If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 136 of 274 FirstFirst ... 3686126134135136137138146186236 ... LastLast
Results 3,376 to 3,400 of 6835
  1. #3376
    a1pcfixer's Avatar
    Join Date
    Aug 2004
    La Porte, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
    ORIGINAL: jedijody
    1.0
    LOL!!!
    I almost spit my drink all over my keyboard.
    Jim L.
    Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
  2. #3377
    crashland 73's Avatar
    Join Date
    Sep 2002
    Oak Grove (in the Ozarks), AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Goobers!! Lol!
    If you are born once, you die twice.
    If you are born twice, you only die once.
  3. #3378
    Join Date
    Jan 2002
    Hesperia Michigan, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No reply...but here is the post about thetiming of Rcexl ignitions.
    Here's the deal with the timing, if you have one of the modules with #4 on it (stock DLE20) the timing is best at ~35*, if you have a standard Rcexl ignition with no numbers on it (says Rcexl on the module, not DLE) set it at 28*-30*. The module for the DLE20 has changed but even the original was set at 35*, personaly I prefer the standard Rcexl ignition at 28*. Either one will make the engine run very well but the #4 module will let the engine idle stupid slow, much slower than necesary.
    There ya go..............
    I never met a engine I did not like !
    6/8/2015 http://www.lambertsrc.com/
    http://pure-gas.org/about
  4. #3379
    Join Date
    Dec 2008
    New Delhi, INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanx jody and Capt., can I use my DLE55 ignition with the sensor set at 28* before TDC ? This is just to check if the engine is OK otherwise ?
    Cheers....
    Sandy Jain
  5. #3380
    Yes, the DLE55 ignition is the standard Rcexl igniton, time it at 28* BTDC.
    Now go outside and play
  6. #3381
    Join Date
    Dec 2008
    New Delhi, INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jedijody
    Thanx Jody that was quick.... :-)
    Cheers....
    Sandy Jain
  7. #3382
    Join Date
    Apr 2010
    Cape Town, SOUTH AFRICA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    JediJody,
    The DLE website says that the CDI can b run off a 6.6V LiFe Battery pack with a regulator, but the manual only refers to 6.0V operating voltage.
     I assume the website is upto date but will my DLE 4# CDI unit handle the 6.6V LiFe battery pack?
  8. #3383
    No. Put a UBEC or diode between the pack and the ignition so as not to exceed 6.0 volts.
    If it ain\'\'\'\'t yours; don\'\'\'\'t touch it!
    Club Saito member #726
  9. #3384
    dwreel's Avatar
    Join Date
    Dec 2003
    southern pines, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What value would be correct for the diode ?
    dwreel
    AMA 70251
    Ultra Sport Brotherhood #146.
  10. #3385
    a1pcfixer's Avatar
    Join Date
    Aug 2004
    La Porte, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Go to the top of this page and click on "Search This Thread",
    then enter diode
    You'll easily find numerous postings on this.
    Jim L.
  11. #3386
    a1pcfixer's Avatar
    Join Date
    Aug 2004
    La Porte, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: TimBle
    ...........The DLE website says that the CDI can b run off a 6.6V LiFe Battery pack with a regulator, but the manual only refers to 6.0V operating voltage.
    *I assume the website is upto date but will my DLE 4# CDI unit handle the 6.6V LiFe battery pack?
    THAT web site is by Hobbico/Tower Hobbies, and NOT the official DLEngines web site.
    It states "LiPo requires a regulator", not LiFe.
    Now go back to this thread's first msg, and my recap of info here.
    Click on the link "Ignition draw + Voltage issues......"
    Then see my reply to dwreel
    Jim L.
  12. #3387
    SpinnerRow's Avatar
    Join Date
    Oct 2008
    Flower Mound, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: dwreel
    I'm using a 1N4007
    \"Hey!!! That tree was NOT there when I took off!!\"
  13. #3388
    ORIGINAL: TimBle
    JediJody,
    Please pardon the copy and paste but I'm tired of typing it all out, this question is asked almost every other page. With a little effort searching for answers one can almost always learn something else, maybe even the next thing they're going ask.
    The DLE factory manual doesn't state any battery or voltage, the Hobbico manual says a 4.8 or 6.0 volt battery, the Rcexl instructions say 4.8-6.0 volts, it even states to use a diode or regulator if using 2 cell LiFe or A123 packs to drop voltage to below 6 volts. The very latest from Rcexl says that 7.0 volts is the maximum their ignition can handle but a single cylinder ignition is then drawing a full 1 amp from the battery when it can easily do its job on less than 1/2 that current. That means the excess is dissipated within the ignition as heat, not good for electronic devices.
    That said, I work on these engines everyday, the failure rate for the ignitions run on straight 2 cell Life batteries is more than 5 times that of those run at below 6.000 volts. Those that survive the warranty period still die a very premature death and cost about $80 to replace. Personally I don't care if you want to use a car battery for your ignition and I have no problem replacing them under warranty if they fail, they give me new ones free, no questions asked. BUT, Rcexl, Hobbico, DLE, and certainly not myself will replace your airframe or replace your flying time or relieve any of the hassle having a bad ignition day will cause.
    I've recommended countless times what's the safest, most reliable, provides the longest battery life, and the longest duty cycle for your ignition. Exceeding 6.000 volts only has draw backs, zero advantages, no performance advantages whatsoever.
    Again, the diode is a 1N4007, 3 cents each, http://www.alliedelec.com/search/pro...px?SKU=2660007
    Attached Files Attached Files
  14. #3389
    Join Date
    Dec 2008
    New Delhi, INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The diode required to drop the voltage from a 6.6V LiFe is 1N4001 - it drops the V by 0.9V and so the output becomes 5.7V ideal for the CDI.
    What I have done is to solder 2 male futaba connectors to a LiFe 6.6V. 1 goes directly to the Rx thru a switch and the other has a 1N4001 in series and goes to the CDI thru another switch.
    hope this helps....
    Cheers....
    Sandy Jain
  15. #3390
    Rcexl recommends the 1N4007 diode, not the 1N4001.
  16. #3391
    Join Date
    Dec 2008
    New Delhi, INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    why? they have the same characteristics only the operating/ reverse voltages are different. for our low voltage use even 1N4001 is enough. Please correct me if I am wrong.
    Cheers....
    Sandy Jain
  17. #3392
    You will need to ask Rcexl that one, but their instructions are clear which one they recommend.
  18. #3393
    Join Date
    Feb 2008
    Huntersville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is a related question and I don't mean to Pi$$ anyone off here but I am going to run a 5cell NiCd pack and we all know that at full charge they go over the 6V range so do I also need to protect the circuit with a regulator or a diode to prevent over voltage until it actually comes down to normal operating voltage?
  19. #3394
    Moderator w8ye's Avatar
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes
    Attended the CutFinger Institute of DirtNap University for years but never did graduate....
    Recipient, Mangledhand award August 2008
    Club Saito Member #7
    Original AMA #31261
  20. #3395
    Come on people, READ. I just posted this a couple of hours ago.This is notdifficult to understand.
    Again, the diode is a 1N4007, 3 cents each, http://www.alliedelec.com/search/productdetail.aspx?SKU=2660007
  21. #3396
    a1pcfixer's Avatar
    Join Date
    Aug 2004
    La Porte, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Reading is fundamental,
    comprehension is an acquired skill.
    A basic 4-cell NiMh gets it done!
    Jim L.
  22. #3397
    Join Date
    Aug 2008
    Waterford, Mi/Citrus Springs, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: a1pcfixer
    And a 5 cell needs a diode to get it done....
  23. #3398
    Join Date
    Feb 2011
    Upland, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    so a 12v car battery would work??
  24. #3399
    Join Date
    Feb 2006
    Norwalk, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Why not use 2 of them and hook them together and use a bunch of diodes to bring it down.
  25. #3400
    Join Date
    Jan 2006
    Freeport, BAHAMAS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    [/quote]
    Come on people, READ. I just posted this a couple of hours ago. This is not difficult to understand.
    LOL, looks like a ruff day at the office Jody
    If you think you can or think you can\'\'\'\'t, you\'\'\'\'re right.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
