If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 134 of 274 FirstFirst ... 3484124132133134135136144184234 ... LastLast
Results 3,326 to 3,350 of 6835
  1. #3326
    RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
    Moving the sensor in the same direction as the propeller rotation retards the timing.
    Now go outside and play
  2. #3327
    Indiomike's Avatar
    Join Date
    Feb 2008
    Indio, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    W8ye and jedijody
    Thank you
    Mike
    Women who have big butts tend to live longer.
    Men who tell them that, don't.
  3. #3328
    Join Date
    Jul 2006
    Maryborough Queensland, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Indiomike
    I have 3 DLE engines from VVRC, a 55, 30, and 20. I have never made any adjustments to the timing from where it was set NIB. With the DLE20 positioned with the spark plug pointing straight down (six o'clock) the Hall sensor is right at the top (twelve o'clock). I am curious as to which way the sensor is moved to advance or retard the spark. Facing the engine does moving the sensor clockwise (to the right) increase or retard the spark.
    Mike
    It will increase(advance the spark)timing if moved to the right/clockwise in your description.
    Club Saito member #695
  4. #3329
    Join Date
    Oct 2002
    Darien, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jody, Continued thanks on providing the best information on these engines!!
    Question. Are the ignition modules fixed timing or do they adjust to the rpm? Then the would see 28, 35, or whatever degrees for low rpms before coming off idle. But if the sensor is off at idle, what would the advance be at higher rpms and could this damage a engine?
    Was wondering if there was a way to hook a timing light up and see if it works off these small ignition modules.
    Thanks, ML
  5. #3330
    Join Date
    Jul 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: ml3456
    Thanks, ML
    I am not Jody but will attempt to answer your questions.
    1)They adjust to rpm.
    2)Whatever you set your timing to static is what will be at max rpm.
    3)Rcexl ignitions retard timing at low rpm of magnet past sensor and increase timing as rpm increases(time between magnet passes sensor decreases)up to what was set static.
    4)You could connect a inductive or direct coupling timing light but you would need to keep the ground circuit intact.As the shield(braid/ground) would prevent an inductive coupling from functioning you would need to connect an adaptor that would allow the emf to be radiated from centre conductor for the inductive pickup or fashion an adaptor to connect inline for the direct coupling type timing light,both methods require ground, that being the plug wire shield be kept continuous or in circuit.
    Picture attached shows basic function of the Rcexl unit,do not take the max timing of 40 degrees shown in the picture as what your timing should be,it is an example of the timing retard function of the ignition module.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  6. #3331
    Join Date
    Feb 2008
    Huntersville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    "Here's the deal with the timing, if you have one of the modules with #4 on it (stock DLE20) the timing is best at ~35*, if you have a standard Rcexl ignition with no numbers on it (says Rcexl on the module, not DLE) set it at 28*-30*. The module for the DLE20 has changed but even the original was set at 35*, personaly I prefer the standard Rcexl ignition at 28*. Either one will make the engine run very well but the #4 module will let the engine idle stupid slow, much slower than necesary.
    Ok so I just got around to looking at my uninstalled DLE 20 today to see which off these I may have and now I am completely confused. On my ignition module is has both RCEXL and DLE on it. I do not see any #4 anywhere on the module and the serial number is 2489. So what do I have? Jody, you say it is either one or the other but mine has both on it. Not that it matters but is there another version now out there?
    Joe
  7. #3332
    Moderator w8ye's Avatar
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    On my DLE 20 ignition unit
    On the back side there is a small RCEXL symbol amongst other insignas
    On the side there is a Serial numberDLE0040058
    On the top, there is a Big DLE insigna
    electronic ignition etc
    model A-01
    www.dlpower.net
    And a light gray big 4#
    Attended the CutFinger Institute of DirtNap University for years but never did graduate....
    Recipient, Mangledhand award August 2008
    Club Saito Member #7
    Original AMA #31261
  8. #3333
    OK, I'll try to make this as simple as possible.
    If it says DLE on the module, the module came with the engine, and the engine runs fine, leave the sensor alone.
    If you replace the module with a standard Rcexl module not from DLE, set the timing at 28* BTDC.
    That's all there is to it.
  9. #3334
    a1pcfixer's Avatar
    Join Date
    Aug 2004
    La Porte, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jedijody
    You sir, have the patience of Job.
    Jim L.
    Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
  10. #3335
    Join Date
    May 2004
    Frostproof, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I would also like to thank Jody, and Valley View, for excellent service. Jody took care of me instantly! GREAT SERVICE!!!!
    Thank you Jody
    Bruce
    aa2dd
  11. #3336
    Join Date
    Feb 2008
    Huntersville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sorry for asking! []
  12. #3337
    Join Date
    Dec 2008
    New Delhi, INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hope this makes it clear once and for all. This is a stock DLE/ Rcexl ignition that comes with the engine.
ID:	1579876   Click image for larger version.
    Cheers....
    Sandy Jain
  13. #3338
    Join Date
    Oct 2005
    Golden, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks just like mine. But I didn't know that these were set at 35 degrees until Jody made that perfectly clear.
    Carl Goldberg Ultimate Brotherhood # 60.
  14. #3339
    Join Date
    Jan 2006
    riverton., WY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jedijody
    Jodi,
    You are correct do not need no instruction book.
    BCCHI
  15. #3340
    Antique's Avatar
    Join Date
    Jul 2002
    Somewhere, DC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Bill, if You are still there give me a call, it's 10 21 pm..Arizona standard no daylite saving time....Question about RC EXL timing board...
    RC Ignition
  16. #3341
    Indiomike's Avatar
    Join Date
    Feb 2008
    Indio, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: a1pcfixer
    ORIGINAL: jedijody
    Maybe Jody should change his user name to "jedijodyjob" or "jedijobjody" Try saying either of those 3 times real fast.[X(]
  17. #3342
    vertical grimmace's Avatar
    Join Date
    Mar 2004
    ft collins , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Is it OK to just take this engine out of the box and run it, without adjusting the timing and messing with all of this other stuff? This all seems to be overthought some. Especially if worried about the warranty.
    Just run it. If it works, continue to run it. If it does not, then get it fixed. Easy enough.
    Let's just say, they will be satisfied with less. " Ming the Merciless
    BUSA Bro # 13
  18. #3343
    SpinnerRow's Avatar
    Join Date
    Oct 2008
    Flower Mound, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: vertical grimmace
    That's what I did with mine. If your RPMs don't fall within what most people are getting for a given prop, then it would be time to investigate more - IMO.
    \"Hey!!! That tree was NOT there when I took off!!\"
  19. #3344
    Amen!
  20. #3345
    Join Date
    Sep 2009
    Bedford, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK Jody, as you suggested I pulled the plug out of the DLE-20 that has about 45 flights on it and put it in the DLE-30 that would not run. It was weird, it would not run, period. I swapped spark plugs from my older DLE-20 and it ran! Then I put in the new plug that would not run in the -30 and it ran fine in the -20! Whatever....
  21. #3346
    a1pcfixer's Avatar
    Join Date
    Aug 2004
    La Porte, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gremlins!
    Jim L.
  22. #3347
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Kamikaze's...
  23. #3348
    Join Date
    Sep 2009
    Bedford, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    BTW, off topic but the DA-60 came alive as well today, and it is OMG, a 24-8@ almost 7K.
  24. #3349
    My MT70 twin does that!
  25. #3350
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got some great flying in this morning in the Bronx with my 70" GP Revolver and DLE20. Think I've finally got the DLE20 dialed in correctly - had to close the low end a tad and open up the high end another tad. Using an APC 16x8, and getting 1,700 rpm idle and 8,700 wot. Very good speed (though hard to be objective in a 15mph headwind...) and unlimited vertical. Did a couple of nice and high inverted "death spirals" today - got some good altitude first - then counted 20 seconds of spinning and falling! And after 20 secs of idle there was no hesitation on acceleration. And with that headwind the inverted hover just HUNG there! The gusts made for some interesting landings - but I like that - it keeps you on your toes. Love this plane and engine!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
