Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
15cc Gas RCGF engine information thread
Old 12-27-2015, 03:44 PM
  #526
the pope
The recommended running in for gassers is to put it in a plane and fly . If nothing else in the plane with the wings attached . This lets the plane absorb some of the vibration . Hard fixed to a plank of wood is not good .The beam mount 15 is the better of the rcgf 15's . You maybe trying to polish a turd ! Cheers the pope
Old 12-27-2015, 10:44 PM
  #527
I-fly-any-and-all
Originally Posted by sidav
hi guys what would the eqivelent 2 stroke ..
an os 91 is the equivalency of a 15cc gasser, just as a 20cc gasser is equal to 1.20 nitro engine. a 60 or 61 os 10cc's, look at the webra 61 (10ccm) there you have it.
taken from os 91 four stroke info
http://www3.towerhobbies.com/cgi-bin...?&I=LXSY82&P=7
[TABLE="width: 100%"]
[TR]
[TD="bgcolor: #f0f0f0"]SPECIFICATIONS[/TD]
[/TR]
[/TABLE]
Bore: 27.7mm (1.09")
Stroke: 24.8mm (.976")
Displacement:
14.95cc (0.912 cubic inch)
Power Output: 1.6 BHP at 11,000 RPM
Practical RPM Range: 2,000 - 12,000 RPM
Old 12-28-2015, 01:39 AM
  #528
paulinfrance
Thanks for all your advice on the Forum, I have run the engine with the timing between 26° and 30° this morning and it does lose between 200 and 500 rpm, it loses the 500 rpm with the 13 X 6 apc prop and doesn't seem very happy, the best compromise is the 14 X 8 APC at 28°, it does lose 250 rpm but doesn't vibrate too much, so I will go ahead with building my Yuki 1700 cm Zero, and in between run the engine in on 4% oil.
Old 12-28-2015, 06:11 AM
  #529
paulinfrance
I seemed to have it sorted out, the bolt on the end of the crankshaft that takes the prop was 0.40mm out of line (bent), after straightening it out and running it a 1/8 of a turn richer I am getting virtually no vibrations.
Old 12-28-2015, 06:36 AM
  #530
Lifer
Lifer's Avatar
Glad you got it worked out.
What plane is it going into?
Old 12-28-2015, 07:24 AM
  #531
paulinfrance
A Mitsubishi Zero from Yuki models, 1.700 cm span, it looks like the Seagull one but in Grey,,,
http://www.ebay.de/itm/Mitsubishi-A6...-/201415109749
I can't seem to upload the picture !.
Old 12-28-2015, 10:22 AM
  #532
Lifer
Lifer's Avatar
Too bad we can't fly the P-40 and your Zero in formation. In any case, best regards!
Old 12-29-2015, 01:50 AM
  #533
paulinfrance
A friend of mine has a P 40 but we will be flying together with his Kawasaki Hein,,
ID:	2138315   Click image for larger version
Old 12-31-2015, 09:43 AM
  #534
paulinfrance
A few surprises on the Zero build, it is (only just ) held together with 'super crap' , straight onto the charred brown laser cut, consequently, every time you pick it up something cracks or breaks !,
Old 01-07-2016, 10:23 AM
  #535
paulinfrance
Nearly finished, I had read somewhere that the 95mm C of G was wrong, but I can't find the forum build,
I will give it a 'weigh in' tomorrow and try and work out the wing loading, only the radio switch to put in and clean up the wiring,,
Old 01-26-2016, 08:26 AM
  #536
hairy46
Just ordered a RCGF15BM looking forward to mounting it on a sixty size stick
Old 01-26-2016, 08:58 AM
  #537
ahicks
Saw that combo fly yesterday. Pretty sure you're going to enjoy it!
Old 01-26-2016, 09:33 AM
  #538
rhd-RCU
My Feedback: (36)
rhd-RCU's Avatar
Where did you get yours. Every place I looked is out of them.
Old 01-26-2016, 09:34 AM
  #539
hairy46
Yes excited about it. Still fairly new to gas,but have jumped in with both feet.
Old 01-26-2016, 09:45 AM
  #540
hairy46
Valley view hobby is showing one left
  #541
paulinfrance
It will be more fun with the version BM, as it is more powerful, I have run about 3 litres of fuel through mine and I get 8.400+ rpm from the APC 14 X 8 prop, and its really fun and stable to fly, have fun !
Old 01-26-2016, 10:08 AM
  #542
rhd-RCU
My Feedback: (36)
rhd-RCU's Avatar
Old 01-28-2016, 03:15 PM
  #543
the pope
You can get them here in Aus if you wish . Cheers
Old 03-16-2016, 10:05 AM
  #544
paulinfrance
I friend of mine has the P 40 with a RCGB 20cc in his, running an APC 16 X 10 at 7.400 rpm and it leaves my Zero standing,,,
But the 15cc is a nice motor, it has 10 litres of fuel through it now and NO dead sticks,,,
Old 03-21-2016, 05:36 PM
  #545
antic
? What about gasoline engines that run with glow plugs ? Do they run as well as ignition/spark plug engines? Simpler, and lighter. Thanx; JH
Old 03-31-2016, 06:25 AM
  #546
fby002
Other than beam vs radial mount is there any difference between the RCGF 15 and the RCG 15.
Old 03-31-2016, 10:30 AM
  #547
ahicks
Yes! The radial mounted engine is down on power compare to the beam mount. The newer design of the beam mount includes an extra transfer port.
Old 01-24-2018, 08:10 AM
  #548
paulinfrance
Default Crash
Well after 2 years of fun flying my Zero is no more,,, hunting down my friends Russian plane for ages, and
I run out of petrol, and it stopped 1 metre short of the runway, it had started to fall to pieces anyway, two of the crankcase
engine mountings were broken and then only people selling them wanted "Gold" for them, I put on a couple of forums
asking weather the beam mount crankcase fitted it but looking at this thread, it won't,,
so I "sandwiched" between the two halves a 4mm sheet of Dural, and aligned the cylinder ports with the crankcase,
it's going in a Seagull P47 that arrived this morning.
Old 01-24-2018, 08:16 AM
  #549
Lifer
Lifer's Avatar
Sounds interesting! Could you post a picture of your modified engine?
Old 01-24-2018, 08:39 AM
  #550
paulinfrance
I turned down 4mm on the crankcase half and sandwiched a 4mm Dural plate between them, Is this clear enough for you ?
Paul
Name:	RCGF crankcase marking out-2048.jpg
ID:	2252084   Click image for larger version
Name:	plaque adjuster-2048.jpg
ID:	2252085   Click image for larger version
ID:	2252086   Click image for larger version
Name:	rcgf montage fini-2048.jpg
