CM-6 plug gap
My Feedback: (19)
RE: CM-6 plug gap
ORIGINAL: PlaneKrazee
What is the proper gap for a cm-6 plug?
RE: CM-6 plug gap
We found that the electrodes in CM6 plugs wear faster than in other plugs. (increasing gap)
In one engine, after a few years of intensive use, the engine started cutting out unexpectedly. The plug central electrode and mass electrode were worn too much, combined with slight plug fouling down the central ceramic isolator. Changing the plug with a new one gapped to 0.5mm cured that.
I would suggest the standard 0.5mm gap, and inspect the plug at least on a yearly base.
Will post picture of mine if I can find it.
RE: CM-6 plug gap
Here it is,
The engine has about three gallons through. Still slightly rich in it's tune, but running well.
Slightly blurry, but the onset of electrode wear can be seen already.
