zenoah g20ei popping but no start
My Feedback: (73)
OK
hey fellas this little zenoah is stumping me big time.. I got it in a trade that has gone way the wrong way and I might be stuck with this thing.. I pulled the carb cleaned it really well..it had all kinds of crap in the screen.. set the carb in some fresh mix fuel then bolted it on.. it pulls fuel great but will not start...
yes I am getting spark with plug in and using my man hands to press it on there.... also I am getting spark with no plug at all is this normal ??? my buddies 3w 80xi CS is doing the same thing and will not start either (both stock ignitions) both planes have been belly flopped as well.. I heard this will kill the silicone in the cap and will never fire under pressure???
help me out quick fellas JEDI> T.O.M anyone
also this thing really gives a good pop but no start and it hits really good on the way back around (clockwise)
thank for any help
RACE
thank for any help
RACE
My Feedback: (12)
SC
RE: zenoah g20ei popping but no start
Have you by chance tried using a starter? It sounds like it's flooded..I friend had a problem like that too..Turned out the carb shaft was backwards. He had changed the carb mounting block which turned the carb at a different angle.
My Feedback: (73)
OK
I am going to try again today.. the guy I got this from broke the throttle stop and butterfly can spin all the way around.. and yes I have tried a starter and I get absolutley nothing.. but then I hand prop it I get the POPS
thanks jessie
thanks jessie
Prime the engine through the carb with a shot of fuel. Varify that throttle plate is about 1/8 inch open so the engine will not rev to high...then see what it does. What ignition do you have on it? If it is a flywheel mag...make sure the flywheel has not spun...which will goof up starting & running. Capt,n
TX
Make sure the ignition battery voltage is above 4.8 volts and charged correctly as well. Low voltage will allow the engine to just pop and not run as well. Since a new carb allowed it to run this is not your problem but on subsequent runs if it pops with the new carb it could be low volts.
Glenn
Glenn
