company that provides instructions) for break-in and normal running. MVVS is adamant about using synthetic.
    Has the MT-35 been in use long enough to confirm that it can survive hard running on a 50:1 mix? (MT Engines should know)
    Should synthetic or mineral oil be used in the MT-35?
  16. #141
    Super08's Avatar
    Join Date
    Dec 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Antique
    Ralph I was thinking that at first too, but then I thought he may be talking about the loose 6" red pig tail that comes in the Rcexl pkg not the extra lead on the ignition itself. So now I am not sure which he was refering to.
    Sig brotherhood #73
  17. #142
    Rocketman_'s Avatar
    Join Date
    Oct 2003
    , MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was talking about the 8.25 inch red and black lead with a Futaba connector on one end and nothing on the other end.
  18. #143
    Super08's Avatar
    Join Date
    Dec 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes that is a pigtail they supply to solder onto a battery or switch if it has the wrong connector on it. I have a bag full of them now.
    Sig brotherhood #73
  19. #144
    Join Date
    Jan 2007
    Olmsted Falls, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Its not tuned.. but I got it running. And for me that is a minor miracle.
    Yep I should have not said anything...their are others out their with far more experience that should have answered those questions. Taking it down. Was just trying to help.
    Just to show you it will turn a prop.
    [youtube]http://www.youtube.com/watch?v=PGGrKro9VsA[/youtube]
    Its a bear to start... My tach wasn't working very well. 6900 with a 18x10 Xoar
    Patrick
  20. #145
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ran my engine today also. I didn't check the timing, left it the way it was. Started off with a Vess 19A prop, several heat cycles. 7700 rpm peak. Switched to Bolly carbon 18X10, 8100 rpm. Installed a Mejzlik 20X6 and continued to break-in. 20x6 peaked at 8400 rpm after 48 oz of fuel. The 20X6 is less load than the Vess 19A.
    This engine makes more power than a OS160FX. I am impressed. SO regardless of the issues I found I would highly recommend the engine.
    The Muffler is extremely LOUD!
  21. #146
    Join Date
    Apr 2004
    Des Moines, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: PlaneKrazee
    Thanks for the update. Those are good numbers for a first day out! How would you compare the vibration level to the OS?
  22. #147
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Truckracer
    The OS is the smoothest 1.20-1.80 engine I've ever run. At this time I would guess the vibration of the MT35 is more like a Moki 2.10 but it needs more run time to see if it will smooth out a little more. Oh, the rpm of the Bolly was up to 8200 before I switched to the 20x6 and chances are it would spin the 19A a little faster also. The Vess is a high load prop, I was able to lean the carb out quite a bit with the other props.
    I'm going to stick it on a old Ultra Stick to give it some air time after a few more hours on the bench.
  23. #148
    Join Date
    May 2006
    Quincy, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Engine sounds like a winner. I am thinking of getting another Crrc GF40i or getting one of these MT35. How do they compare? Whats theprice for the motor?What will it turn a 18X8 prop?
  24. #149
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    $279.00 shipped from Valley View RC.
    I think a 18x8 is too small, depends on the brand and type. I have a APC 19x8W and a Mejzlik 20x8 I can install later today. We run the 20x8 on Moki 2.10 and get 7600-7800 rpm. It will be interesting to see what this engine can do.
  25. #150
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Checked the timing and found the key way has 5 degrees of play. My engine is timed to 30 degrees or 35 if I don' adjust the prop driver ccw when installing the prop! The play at tdc you were feeling in your video may have been the slop in the propdriver. If you timed the engine to a max of 28 degrees and it's only running at 23 degrees that would equate to much less power.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
