ZDZ 80J Rcexl Install
RE: ZDZ 80J Rcexl Install
Put three flights on yesterday after work. I have no rpm figures to report, the prop seems to ripping more than before to point where I feel I must make a change. I was measuring about 8000 rpm maximum with Epower tach before the change, this may be slightly higher now, but I'll never know since the Rcexl tach does not record the maximum in flight rpm. I think I'm switching to the Menz 26x10 to eliminate some of the prop noise.
I returned the tach for warranty reasons, when it returns, I plan to run a few prop tests.
