DLE30 loudness?
DLE30 loudness?
Anyone done a decibel test on a dle30 with the stock muffler?? My club has a noise limit and I need to decide whether I need to get a pitts muffler or not.
Zach
Zach
My Feedback: (40)
RE: DLE30 loudness?
I would bet you will probably need a pitts muffler. I haven't played with one myself but in most cases even a good side dump is loud.
Also keep in mind that prop noise has a lot to do with it. A high quality prop (pref CF) will go a long way. Maybe even go up a size to help with noise.
VA
RE: DLE30 loudness?
You need to give more specifics. What distance from the running engine? In most areas it is around 9 meters away in others it is at the end of the taxi area, other clubs different. There is no set AMA suggestions or guidelines. Every time I check the ambient noise level for example in our rural club, it is around 55-65dB. With a Zenoah 23cc gas engine flying at close to max rpm in the air at approximately 60 feet, the dB level was around 73dB. What is your club's max and at what parameters?
RE: DLE30 loudness?
Our club mesures the method from the AMA scale contest rule book. 25 feet in line with the prop and 24 inches from the ground. Also you will need a wind screen.
No way will the stock exhaust (note i did not say muffler) will get you below 90db.
RE: DLE30 loudness?
Some at our club have gone to three bladed CF props to reduce the noise footprint for their large gassers. I can't advise what size for the DLE30 though. Good luck.
RE: DLE30 loudness?
It's going on a wildhare "baby" edge. I have a 19 by 8 wildhare prop so I will try that out first and if the prop is too loud I will go to a Mejzlik (which are beyond sexy looking!)
My Feedback: (90)
RE: DLE30 loudness?
You may consider add something like Syssa 180 engine's tone inserts to cut the noise level even more. http://www.syssaaircraft.com/cart/pc...&idcategory=11
RE: DLE30 loudness?
That engine very well with a mejzlik 18-8 two blade, so it should be fine with a Mejzlik 16-11 three blade.
i have not run that prop, so if anyone has, please post.
RE: DLE30 loudness?
Weight isn't a really big factor but as always I would rather not add extra weight if I didn't have to. I'll see how the wrap around works and then go from there. I'm sure it will be just fine. This plane is getting EXPENSIVE (although you 100 and 150cc guys probably think its chump change)
RE: DLE30 loudness?
Thanks Jody, I probably could have gotten away with the stock muffler but I like the dual outlets of the jtec anyways. It should quiet it down under 90db for sure.
RE: DLE30 loudness?
Zach, here is a video that maybe can help you.
[youtube]http://www.youtube.com/watch?v=PfKK69ACvt4[/youtube]
RE: DLE30 loudness?
Thanks, yea I saw that video, hard to tell much from it other than that it idles lower with the pitts and doesn't quite have the same RPM at WOT. The power loss won't matter since its going on a 10 pounder anyways
My Feedback: (37)
RE: DLE30 loudness?
ORIGINAL: zachfeen
Steve
CA
RE: DLE30 loudness?
A dle30 turning a 19x8 xoar on a stock muffler seems to be a little less noisy than most 60 sized glow engines that I fly with.
My flying style is usually at or less than 1/2 throttle. When I put on an 18x6 for more aggressive 3D flying the engine gets a little noisy, but not what I would consider loud.
