Help with Walbro Carb ID
How do I find do I find out the Walbro carb model number? I have a RCGF 20cc side carb engine. I've already had a carb replaced once under warranty. Now the replacement has gone bad. Won't draw fuel. I cleaned it and put in new metering diafram and fuel pump membrane. Same problem. Won't draw fuel. Tried a replacement carb off another engine and runs fine so it is carb problem and not something else. These are not real Walbro carbs but Chinese copies. About a 10mm venturi, tube for air pulse line and choke.
