If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 9 of 18 FirstFirst ... 7891011 ... LastLast
Results 201 to 225 of 444
  1. #201
    Join Date
    Dec 2005
    Victoria, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: MT 35 Looks Like a Winner
    you could always make the pipe fit the header by dropping it down just a bit...
    I guess you would have to bend the header back but it would solve your problem..
    If you can\'\'\'\'t dazzle em with brilliance,baffle em with BS
  2. #202
    Rocketman_'s Avatar
    Join Date
    Oct 2003
    , MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: PlaneKrazee
    Take the cylinder off and flush the crankcase out with two stroke mix a few times and see what comes out.
    Does the bottom of the cylinder have a chamfer to allow the piston and piston ring to be re-inserted easier? Is the piston ring free floating or is there an anti-rotation stop?
    NORTHEAST R/C MODEL CLUB
    http://www.nrcmc.org/
  3. #203
    PlaneKrazee's Avatar
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Pinned ring, I think it's chamfered. Only takes a few seconds after you've done it a couple times.
    a never-ending battle for truth, justice and the American way
  4. #204
    Join Date
    Jan 2007
    Olmsted Falls, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I advanced the timing all the way to 35 degrees and the motor runs much smoother and starts much easier. However, it is only spinning the Vess 19A at 6750.
    Whats up?
    I see that it should be in the around 7700. I spent a morning tuning it and 6750 was the best I could get out of it.
    \"He who makes the least inputs... wins!\"
    Patrick
  5. #205
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tele1974
    I advanced the timing all the way to 35 degrees and the motor runs much smoother and starts much easier.* However, it is only spinning the Vess 19A at 6750.*
    Whats up?
    I see that it should be in the around 7700.* I spent a morning tuning it and 6750 was the best I could get out of it.
    That makes no sense. The engine should be labored and wanting to backfire at high rpm with that advance. Send the engine back and have them fix it or give you another.
    Send me a pm with your phone number.
  6. #206
    Join Date
    Jan 2007
    Olmsted Falls, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I told Tomy that I would like to send it for service and he suggested that I advance the timing and try a different plug.
    I sent another email with a request for service.
    Patrick
  7. #207
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Contact Jack at mtenginesusa.com. The rpm figures I got, you and everyone else should get with a couple hundred rpm. Send it back if there is a problem and they can fix it, replace the reeds with fiberglass or whatever. It has a two year warranty, right? The metal reeds do spit fuel out the carb for sure. I installed a velocity stack from the get go so I have no comparison without one.
    It is not up to you to get the engine running properly if there is truely a problem with the engine it's self, it is up to the manufacturer.
  8. #208
    Join Date
    Jan 2007
    Olmsted Falls, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Right on.... I emailed the service department at MTengines.
    Patrick
  9. #209
    Join Date
    Jul 2004
    ButterworthPenang, MALAYSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    6750 - fairly decent #
    7700 - i think we are asking too much
    thx
  10. #210
    Super08's Avatar
    Join Date
    Dec 2007
    Fort McMurray, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Quote: Hey, who put that tree there?
    Stik brotherhood #25
    Ultra Sport brotherhood #125
    Sig brotherhood #73
    Cub brotherhood #226
  11. #211
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Weather: 100% humidity, temp 46 degrees. Stock exhaust. The engine has about 3/4 gallon thru it now.
    APC18X6W 8300
    APC 19x8W 7250
    Bolly Carbon 18x10 8000
    Bolly 16.5x10 3 blade 7700
    Mejzlik 19x8 7400
    Mejzlik 20x6 8000
    Mejzlik 20x8 7000
    Vess 19A 7630
    Based on the rpm of the APC 18x6W this engine is not a revver but a puller.
    I set the timing to 28* BTDC and flushed the engine of crud before running. If you are not getting close to these numbers there is something wrong.
    These figures are all down a couple hundred rpm from a DLE 30 but the 35 weighs a little less and is beam mount.
  12. #212
    Join Date
    Jan 2007
    Olmsted Falls, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Of course the numbers are just that and are going to vary with different wood species...  but a thousand?   I'm done monkeying.
    Its going to Jodi tomorrow.
    I'll let Dr. 2 cycle figure it out now.   Who knows maybe it just has a case of the "crud".   I hear its going around.
    Patrick
  13. #213
    The problem with prop numbers is not everyone uses the same prop, with the execption of the Vess 19A , the props listed above are rarely seen on engines this size. Very few people buying a $280 engine will spend $60+ on a prop.
    Now go outside and play
  14. #214
    Join Date
    Feb 2010
    Taipei, TAIWAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This thread seems being quieta lot.To put something new here..
    The new canister for MT35.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  15. #215
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The APC 19x8 costs about $22.00 but my guess is the Vess will provide the best in-flight performance for sport flying. The Bolly 18X10 three blade I ran would be the best on a warbird. Too bad they are no longer made. One thing is for sure, to break a Bolly you would also destroy the engine.
    Is MT going to replace the reed on new engines with a different material?
  16. #216
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What about a flex header?
  17. #217
    aussiesteve's Avatar
    Join Date
    Oct 2005
    PerthWA, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've always found that a Prop works MUCH better than a flex header when bolted to the front of the engine
    3W, BME and DA all the way. Proven power, Proven reliability and Proven support equals much cheaper in the long term.
  18. #218
    Join Date
    Feb 2010
    Taipei, TAIWAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Flex header for MT35 new canister is similar with the picture but some are improved.
  19. #219
    Rocketman_'s Avatar
    Join Date
    Oct 2003
    , MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Another MT-35 runs.
    Those new Xoar 19 X "3DA" props arrived from Valley View RC in a dented, bent and busted mailing tube but the props were undamaged. The props were obviously strong enough to prevent the U.S. Mail from breaking the tube completely apart.
    Initially the engine was difficult to start because it would not draw fuel but it popped and spun the prop loose after I squirted gas in the carb. After squirting gas in it a couple of times it fired up and continued running. Before I was chased indoors by mosquitoes, thunder and rain I managed to get the max speed up to a "blazing" 4300 rpm and idle speed down to 2400 rpm after many needle valve adjustments and a tank of gas.
    The following day I started all over by resetting both needle valves to 1 1/2 turns open and choked the engine. This time the gas came up in the line and flowed to the engine. Also, the compression was much better than the day before when it seemed to have a leaky piston ring. It surprised me by roaring to life on one flip of the prop.
    With just a few needle adjustments, max speed went to 7000 rpm and idle was 2000 rpm (it idled at 1700 rpm but not reliably). It shakes a good deal more than the MVVS 26cc that it replaced. I'm using regular gas at 32:1 with Mobil Racing 2T synthetic oil.
    I would have taken it to the field to break it in while flying it but the winds were too high, just as they have been for weeks.
ID:	1432514   Click image for larger version.
ID:	1432515   Click image for larger version.
  20. #220
    Do I have to ship them in a safe? SHEESH!
  21. #221
    AJsToyz's Avatar
    Join Date
    Feb 2006
    Maybee, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just armored cars!
    That one looks like it went through the Detroit post office. If it was three weeks late and busted up, it went through Detroit!
    Yes, even if its only supposed to stay west coast, it might make it through Detroit, they have a way!!
    ULTRA SPORT BROTHERHOOD #120
    GOLDBERG TIGER CLUB #10
    CLUB SAITO #590
  22. #222
    Join Date
    Jan 2007
    Olmsted Falls, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mine should be at Valley View by now.  I hope you find something wrong with it Jody.     If not, I hope you find something wrong with the operator .
    Patrick
  23. #223
    It's here Patrick, I'll find something I'm sure, I'll get into it this week.
  24. #224
    Join Date
    Apr 2007
    dickinson, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hello PlaneKrazee, did you get my p.m. ?
  25. #225
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A6TEXAN,
    I did.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
