DLE 20cc Gasser! (Data & Links 1st Post)
#5201
My Feedback: (7)
IN
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Start with what you'll end up with....no 'break-in prop' but the one you fly in the end.
Lots of pages because there's loads of info here!
Do read Post #1
Do read Post #1
#5205
I have 2 Xoar 16x8 and 17x8, but it is always good to have a spare, so I got a 16x10, Probably has the same pull as the 16x8 Xoar LOL
#5206
My Feedback: (47)
NY
I tried a Zinger once - got it cheap at a trade show. I was amazed at how much power was lost using this prop - lost about 1/2 the thrust of an APC. Hard to believe someone can sell a prop that's so inefficient. Guess they don't call them "Zinger"s for nothing.
#5207
My Feedback: (7)
IN
ORIGINAL: acdii
But comparing a Zinger to either a Xoar or a Vess is like night vs day.
If there's maybe 15 brands of props in the world (maybe more), then the Zinger's are at or near the bottom with Xoar & Vess at or near the top of such a list.
#5208
Yeah, its a spare prop, as long as the DLE20 can spin it. Heck maybe if the Xoar is too hot, the Zing can slow it down LOL
#5209
My Feedback: (47)
NY
Am about ready to start rebuilding my 70" Revolver with the DLE 20. But first... I have a generic gasser tuning question about my XYZ 50.
My XYZ 50 wasn't running great - wasn't getting high RPM's (was hitting maybe 5500 or so, instead of 7000 (that it should hit with a Xoar 20x10 prop), so I did some work on it tonight. Put on a new muffler (the old one had holes from crashes), checked inside the carb diaphragm and looked for dirt, and changed the manifold, between the carb and the engine. (the old manifold was pretty beat-up, also from crashes).
So now the engine sounds better and runs smoother at idle and through mid-throttle But when I get close to opening it (3/4 throttle) the engine bogs down so much it almost cuts out. I opened the High speed needle, but it didn't seem to help much. I opened the HS probably 1 - 1.5 turns more than the 2.25 it's supposed to start at. Any suggestions? The carb looks clean - no blockages or dirt inside that I can see. And the diaphram looks healthy. Should I open the Low speed more? (would have tried this but it was getting late). Thanks.
#5210
My Feedback: (7)
IN
ORIGINAL: microdon2
So now the engine sounds better and runs smoother at idle and through mid-throttle But when I get close to opening it (3/4 throttle) the engine bogs down so much it almost cuts out........................ Any suggestions? ................................... Thanks.
Btw....have fewer crashes!
#5213
My Feedback: (7)
IN
Well, you DID mention 'crashes' several times, so I thought I'd throw that clue in there. LOL!
Larry.....when's your buddy Captnjohn coming home?
#5215
ORIGINAL: a1pcfixer
#5216
My Feedback: (47)
NY
(I know this is not about a DLE 20, but I think these issues apply to all gassers, so... )
So I've got the XYZ 50 running nicely now. Steady idle and very good high end (will tac it tomorrow). Was a combination of opening the low speed needle and also adding liquid gasket to the surfaces and gaskets around the carb manifold. Seems like there might have been a slight air leak that was increasing with the higher RPMs. Now with the liquid gasket she's running very nicely. I also saw that the Halls Sensor had loosened slightly and shifted a touch, so I re-centered that. That didn't seem to make a difference.
One more recent issue with this plane - now when the engine is running the elevators shake and move intermittently on their own - my guess is radio interference. This intermittent movement is independent of whatever controls I do. I've had this plane for over a year and this is a new development. Can radio interference pop up out of nowhere? From what I see I can't find any obvious wear on any cables. Am wondering if Ch 2 on the receiver might be going bad (though the elevators work fine when the engine's not running). Any other thoughts? Guess I can swap in another EI to see if that's the cause. Any ideas on what I should look for that might be generating radio interference?
#5218
My Feedback: (47)
NY
I'm usually careful to fully seat the boot, though can't vouch for those particular instances in hindsight. And that plug boot is split at the seems - could that leak noise?
Right now I'm swapping in a new XYZ ignition. If this IS the cause then I want to salvage the old EI. Anyone know how to change the boot? Do you need a special tool to crimp this type of cable? Would hate to throw away a perfectly good CDI Rcxcl ignition because of the plug boot.
Will report back after I start this thing up.
#5219
CA
www.valleyviewrc.com/estore/engine-parts/ignition-accessories/spark-plug-caps.html
if you got something like this im sure it would have instructions with it.
Id call valleyviewrc.com since they sell XYZ engines. They will tell you what size you need.
#5220
My Feedback: (7)
IN
ORIGINAL: microdon2
.........................................Anyone know how to change the boot? Do you need a special tool to crimp this type of cable?..........................
#5222
My Feedback: (7)
IN
Look closely at photo #1, which shows the tiny resistor on the end - right portion of photo.
And be SURE (if you do one) to put the shrink wrap on loosely BEFORE everything else!
#5223
ORIGINAL: a1pcfixer
That little resistor was the subject of quite a discussion not too long ago. There was a comment made by somebody in a position to know, that it's not necessary. Some engines are supplied with ignitions that use them, others that don't. SO, in the interest of simplicity/KISS, the next one I do is going to have a piece of safety wire in it's place. Will give that a try....
#5225
ORIGINAL: w8ye
Spark plugs like the 1/4-32 and the CM-6 use the resistor and the others do not because they use resistor type plugs..
