DLE 20cc Gasser! (Data & Links 1st Post)
Old 12-22-2011, 02:11 PM
  #4951
SpinnerRow
SpinnerRow's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Quote:
ORIGINAL: kiwibob72
Looking at the link, I love how you guys over there can just go in and order that level of mind-numbing stupidity off the shelf ..... almost makes me thing of emigrating! (we have performance shops and aftermarket nut jobs for sure, but I don't think we are at the ''wheel in your lambo and get bolt on 1500hp'' stage)
I would be that mind numbingly stupid if I had the money! Riding in one of those is almost as cool as the realization that your wanker is used for something other than peeing!
SpinnerRow is offline
Old 12-22-2011, 03:57 PM
  #4952
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK these last posts have been the best laugh I have had all week!
And no they had nothing whatsoever to do with the DLE20.
We now return you to your regularly schedule forum discussion on the DLE20
acdii is offline
Old 12-22-2011, 08:20 PM
  #4953
raubold
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
maybe we get back to the topic, but lambo 1500 hp ????????? 15 years ago when i ran Top Alcohol i had 1800 horses on Keith Black 548 cid Hemi stage 3 with newberry combination supercharged on straight Alcohol with 30 lbs of bosst ?? must be miniature Horses in the Lambo since Italians are short folks too i guess.
DLE 20, dont worry about Ethanol in the gasoline mix it fly it, works just fine, no matter what pump you used.
my 2 cents here
raubold is offline
Old 12-22-2011, 09:55 PM
  #4954
tmaucher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The problem with the ethanol is it eats the silicone gaskets it the carb and the motor. It will make a walbro carb diaphram hard over time. Run all fuel out after you fly and there wont be any problems.
tmaucher is offline
Old 12-23-2011, 12:39 AM
  #4955
Jonde
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tmaucher is right about ethanol in gasoline. Ethanol causes delamination of rubber, plastics, synthetic hoses, etc. It is also a strong solvent and as it breaks down varous organic materials they go in to solution. Some of these dissolved materials tend to settle out and form various gummy materials. So, in any fuel tank, engine system like in a DLE 20cc engine in a model plane, fuel containing ethanol will attack the rubber, plastic and synthetic components over time. Because ethanol is very hygroscopic, (holds water), it is also thought to form acetic acid as a reaction product, which causes metal corrosion. I worked on these problems, as a chemist, when they first went to an E85 type fuel in a big way in Brazil and experienced huge problems.
Despite my comments, I would not worry too much about our 10-15% ethanol containing gas. I would recommend that you inspect your carburetor rubber/synthetic components and hoses closely at least once a year.
Jonde is offline
Old 12-23-2011, 05:49 AM
  #4956
FlatSpin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had the very same questions about blended gasoline in my DLE 20 when I got into the world of gas engines this year. In case you want to try "clean gas", here is a link to search your state. In Colorado, there are only a few stations that still sell it at a regular gas station.
http://pure-gas.org/
I've been flying my DLE 20 on straight gas for about 8 months and have not has any issues with it. Great little engine.
Dave
FlatSpin is offline
Old 12-23-2011, 06:00 AM
  #4957
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oh just light a match, the ethanol will burn right off.
acdii is offline
Old 12-23-2011, 07:06 AM
  #4958
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: acdii
AND SO WILL EVERYTHING ELSE
w8ye is offline
Old 12-23-2011, 08:16 AM
  #4959
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: w8ye
Quote:
ORIGINAL: acdii
Well, no one said it was perfect!
acdii is offline
Old 12-23-2011, 08:27 AM
  #4960
microdon2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A slightly related question - I've had plenty of crashes with my Nitro planes, and a few with my gassers. But I've never had a fire break out, even when the tank has been puntured. I'm guessing that's cause there were no real sparks nearby to ingnite the fumes (since the engine was stalled by then). Or could it be that Nitro is not as flammable as gas fumes? I've seen some nice crash-fires on Youtube, but those always involve jets, which, I guess, crash with much more force \ explosive power. Any thoughts? (btw - not that I'm LOOKING for fires, either. I'm past that stage...)
microdon2 is offline
Old 12-23-2011, 08:39 AM
  #4961
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Methanol does not have the same flammability as gasoline
w8ye is offline
Old 12-23-2011, 09:34 AM
  #4962
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try this...pour a small amount of glow fuel on cement or hard packed dirt. Then with a long stick with a burning match...ignite the Glow fuel. It should ignite soft...compared too gas. Be carefull, where and how you do this. In bright daylite...acohol is hard to see burning! Capt,n
captinjohn is offline
Old 12-23-2011, 10:00 AM
  #4963
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jet go boom because the engine is spitting fire out the back end, unlike a gas/glow engine that goes boom internally. Open Flame, Gas Fumes, BOOM!
acdii is offline
Old 12-23-2011, 01:07 PM
  #4964
Jonde
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FlatSpin
Thanks for the great link to "clean gas" stations. There are a few listed that are not too far from me. Given a choice, I will use regular gas without any methonal added in my DLE 20cc.
Jonde is offline
Old 12-23-2011, 09:04 PM
  #4965
FlatSpin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad to help! Yeah, I bought 5 gallons of the clean gas to stock up. And then I used 3 gallons of it for my other lawn powered engines because the DLE doesn't use all that much.
There are some guys in my club that buy the blended gas and then add water to it to remove the ethanol. It actually works, but it can be messy! I’ve never done it myself, other than a 3 oz test in a mason jar, so Google it for complete instructions if you want to try it.
Dave
FlatSpin is offline
Old 12-24-2011, 05:19 AM
  #4966
SkidMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Jonde
FlatSpin
Very small distinction for several posts in this thread
M
ethanol (CH3OH) is the primary component of glow fuel.
E
thanol (C2H5OH) is added to gasoline.
SkidMan is offline
Old 12-24-2011, 06:27 AM
  #4967
FlatSpin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OOPS! Got to love Microsoft's auto spelling corrections. I meant "E".
THANKS for the clarification and all the great informaton in this link!
Dave
FlatSpin is offline
Old 12-27-2011, 03:22 PM
  #4968
WindGap
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Crud
Got some in my tank plugged up my fuel supply and engine quit. Argh! Where's the best place to insert fuel filter?
WindGap is offline
Old 12-27-2011, 03:30 PM
  #4969
ghoffman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the fuel filler and the tank vent, none from the clunk to engine.
ghoffman is offline
Old 12-27-2011, 05:50 PM
  #4970
Jonde
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SkidMan
Thanks for the correction on the fuels. I meant to say Ethanol when referring to gasoline and instead wrote Methanol. I'm either too new to gas r/c engines or it's an age thing!
Jonde is offline
Old 12-28-2011, 06:04 AM
  #4971
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go with the latter, works every time!
acdii is offline
Old 01-06-2012, 09:58 AM
  #4972
woodbender
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello everyone, and thanks for all the great info.
I'm definately a newbi with gas. Please pardon the question below if it's been covered already.
A club member suggested using white gas Coleman fuel instead of gasoline from the pump. I tried it just for the heck of it and my elderly Zenoah 26 seems to like it just fine. Yes, it's expensive (but less than glow fuel), but my friend says it burns cleaner with less carbon build-up, etc. and offers a higher octane level (more power).
I know just enough to be dangerous. Any thoughts, pro and/or con on running this fuel with my shiny new (and as yet unpackaged) DLE 20?
woodbender is offline
Old 01-06-2012, 10:10 AM
  #4973
SkidMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: woodbender
Some helicopter pilots swear by it. A guy at my club adds 10% white gas to his pump gas.
I haven't seen the need and pump gas works just fine.
Paul
SkidMan is offline
Old 01-06-2012, 11:24 AM
  #4974
raptureboy
raptureboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The alcohol is not a problem. Been using it for years no problem with newer equipment. here is a link to some expert information, Pat aka T.O.M knows what he talks about he's bben working with UAV engines for years. http://www.rcuniverse.com/forum/fb.asp?m=10166972
You just have to get past his gruff exterior Unfortunately he's not on here any more because some just could not handle his blunt truth ( read his sig line) I have the DLE 20 and just use reg gas and a good 2c oil mixed at 32:1 and don't follow the Tower Hobby instructions.
raptureboy is offline
Old 01-06-2012, 11:29 AM
  #4975
Estang
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Higher Octane does not give more power. It will slow down the flame and give a more controlled burn. Some engines require the higher Octane, where as other will not bennifit fromit. I am running Stihl oil with 91 octain pump guas in mine and it is still clean inside. I use to race Moto-x 2 strokes and ran H1R 2 cycle oil and it would actually clean the carbon off the top end. At $20 a liter it should have come with a new tool kit too
I know just enough to be dangerous. Any thoughts, pro and/or conon running this fuel with my shiny new (and as yet unpackaged) DLE 20?
Estang is offline
Display Modes
