DLE 20cc Gasser! (Data & Links 1st Post)
Old 06-06-2012, 10:11 PM
  #5501
raydar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
The graupner 15 8 3 is the prop you want, it has a wide blade and is quite efficient unlike a mas. Expect about 8000 rpm from it.
raydar is offline
Old 06-07-2012, 05:19 AM
  #5502
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not having much luck finding one in that size, those I am finding are 11" and under. Reason Iam considering the MAS is I can get it quickly from either my LHS or Tower, though with the LHS it took 3 times as long to get my last thing than it would have from Tower.
NM found it finally, Not cheap thats for sure, nearly twice what the MAS is.
acdii is online now
Old 06-12-2012, 05:02 PM
  #5503
RBean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
acdii, I have MAS 16-8 Three blade. Old one turns 8,200 rpm with DLE 20. New one which is redesigned turns 7,400 rpm but does not loose much thrust. I have a Graupner 15-8 three blade on a DLE 20, it turns 8,600 rpm.
RBean is offline
Old 06-14-2012, 02:57 PM
  #5504
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well this is interesting, just browsing sites for DLE and came across the DLE page. They say props down to 14x10.   Anyhow, I have a 15 3 blade enroute and will see how it works. It would be nice to be able to land without striking the prop.
acdii is online now
Old 06-23-2012, 02:06 PM
  #5505
Falcon32
Falcon32's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm just about to start my DLE 20 for the first time and have a couple of questions.
Mineral or synthetic and is it OK if the oil is a couple of years old but has been kept in a sealed container?
Falcon
Falcon32 is offline
Old 06-23-2012, 02:29 PM
  #5506
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Should be fine but 30 or 32:1 one the DLE20
w8ye is online now
Old 06-23-2012, 03:51 PM
  #5507
tailskid
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have an interesting 'new' problem....I switched the throttle arm to the additional one (longer) that came with the engine....it was difficult to get the screw out of the original but now when I tighten the new one, the throttle will not move! Suggestions?
Jerry
tailskid is offline
Old 06-23-2012, 04:16 PM
  #5508
skip1320
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Prolly bent the brass shaft
skip1320 is offline
Old 06-23-2012, 04:17 PM
  #5509
tailskid
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Crud....now what can I do?
tailskid is offline
Old 06-23-2012, 04:30 PM
  #5510
Twin_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did you push the new arm too far down on the shaft before you tightened it and it's hitting the carb body? Loosen the setscrew, pull it away from the body and tighten carefully and try again.
Bill S>
Twin_Flyer is offline
Old 06-23-2012, 04:56 PM
  #5511
tailskid
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Bill, but I removed the engine from the plane and reinstalled the one that was originally on the engine and I can bearly move it. I removed the spring from the other side hoping it would work easier - noope
Stuck as it takes a LOT of force to move the throttle. Even took the screw to the orginal arm out and with only the arm, can barely move it. Wasn't that way when I opened the box
tailskid is offline
Old 06-23-2012, 05:16 PM
  #5512
microdon2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
tailskid - try taking the throttle plate off. Maybe you pushed the axle a bit and the plate is binding inside the carb throat. And, as Twin Flyer said, I've also pushed the throttle arm down too far before tightening, causing binding between the arm seat and the carb. I doubt you bent the throttle axle.
microdon2 is offline
Old 06-23-2012, 05:37 PM
  #5513
tailskid
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll try that!
tailskid is offline
Old 06-24-2012, 02:23 AM
  #5514
airborne2.4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mach2
Im in the market for a 30cc. Im pretty set on the DLE30 since I know its good. But Why not keep the options open....
Jeremy
OS GT33
http://www.osengines.com/engines/osmg1533.html
airborne2.4 is offline
Old 06-24-2012, 03:59 AM
  #5515
microdon2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like OS's pricing (on TH, anyway) for the GT-33 is not too bad - after the TH $50 discount, the GT33 is $350 - which is still $80 more than a DLE 30 after discount, but the GT33 comes stock with a Pitts-style muffler. If you add a Pitts-style muffler to the DLE 30 that adds $75 - bringing the engine to equal pricing. Of course, this doesn't take into consideration any quality issues. Maybe someone can comment on the quality of the OS engine - I'd suspect it's very good, going on their Nitro engines, but that's just a guess.
But their pricing for the GT55 is double the DLE 55 (which get's rave reviews here on RCU). After TH $50 discount, the GT55 is $599, where the DLE 55 is $319. And you still have to buy a muffler for the OS55 - another $90. So now we're talking $319 vs $690. HP numbers, for what they're worth, are very similar. Does anyone have any idea why OS would price their 55 so high?
Old 06-24-2012, 04:23 AM
  #5516
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: microdon2
But their pricing for the GT55 is double the DLE 55 (which get's rave reviews here on RCU). After TH $50 discount, the GT55 is $599, where the DLE 55 is $319. And you still have to buy a muffler for the OS55 - another $90. So now we're talking $319 vs $690. HP numbers, for what they're worth, are very similar. Does anyone have any ideal why OS would price their 55 so high?
You're aware there's a new DLE just now being introduced? Not a lot of "in service" reports, but there's info floating around. If you're in the market, look for info on the DLE 35R - it's a rear exhaust engine as well. TBM put a price on them.
ahicks is online now
Old 06-24-2012, 05:48 AM
  #5517
bgw45
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Valley View RC has the 35r listed and priced on their site. It appears to be in stock.
bgw45 is offline
Old 06-24-2012, 05:56 AM
  #5518
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Expected to be in stock about the middle of July
http://www.valleyviewrc.com/estore/d...as-engine.html
w8ye is online now
Old 06-24-2012, 06:10 AM
  #5519
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is the 35cc equivalent to in the 4 stroke range?
acdii is online now
Old 06-24-2012, 07:46 AM
  #5520
Falcon32
Falcon32's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks W8Ye Will use 32:1
Falcon
Falcon32 is offline
Old 06-24-2012, 01:38 PM
  #5521
bgw45
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, w8ye, for correcting me. Could what my wife says about my listening be also true about my reading?
bgw45 is offline
Old 06-24-2012, 01:51 PM
  #5522
tailskid
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still can not get the throtte to work smoothly (as easy as the choke)....anyone help? It takes both hands to move the throttle from idle to full!!!!
Jerry
PS I pushed from the bottom and pulled from the top and it is getting a bit easier, but no where near what it was.
tailskid is offline
Old 06-24-2012, 02:09 PM
  #5523
tailskid
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: microdon2
Here are some pictures of the carb closed...it doesn't look like there is any evidence that the plate is binding but I may be in error.
Thanks for the advice microdon2!
ID:	1775344   Click image for larger version
ID:	1775345   Click image for larger version
ID:	1775346   Click image for larger version
tailskid is offline
Old 06-24-2012, 07:39 PM
  #5524
microdon2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
tailskid - did you try removing the throttle plate to see if it made a difference? It's very easy to get off and back on, btw.
Old 06-24-2012, 07:47 PM
  #5525
tailskid
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No I haven't...but I'll try that next....thanks microdon2!
tailskid is offline
Display Modes
