Fuji 64EI lost spark
CO
My Fuji 64 EI lost all spark. I did notice that the spark plug boot may not have been pushed all the way down on the plug.
If there was no connection to the plug, would this be enough to kill the Ignition module? it doesn't seem like it. it was still hooked up just not pushed all the way down.
Battery is a 4.8 volt pack per the manual, and the voltage does not drop one little bit while the ignition is on, watt meter detects 000 current draw when trying to start with EI power on.. I think it's fried.
any suggestions? If I have to replace it again I'll just put a CH module on it this time.
CO
RE: Fuji 64EI lost spark
Yes, I checked all wiring and swapped out the sensor and tried a new spark plug, I cannot get any spark. Not sure why it went bad but I just ordered a CH replacement for it.
