Saito - Pro FG 14 Tips and tricks only!!!
Reply
Old 11-04-2012, 10:18 PM
  #201
Ernie Misner
Ernie Misner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Saito - Pro FG 14 Tips and tricks only!!!
The carb diaphrams might be more sensitive to gas with ethanol in it, and less sensitive to no ethanol if not run dry.
Ernie Misner is offline
Old 11-05-2012, 03:56 AM
  #202
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The diapragm in the carb is clear Mylar
w8ye is offline
Old 11-05-2012, 10:15 PM
  #203
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does that mean not sensitive to ethanol? Thanks Jim.
Old 11-06-2012, 05:24 AM
  #204
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, I don't know about that but Mylar is less sensitive than the rubber stuff.
w8ye is offline
Old 11-26-2012, 08:39 AM
  #205
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Saito FG-14 needs help
My saito FG-14 coughed a few times then died during bench run in, after that it wouldn't start again. Please help. It was into about a couple hours of bench run in, it never quit since the first start, and was breaking in properly according to the manual. The previous tank I started to lean it to reach WOT, from idle to WOT was all fine even though the transition was stumble and not yet smooth, but it never quit. Today during it's first tank of run in, it started easily as usual but seemed lean as I throttled up and down, but after about 7 minutes, it coughed a couple times, then stopped. After that I couldnt get it to start again and the spark plug didn't fire at all. I removed the spark plug to check, but it fired properly. I checked the fuel line, and it looked the fuel did reach the carb. I tried to adjust the hsn and lsn a little bit either way, but the spark plug just wouldn't fire when I applied the starter. My hsn is about 1hr20min, lsn around 5 turns from flush, all unchanged since the previous tank.
What should I do about this problem? any advice will be appreciated.
Correction from FB-14 to FG-14 Made by moderator
Kentli22 is offline
Old 11-26-2012, 09:05 AM
  #206
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.rcgroups.com/forums/image...amebg-user.png); background-attachment: initial; background-origin: initial; background-clip: initial; background-color: initial; height: 55px; background-position: 0px 0px; background-repeat: no-repeat no-repeat; " class="user_postbit_top postbit-name-user">
Registered User
Joined May 2012
It should be Saio FG-14, not FB-14
Kentli22 is offline
Old 11-26-2012, 10:00 AM
  #207
sharps
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kentli22
Check the spark plug boot. Specifically the spring clip that holds it on. Make sure all is snapped in place. This is quite stiff and if not snapped in properly will result in erratic running or non starting. If that doesn't help then check the spark from the ignition system and all the wires. If all checks out you may have a faulty spark plug that won't fire under compression. Hope this helps! The only other thing is fuel.
sharps is offline
Old 11-26-2012, 10:36 AM
  #208
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did remove the spark plug to check for spark, it made spark as correctly when I flip the prop. But after I put the spark plug back it, it just wouldnt fire.
Kentli22 is offline
Old 11-26-2012, 10:37 AM
  #209
ForcesR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kentli22, you have leaned your LS needle too much during break in. Saito'sgas enginesare notorious for acting this way. Open you LS needle by 20 minutes and re-apply the electric starter, it should start. The low and high speed needles are very sensitive to adjustments; they have to be adjusted at very small increments, one minute at a time. When you get to the point where the LS needle does notallow the engine tostumble on throttle up, leave it at that needle setting, do not lean it any further.
Roger
ForcesR is offline
Old 11-26-2012, 10:43 AM
  #210
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The fuel was from the same tank previously. The battery had plenty of juice. It shouldn't be anything to do with the needle settings, right?
Kentli22 is offline
Old 11-26-2012, 10:58 AM
  #211
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ForcesR, ok I will try to open up the lsn to try again. But from the previous few tanks, it started normally at the current needles setting.
Kentli22 is offline
Old 11-26-2012, 11:10 AM
  #212
ForcesR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Kentli22
Kentli22, yes it does; as I stated in my previous post above; you have the LS needle set too lean. Open the LS needle by 20 minutes, re-apply the electric starter and the engine should fire up after 5 or more complete rotations of the prop.
Roger
ForcesR is offline
Old 11-26-2012, 01:20 PM
  #213
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found out there was a weak wiring connection to the CDI, when it touched, it sparked. When not touched, no spark. I hope this will solve the problem after I fix the wiring. Thanks for the help.
Kentli22 is offline
Old 11-26-2012, 01:24 PM
  #214
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will also open up the lsn too after I fix the wiring. thank you for your advise.
Kentli22 is offline
Old 11-26-2012, 09:34 PM
  #215
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You were right. Besides the weak wire connection, it was the spark plug that was bad. It fired occasionally when I had it out to check, but when it was back, it wouldn't fire at all. I replaced it with the used spark plug that I pulled out from my NGH GT9, and it sparked every time I spin the prop. My Saito is now back to normal,just like the way it should be.
Saito's spark plug went back so soon only after a couple hrs of bench break in, is it a quality issue or it was me?
By the way, what does spark plug under compression mean?
Kentli22 is offline
Old 11-26-2012, 10:09 PM
  #216
sharps
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's good news Kentli22. It is possible for a spark plug not to fire or not to fire well when the piston is coming up, both valves are closed, on the compression stroke because of the increase pressure where it might appear OK when not under a compression load outside of the compression chamber. ForcresR is correct about the Saito low speed especially being very sensitive. I never turn mine more than 1/8th at a time. The high speed is also very sensitive but a little more forgiving. Take care.
Put two sets of wheels on so you can land upside down.
sharps is offline
Old 11-27-2012, 05:35 AM
  #217
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the advises above. I have very little experiences in gas engines, it's great that there are experts who could help.
I am having a tuning issue that I need help with. As I'm continue breaking in, I have so far adjusted the needles in a way thatfrom nose forward to nose up vertically, the transition is smooth with RPM incresesbut stable at bothidle and WOT and stable; when the engine is nose forward horizontally, it feel rich from idle to WOT, but is also stable with a lower RPM than when it is nose up. There is no threat of the engine that itmay die at any throttle position.
But the problem happens when I point it nose down and afterward bringing it back to nose up from nose down. When I point it nose down, the RPM decreases some but it continues to run with a feeling that it may die but didn't die, then when I bring the nose up to point towards the sky, the engine will go back to normal RPM but will soon die after a few seconds. I don't know which way to adjust the needles nor what needle to adjust because I am afraid that I will mess up my present needle settings. Please kindly give advise, thanks.
Kentli22 is offline
Old 11-27-2012, 05:58 AM
  #218
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have 4 gas engines, DLE60, OS GT22, NGH GT9 and the Saito FG-14. They are all very good except the NGH that I had already given up during the bench break in process because it is not stable nor reliable. The Saito is so far the most sweet engine with the sound so beautiful that I could just happily listen to it all day long.
Kentli22 is offline
Old 11-27-2012, 06:53 AM
  #219
ForcesR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Kentli22
Kentli22; you need to provide us with more information. When you are pointing the aircraft nose up and the engine stops, is the throttle set at idle or full power? Are you using a tachometer to check the maximum RPM and idle RPM of the engine?
Roger
ForcesR is offline
Old 11-27-2012, 07:10 AM
  #220
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
when i pointed it nose up, I was somewhere around half throttle, not idle nor full throttle. when i mentioned WOT, i simply meant full throttle position. i didnt used
Kentli22 is offline
Old 11-27-2012, 07:12 AM
  #221
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i didnt use techometer, i dont know how to connect to the Saito CDI,
Kentli22 is offline
Old 11-27-2012, 07:22 AM
  #222
ForcesR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kentli22; I believe your HS needle is set a bit toolean. Go to page15 of the manual, under heading "Enjoy your new Engine" read the first paragraph, that paragraphholds a clue to your current problem.Whatdo you havethe engineRPM setat whenyou applyfull throttle?
Roger
ForcesR is offline
Old 11-27-2012, 07:41 AM
  #223
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i dont  know what the full throttle rpm is.i just feel it witb my ears.i will look up the manual . thanks.
Kentli22 is offline
Old 11-27-2012, 07:57 AM
  #224
sharps
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kenti2 ForcesR is correct from my experience. You are too lean on the HS. Try this next time you fly. Open HS one more click. Fly at full throttle and pull an abrupt vertical. Be prepared for a dead stick. If the engine does not quit your good. If the engine stalls a bit or quits open HS one more click and try again. If this does not work or the engine starts to run rough then the low speed is lean.
sharps is offline
Old 11-27-2012, 08:32 AM
  #225
ForcesR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Kentli22
Kentli22; don't take this as criticism, you are making the same mistake many 2 cycle engine owners make when they purchase theirfirst Saito4 cycle gasengine and then try to tune the Saitousing experience from2 cycle engine tuning.
It is very difficult to tune a Saito4 cyclegasengine by ear without the useof a hand held tachometer to set engine RPM. Most people, usually always set the low and high speed needles too lean. Needle adjustments on a Saito 4 cycle gas engine are minute and have to be done slowly;it is very difficult to detect an RPM change on a 4 cycle Saito without the help of a hand held tachometer. A hand held tachometer is your best friend when it comes to tuning a Saito 4 cycle gas engine. Over here, a hand held tachometer cost roughly, $35.00usd.
Roger
ForcesR is offline
Reply
Display Modes
