Carbon/Composite Propeller Manufacturers
Due to a need to initiate some propeller tests pretty soo I need to find out the names, and links if possible, of all the carbon/composite propeller manufacturers. I thought I knew the name of all of them but I don't want to be limited by any memory failures on my part. So if someone makes composite props in either 2 or 3 blade dimensions and you know of them, would you mind sharing?
Pat
Pat
NC
RE: Carbon/Composite Propeller Manufacturers
Mexjlik, Bolly, Fuchs, Beila, 3W, Vess is working on them, Xoar has carbon tipped props. Those are the ones I can think of now.
My Feedback: (8)
WA
Pat,
ZM were some of the best (I don't believe TBM picked up the line when they bought RC Showcase unfortunately, but are closing out remaining stock),
Landing Products/APC has some custom carbon fabric props (entire line is "composite"),
Biela (hollow blades with a wood hub),
PT Models.
You probably should clarify whether "country of origin" is an issue.
Brett
PT Models.
Brett
Skip,
Yes, and thanks. In the sizes I tried they didn't work out all that well.
Brett,
Where to find the ZM is my next question. That's one I never heard of.
Although point of origin ultimately does matter, for the trials I can over look a few things.
Brett,
My Feedback: (8)
WA
ORIGINAL: Tired Old Man
Brett,
Brett,
TBM still has some props. They are made in the Czech Republic and are very good.
http://www.troybuiltmodels.com/categ...ropellers.html
