DLE 20cc Gasser! (Data & Links 1st Post)
#5527
CA
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
If I remember right, that is an old post....but im glad he dug it up, because I DIDNT KNOW ABOUT A DLE 35R! Ive gotta look that up!
ALSO! valleyviewrc.com as the DLE20 on sale for $245. And they give you a free prop with an engine purchase...
#5528
CA
well I just checked on it. It better have a way better power to weight ratio since it costs what a DLE55 costs.....
Most 30cc planes Im looking at can be hovered with a 28cc engine with no problem. The extra cost will probably keep me away from the new 35R. If im spending that much, Ill spend a few more bucks on the plane and get an 88" 50cc plane and the DLE55.
It makes sense that the cost is a wash with the addition of a pitts muffler, but Ive never even considered buying a pitts muffler because they are ridiculously priced. I did by one for 20 bucks used once...
And the way the muffler is mounted on the 35R makes it to where the engine cannot be moved back at all. The Goldwing MX2 needs to have the DLE30 moved back for the spinner to meet up with the cowl ring well. The firewall has to be opened up to slide the carb through. Also, I dont mind the look of either DLE 20 or 30 mufflers.
Just my personal opinion. But its always good when companies make more options. Id like to see a DLE 15, and a DLE 75 or 85
Jeremy
Jeremy
#5529
Lesson learned: Anything loose can get sucked into the engine.
See the whole story at DLE 20 won't stay running.
#5530
My Feedback: (8)
tailskid chances are you twisted the shaft and being flat in the middle for the throttle plate makes it essenctric and will cause binding. I sent you a PM. Hope this will help.
#5532
Hi Guys
I would like to ask one more question.
I have replaced the ignition unit to the rcexl one without the funny advance.
On checking the timing with the rcexl ignition tester I get around 36-38 degrees.
I don't think the original sensor will give me enough movement to change that by much.
Will I need to fit the new sensor that came with the ignition unit and set it at 28 degrees.
Falcon
Falcon
#5534
Thanks w8ye.
I'm OK on the method, just need to know if I need to re time it to 28 degrees with the standard (not the No4) ignition, and will I need to use the new sensor and adjustable bracket.
Falcon
Falcon
#5538
TX
The instructions on the RCXL checker say that the prop hub should be turned to the point when the beeper goes off. The beeper off point is the proper timing point. This can be confirmed by simply installing a cm6 in the cap and it will fire at the same point.
I did not read the instructions and misled myself till Jody squared me away.
#5540
Hi Guys
Thanks for all the information you have posted, but I think I need to clarify a couple of points.
I'm sure that the sensor fitted to the engine is in good condition and will get the engine running.
Also I know how to use the RCXL tester unit correctly although the instructions are not that helpful.
The real issue is that if you read the Hobbico manual for the DLE 20 it states the timing to be 38-40 degrees BTDC.
Using the tester I'm getting about 38, which I believe is correct if using the original #4 ignition unit.
However I've swopped that one out for the unit more commonly used on the DLE 55 where the timing is 28 degrees BTDC.
My question therefore is should I leave the timing at 38 degrees or change to 28 degrees.
Thanks for your patience.
Falcon
Falcon
#5544
CA
ORIGINAL: Falcon32
Hi Guys
Falcon
Hi Guys
Falcon
Jeremy
#5546
My Feedback: (34)
Buggers are out of stock Thanks for the part number Bill......I wonder if the 30cc and 20cc carbs are the same.
I got the carb back from the lawnmower shop and he showed me where the 'arm' (inside the carb) is twisted....wonder if I could 'untwist' it?????? It is bent in the direction of tightening the throttle arm.
#5547
My Feedback: (34)
Alright guys..........I did it! With GREAT amount of tension, I removed the entire throttle barrel and gently twisted the brass back to shape and then even put everything back and it works smoother now than when it was new! Thanks to all of you for your help.
Jerry
Jerry
#5548
OH
ok you crazy kids im putting my dle 20 on my top flite arf 60 size just took it off of my top flite p-51d hurry home honey so the head is broken in im going to mount it with some 1.20 -1.50 dubro motor mounts wish me luck
