HELP!!!! Ignition wirings...
Here I am installing the Mintor 33 engine on the plane... check the photos cause I have come questions and I hope you anwser!!!
1- How I'm supposed to connect all the wiring there? Regarding to the ingition itself I've no doubt... but note that the killing switch has two free wires; one red another black. My guess is I have to plug it in serie; so the red-possitive battery goes to red-possitive from ignition box BUT passing through the switch, Black-mass from battery goes directly to black-mass ingition box. Note I can use the servo alike wire to make connections.
2- Please, can anyone post some photo of a walblro carburator lever setup? WINGBURNER; can you show how you did on your mintor?!?!? How do you command the choke?!?
Thanks to all in advance...
G.
G.
My Feedback: (13)
OR
RE: HELP!!!! Ignition wirings...
you need a different kill switch, the one you have is for an engine with a magneto. You basically need a standard receiver type on off switch to control your ignition
AAARRRRRRRRHGHGHHGJKDLçVHLKDGVLFVGKçHGSVF!!!!!!! !!!!!!!!!!!
OK; thanks!!! Can you advice one in particular?
OK; this is the idea: as TOM suggested, connect battery mass to ignitions mass directly (black wires); use the servo operated switch to pass through the positive... works? Check the image...
Thanks on advance!
BTW; hte fuesl stopper is a Sullivan for gas... so should be OK
Thanks on advance!
