DLE 20cc Gasser! (Data & Links 1st Post)
#3726
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
ORIGINAL: microdon2
Side carb. Just checked my still-in-box DLE 30 - its' rear mounted. Do you think this is more of an issue with side-carbs?
#3728
IL
ORIGINAL: microdon2
This thread has lasted a long time as NEW DLE 20cc Gasser! (Data & Links 1st Post).
So pic's in another thread might get you some help. Not here from me.
#3729
ORIGINAL: regets ama
keep going, that hole you are digging is just getting deeper.
the problem isnt the part(s), it is the assembly issue. i hope you took the issue to the correct group.
everything i have seen of DLE presented products has been better than average quality. i have steered many hobbyist to buy dle 30s and 55s,,,,,,,,,,now we know it is important to double check the finished product.
The carburetor is not manufactured by DLE, it is produced by a large producer of OEM carburetors and many other parts or components. As I said, the issue was brought to their attention, they acknowledged it, took corrective action and implemented QC checks that should prevent it from reoccurring. This seems to me to be fairly easy to understand. Why would you not double check any component used on an 8 pound missile with a 17" spinning meat cleaver on the front of it?
#3730
MI
Jody I was not getting the hole thing !!! either ????
O well mine is purring like a kitten thanks to you !!!
it is a hit and miss thing on the carb's 1 of mine was ok 1 was not !!! probley a Friday thing !!! O well
that is what makes this hobby FUN started doing this when I was 11 - 60 now still learning first gasser !!!
A1pcfixer seams to have it togather also the tank thing was great !!! and outher things not just the tank !! KEEP up the good work boath of you !!!
I will head south some time this summer and meet him ( only 2.5 hr. away ) need to ck with him on some fun fly at his club
Hope the weather gets with the program this weekend TIME TO FLY U 2 Captin John lets do it !!! R/L
#3731
SC
"Why would you not double check any component used on an 8 pound missile with a 17" spinning meat cleaver on the front of it?"
My SENTIMENTS exactly!!!!!! Seems that "GRABBIT and FLYIT" takes more precidence than safety.
#3732
AZ
Who checks for loose screws inside the carb or taken apart every servo and receiver? Am I the only one who just installs engines and radio equipment without disassembling and inspecting that all screws have loctite or the integrity of the solder connections? That is why the manufacturers have QC departments.
#3733
IN
ORIGINAL: DwightMann
i've just never encountered such an issue with any OS or Thunder power engine.
i wonder why thier QC didnt catch mine, it is only 4 months old
so lesson learned, always dismantle your DLE engine to make sure the assembly was correct,,,,,,,,,
#3734
If you purchase from a reputable dealer like Jody at Valley View then all that sort of work is already done for you
Karol
Karol
#3735
My Feedback: (8)
All this over a loose screw that told off on itself. Just makes me want to look at an engine that I have still not found out why I seem to be the only one having trouble with.
#3736
NC
ORIGINAL: karolh
Karol
Karol
#3737
We were talking about a single screw that was intermitantly being sent to DLE as part of an assembly without being torqued properly. I truthfully and acuratelystated the issue has been addressed and the problem rectified.
Does the engine warranty cover your airframe, radio gear, and provide for liability coverage, no. Does the guidence system manufacturer's warranty extend to the airframe and engine, no. Does the airframe manufacturer have an umbrella warranty covering the engine and radio gear, not.
We do unpack, inspect, and check for loose screws,nuts, and bolts etc.. We don't completely disassemble the engines as rulebut when a preventablereoccurring problem surfaces we do look for those issues and disassemble an engine as far as necessary to do so and correct it if present.
When I build a plane, I do not assume anything, anything I take for granted is my responsibility. I DO disassemble an engine before it goes on my or anyone I'm building for's airframe. The carburetor is the first thing I disassemble and inspect.
I never said the problem was anyone but the factory's responsibility to correct, it had been discussed in this forum multiple times. Once discovered, no engine left our store without it being check for and corrected if necessary.
#3738
ORIGINAL: microdon2
captinjohn - in post 659 you said you may sell your DLE 30. Any problems with it, or is it that - size-wise - it doesn't fit your current planes? I'm about to install a new DLE 30 in a CG Sukhoi...
River Larry, after I stopped and tralked the darn wind came up here and very gusty. We will get together soon and fly I hope. Best Regards Capt,n
#3739
exactly, guess we now have to completely disassemble the engine and carb, make sure the piston was secured with circlips, screws and bolts are tight, needle inlet valve is secured and set at proper height, pump diaphram has no holes, maybe magnaflux, etc,,,,,,,,
#3740
Many years ago when I learned to fly full scale aircraft I was taught to do a preflight check of the aircraft. You inspect everything (within reason) by sight and do a little pulling and tugging on some things. To dismantle various parts of the aircraft to check on integrity is neither practical or necessary. I always check my model engines over (gas or glow) before installing them into the plane but that does not mean dismantling them to make sure they were assembled right. I think that is taking things way too far. But if you feel you must, have at it.
I have three DLE engines from VVRC with no issues. I fully appreciate the time and effort Jody gives his customers in answering questions and to take the time to inspect the engines before shipping. Does Tower or TBM do that? If you have read the various threads on the DLE20, 30, and 55, you would realize the effort Jody puts into his profession. He is very knowledgeable and he has my full respect. He is the reason I buy my DLE's from VVRC.
Indiomike (George Burge)
#3741
MI
Well I am with you on that INDIOMIKE I was a bad boy and did not get my dle 20 from Jody and V V R C !!!
( WELL THAT WONT HAPPEN AGAN ) !! I called the man on the phone and told him where I got them from and he still help me out !!!
that is custermer service !!! we had a great talk !!! and boath agread YOU CANT FIX STUPED !!!
And this carb thing got way out of hand !!! so a screws was loose big deal !!!!
with any thing ther should be some type of pre flight done !!! not just airplans
WHAT EVER HAPPEN TO COMMON SENCE !!!! next time , now that summer is hear I think if you see a car over heated on the side of the road
WHO IS THAT PERSON GOING TO BLAME !!!! Common Sence I wish you would come back we sure miss you !!!
Jody and outhers have done a great job getting us up to speed on the DLE 20 ( too many names to post ) but you know who you are !!!!
for that we thank you ( or at least ME ) well my $0.02 !!! for what it is worth the outher post that were did not help me out at all
All it did was confurm
YOU CANT FIX STUPED !!!! and Common Sence is Gone !!!!
R/L
R/L
#3744
My Feedback: (47)
NY
Speaking of stupid, my DLE 20 would not idle-down this morning, even with the throttle all the way down. I suspected a "traveling" or misaligned throttle plate. So I took the engine and carb off - right there in the middle of the field - good thing I bring all tools. Sure enough, the throttle plate was misaligned, leaving a gap at closed-throttle. But the screw seemed tight. So I'm guessing I didn't line it up correctly when I last worked on it. MY BAD. OR maybe the plate DID move. Well, it's on correctly now and the screw is tightened properly, and the engine is also running perfectly. Nice, low idle. I'll monitor it to see if that plate moves again.
Seems to me this issue would not happen if the screw hole were just large enough to fit the screw, with no play.
#3746
SC
ORIGINAL: a1pcfixer
That only applied to Stupid ver 3.0[&o]
Rumor has it that Stupid ver 8.7 is available[sm=bananahead.gif]
Stupid IS...no matter what version.
#3748
QC, CANADA
Hi guys,
I took mine apart for inspection after 2 galons. I saw there are still small areas of the cylinder (above the exhaust port) where the ring has not seated yet. I am using mineral oil. Should the ring seat completely after say 3 gallons. Compression seems goo though and performance as well.
The other thing is that I saw some fuel that is leakin very slightly from the choke plate pivot. Is this normal? There was also some fuel on the front face of the carb
I had some carbon buildup on top of the piston but that should just increase the compression right?
