DLE 20cc Gasser! (Data & Links 1st Post)
#4901
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
ORIGINAL: oldtyme
This is where I got mine: http://www.quickieparts.com/spark-pl...w-engines.html
ORIGINAL: acdii
Wish the DLE20 fit my T-34, well it could, but weighs almost as much as the plane itself. I still haven't decided what engine to put on the T-34 to covert it from electric. I know I want 4 stroke.
BTW where can I get the plug for the DLE20? I didn't see it listed on Tower where I got it. Napa parts guy just gave me a weird look.
#4903
Hate to say it, but the links for the ignition draw and consumption are dead. I am looking for the amp draw so I can get a BEC to use with the DLE20 ignition and my 7 servo Futaba RX running off a 3300 MAH 3S Lipo. I don't want to get one that is too low an amperage.
#4904
My Feedback: (7)
IN
ORIGINAL: acdii
Hate to say it, but the links for the ignition draw and consumption are dead.........
Try right-click and open in new tab maybe?
#4905
#4906
Well now it directs me to one of the thread pages, and the attachment gives me the error now,
Thanks, just what I was looking for.
Followed the rest of that page that the link pointed to now and found what I needed to know. The input voltage doesnt matter for the output, and in fact the higher the input the more draw(seems strange, quite the opposite in fact), so I will use a regular 4.8v pack, maybe 1000mah in size, should get me 4 flights before needing a recharge, and get a LiFe for the RX instead of using a BEC with one of my 11.4v LiPo's for both. Good information in this thread when you can find it.
The page cannot be foundThe page you are looking for might have been removed, had its name changed, or is temporarily unavailable.<hr />Please try the following:
HTTP Error 404 - File or directory not found. <hr /> |
ORIGINAL: w8yeJust for the record . . .
Original: a1pcfixerFrom the Rcexl chart Jody just posted;Currentconsumption{min @ 4.0v}35mA(0-rpm)300mA(8000 rpm){typical @ 4.8v}45mA(0-rpm)430mA(8000 rpm){max @ 6.0v}60mA(0-rpm)580mA(8000 rpm)
#4908
I've been having posting issues for the past 2 weeks, sometimes they go right through, other times, I get errors and have to refresh and start over.
#4911
CA
So I've ran about 1.5gal through my engine and it's starting to 4stroke @ ~1/3 throttle. I know as it breaks in it will need retuning I'm just wondering if it's normal to need to be leaned out as it breaks in?
#4912
ORIGINAL: nefariousrc
#4913
CA
ORIGINAL: ahicks
Yes, it's normal for the carb to need adjusting. I'm not sure I would lay the blame completely on break in though. A 30 degree air temp swing could cause it as well as a number of other factors? Go for it!
As for temp, I'm in San Diego... We don't get 30* temp swings Kidding aside, there was maybe a 10* temp difference between when I first tuned it and this weekend.
#4914
My Feedback: (38)
Quick question.....
Manual states a gas mix of 30:1
I have several Zenoah that I run with 32:1
Can I use the same mix 32:1 to my DLE 20 or I need to have a separate can with 30:1? Would it hurt it too bad to have a little bit extra oil?
Thanks for the help
Fabio
Thanks for the help
Fabio
#4916
My Feedback: (10)
Hello y'all,
Since I'm one of the own of DLE20 and I would be experiencing my engine may be the end of January 2012, or February. There is another thread of Chinese gas engines, and it looks like we are under an influx of Chinese engines, which is good in a way that price may get plummeted but so far, it's seems like a shot in the dark.
http://www.rcuniverse.com/forum/m_10...m.htm#10486267
DLE20's been spoken a lot about and spoken high. I would like to ask a simple question of those who had been, or had used the DLE 20 engines in the past. The question is
What is a life span of DLE20 or bigger size gasser, how long do they last if not abused, and what are the precautions to be taken in order to keep it running good.
I know nothing can be predicted precisely when it comes to any electronics or mechanical stuff, but experiences make us learn the ropes.
Thanks y'all, happy flying and happy holidays
Mody
Mody
#4917
NH
I have over 250 flights on the DLE-20/Velox and had about 50 on the other DLE-20 I had before I sold it. It is still running great, no issues.
#4919
My Feedback: (17)
FL
ORIGINAL: armody
Wow 250 flights, that's really amazing and very encouraging. What are the general precautions to you take to keep it running well?
Here is what I'm doing to keep my DLE-20 happy (which means I'm happy since I own two)
Correct fuel to Oil ratio with a high quality synthetic oil
Correct mixture: (Not too lean - Not too rich:either will cause problems)
Don't over-rev nor over-prop
(Don't crash)
Plenty of information on each of these on this thread.
Good engine.
Paul
#4920
NH
I run VP fuels 100% gas with Stihl HP Ultra synthetic, and a 17-6 or 17-8 Vess prop so it is not reving too high. Also, I have plenty of cooling air, and even in a hover never gets too hot.
#4921
My Feedback: (10)
Paul, hoffman,
Great information. I bought me a wooden prop 16X6, and I might get 17X6 as well, don't want much speed but thrust. One thing I would like to clear it up, for the fuel, I bought Klotz 32:1 synthetic oil
http://www3.towerhobbies.com/cgi-bin...&I=LXS626&P=ML
and I have to buy the Hi Octane Supreme gasoline, that's it or something else?
Mody
Mody
#4922
ORIGINAL: ghoffman
Doug
#4923
NH
I buy it in a 5 gallon bucket for about $70, and the local shop gives me the Stihl HP Ultra with it. With the DLE-20 that is alot of flying time, but I also use it in a DA-60 and a DA-120 as well. The DA-120 uses about 20-25 oz per 10 minute flight, but the DLE-20 uses the 16 oz tank in maybe 30 minutes.
#4924
My Feedback: (17)
FL
I'm using no-ethanol Rec fuel now but I started with 87 Octane pump gas and it worked just fine. Other than the possibility of some fuel line being more reactive to the ethanol than others, I believe that the uber-experts support the use of plain, out of the pump non-premium gas.
Everything else being equal, I don't believe that the gasoline will have any substantial effect on the longevity the engine.
Some have found a brand or type of fuel that works better for them. I use ethanol-free because I can get it and I'm not sold on the whole ethanol thing in the first place and it works fine for me.
#4925
ORIGINAL: SkidMan
