CRRC PRO GF26I
CRRC PRO GF26I
Hi
I have A GF 26I motor that has had about 2 litres of fuel through it, it now has excessive forward and rearward crankshaft movment (1mm plus). When the crankshaft is pushed in and pulled out, it makes a knocking sound, which gives me the impression that the bearing is moving in the housing, does this sound correct and has anyone else had this problem?
Has been running on 25-1 mix, with an APC 17x8 prop, would not have thought that the prop load was too high.
Geoff
RE: CRRC PRO GF26I
I have seen countless Pro 26 engines with this problem and fixed well over 100 of them. It is the bearings that are loose not only in the crankcase housing but on the crankshaft as well. The bearings and housing will most likely need to be replaced and properly this time with a good quality bearing lock compound.
RE: CRRC PRO GF26I
Have removed the cylinder, and the play is due to the crankshaft moving through the bearings. The bearings to crankcase fit seems ok. Plenty of side play tolerance on the big end, so will just run the motor and see what happens.
Geoff
RE: CRRC PRO GF26I
hey conrod , is that the v2 or the first one you have ?. i myself should be getting the crrc pro gf26i v2 from the postman some day. if there are some issues with these i would like to be prepared for them , thanks.
RE: CRRC PRO GF26I
ORIGINAL: Conrod
Geoff
Geoff
