DLE 20cc Gasser! (Data & Links 1st Post)
Old 03-19-2011, 05:09 PM
  #3351
afjetmech
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Quote:
ORIGINAL: microdon2
Got some great flying in this morning in the Bronx with my 70" GP Revolver and DLE20. Think I've finally got the DLE20 dialed in correctly - had to close the low end a tad and open up the high end another tad. Using an APC 16x8, and getting 1,700 rpm idle and 8,700 wot. Very good speed (though hard to be objective in a 15mph headwind...) and unlimited vertical. Did a couple of nice and high inverted "death spirals" today - got some good altitude first - then counted 20 seconds of spinning and falling! And after 20 secs of idle there was no hesitation on acceleration. And with that headwind the inverted hover just HUNG there! The gusts made for some interesting landings - but I like that - it keeps you on your toes. Love this plane and engine!
Do you know approximately where your needles are? Iknow every engine is a little different, but just want some comparison settings to go by.Mine sometimes hangshigh at idle andat other times comes downand then speeds up. I'm really curious as to the low needle setting. I have a cheap 15x8 zinger on mine now but have never tached it. Hope to tomorrow by borrowing someones tach.
afjetmech is offline
Old 03-21-2011, 08:46 AM
  #3352
lmeidl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a strange issue with my DLE20. It runs but with a tiny misfire every 2 to 3 seconds, then after about 2 to 3 minutes it dies completely. I have checked my ignition wires and changed my battery pack to it (from 4.8 to 6volt). Removed my opti-kill, but none of these changes have made a difference. I shortened my fuel lines and verified no bubbles or kinks that I can see. I have tried to adjust the high and low mixtures, but nothing seems to stop these misfires and eventual dying after 2 to 3 minutes. The misfires seem bad at 1/2 speed to full throttle, but it idles smooth with no misfires. Any suggestions? Also, just F.Y.I. This DLE20 is in a 91" Piper Cub that weighs 11.5 lbs and when running, it has TONS of power for the cub (way more than needed actually).
lmeidl is offline
Old 03-21-2011, 09:18 AM
  #3353
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are you still running the DLE spark plug?
w8ye is offline
Old 03-21-2011, 12:42 PM
  #3354
lmeidl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have changed out the spark plug to an NGK. I guess I should have said that, as we all know the DLE plug is junk. Sorry.
lmeidl is offline
Old 03-21-2011, 12:44 PM
  #3355
lmeidl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lmeidl is offline
Old 03-21-2011, 02:33 PM
  #3356
noahb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anybody ran a tuned pipe on this motor? I know there is another thread with a guy building a profile up with an ES pipe, but no data as of yet.
noahb is offline
Old 03-21-2011, 04:23 PM
  #3357
Cherokee Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a question. I just purchased a DLE-20 from my local hobby shop and set it up for break in. Changed plug to CM-6 other than that a standard engine. My issue is this: it starts fine; but the needles have no effect on the engine from clear closed to 4-5 turns open. I can close both needles and it runs the same. Not real good, seems rich.Help!
L.
Cherokee Flyer is offline
Old 03-21-2011, 10:37 PM
  #3358
scooterinvegas
scooterinvegas's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Cherokee Flyer
My issue is this: it starts fine; but the needles have no effect on the engine from clear closed to 4-5 turns open. I can close both needles and it runs the same. Not real good, seems rich. Help!
Thats a new on for me! My DLE-20 tune changes with 1/8 of a turn hi or low. But not to fret, Master Jody will be here shortly to help you, or just to tell you to return it.
scooterinvegas is offline
Old 03-21-2011, 11:38 PM
  #3359
a1pcfixer
a1pcfixer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Might be a bad air leak.
Take it back to your LHS and exchange it.
Let your LHS deal with Hobbico's service dept!
a1pcfixer is offline
Old 03-21-2011, 11:48 PM
  #3360
jedijody
jedijody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
L.
Definitely something wrong on the metering side of the carb, possibley a stuck open inlet needle. Not that hard to fix if you want to try it yourself but, even though you knowas much about carbs as Hobby Services techs,it may ruin any chance of warranty help if it came from Hobbico. If you need help and need it performed under warranty see your selling dealer first. Otherwise you could call me with carburetor and screw driver in hand.
jedijody is offline
Old 03-22-2011, 03:55 AM
  #3361
Cherokee Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jody
Since it was purchased from the LHS and support is one of the reasons I try to support them, I will return it to him. Not fair to take your time for a product you didn't sell. Thanks for the offer!
L.
Old 03-24-2011, 03:56 AM
  #3362
jaless
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi All, This is my first post on this site.
I took my Seagull Yak 54 out to the field last Saturday for it's first flight with the DLE 20cc and I was very impressed. Trimmed down weight for the YAK is around 10 lbs and I was running a 17x8 prop because the LHS didn't have any 17x6's yet.
I had only about 1 tank of gas through the engine when I got to the filed and had not done much with tuning except to get it rich for the first tank.
Spent about 20 minutes tuning for max RPM minus 1/4 turn and then setting the idle so it would respond to WOT without much hesitation. Max RPM I could get right now was around 7200 and idle is around 2500/2800.
Right from the first flight I knew I was going to like this engine. I spent the end of last summer getting into gas with a RCG 26 from HobbyKing on my H9 1/4 scale cub and had nothing but problems. Could not keep the engine running and most of my landings were dead stick.
The DLE 20cc is a whole different experience. This little engine can really pull. I was doing vertical out of sight and this little guy never quite.
Three flights and no problems. I am really hooked on gas.
I hope to have my Xoar 17x6 for the next flight.
I do have one question. I notice that there is very little compression on this engine. I can flip the prop without much resistance. Will this improve or is the nature of this beast?
I also notice the step at idle which is a bit weird. Seems to idle down just fine till it hits a point then it kicks it up a notch. No problems with this in flight but when it happens pulling out from the flight line it has a whole new gear and I have to throttle it back a bit.
All in all a great first day with my DLE and glad I made the switch.
Thanks for a great forum and so much useful information.
Joe From Howell
jaless is offline
Old 03-24-2011, 09:24 AM
  #3363
g_mkoch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello
Does anyone know the sound level at full throttle?
g_mkoch is offline
Old 03-24-2011, 10:05 AM
  #3364
skyriter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would not back off the top end a full 1/4 turn from Max RPM...back it off only enough to drop the RPM about 200 RPM. These carbs do not need very much adjustment to change the fuel mixture quite a bit. 7200 RPM seems quite low.. Should be up around 8000. 1/4 turn may carbon up the plug pretty quickly.
Bruce
skyriter is offline
Old 03-24-2011, 10:11 AM
  #3365
jaless
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: skyriter
Bruce
Gotcha! Thanks Bruce. I will try that.
The stock muffler is pretty loud. I didn't meter it but I have sent for a Pitts wrap around muffler from Jtec.
Does anyone know how much quieter the pitts muffler is?
Joe
jaless is offline
Old 03-24-2011, 11:16 AM
  #3366
vinmech
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Pitts wrap around has a different tone to it, but it is not much quieter in my opinion to the stocker.
vinmech is offline
Old 03-24-2011, 05:55 PM
  #3367
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got a question for you pros on this thread. I have a Red max Zenoah engine & was going to install the magnet & sensor on a disk on rear of engine. But I got to thinking with fixed ignition...that could be done RIGHT? But with a auto advance ignition...will the advance be in the correct direction? Thanks Capt,n
captinjohn is offline
Old 03-24-2011, 06:21 PM
  #3368
Craig 01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes and yes.just time for 28 degrees before TDC.The electronic auto advance ignition unit and sensor does not know which direction the engine spins its magnet past the sensor so will work with anti clockwise and clockwise crank rotation.A mechanical advance fixed timing electronic system with sensor advance set off throttle would need reversing with reversed crank rotation .
In your case,crank rotation stays the same.
Craig 01 is offline
Old 03-24-2011, 09:08 PM
  #3369
jedijody
jedijody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've re-timed engines for counter clockwise rotation several times, the sensor and module cannot tell the difference, flip the prop over  and you have a pusher.
jedijody is offline
Old 03-27-2011, 10:01 AM
  #3370
sandyjain
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jody, I need some help.
I had a bad crash of my extra 260 with the DLE20 today. :-(
I might need a new ignition.
Is there a spare DLE 20 ignition #4 available ? If not, can I use a standard Rcexl ignition ? What will be the the setting for the sensor ?
I hav some one coming to India from the US - DC area. Would like it shipped to him.
Regards
sandyjain is offline
Old 03-27-2011, 10:33 AM
  #3371
jedijody
jedijody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We have both modules in stock. I've very plainly explained the differences in them, my personal preferences, and what each of them should be timed at very recently in this forum. You need to decide for yourself which one you want.
jedijody is offline
Old 03-27-2011, 11:15 AM
  #3372
spaceworm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Would you please tell us the post number you refer to for your preference and timing issues? Thank you.
Sincerely, Richard/Club SAITO #635
spaceworm is offline
Old 03-27-2011, 12:12 PM
  #3373
jedijody
jedijody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Though I do have a preference, I have no timing issues.
http://www.rcuniverse.com/forum/fb.asp?m=10402619
jedijody is offline
Old 03-27-2011, 12:20 PM
  #3374
crashland 73
crashland 73's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My dle20 has the #4 module & my dle30 has the #3, whats the diff?
crashland 73 is offline
Old 03-27-2011, 12:22 PM
  #3375
jedijody
jedijody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
1.0
jedijody is offline
Display Modes
