If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 224 of 274 FirstFirst ... 124174214222223224225226234 ... LastLast
Results 5,576 to 5,600 of 6835
  1. #5576
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
    Lifer - sounds like a good idea. And you've tested this and found no reduction is RPM or power? Have you tried different sized holes in the baffle? ( I do like this idea - think I'll try it).
  2. #5577
    Join Date
    Jul 2012
    Scotland, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks all for the replies.
    I think I will give Lifers suggestion a go, was thinking along the same theme myself, thought I would go to a local golf shop and see if they had any old stepped club shafts that I could use instead of copper tube.
    Yes I too like the sound of real engines but you've got to admit the DLE20 is a little over the top, its not me thats bothered just a little concerned about others that live near our flying site.
    I have seen the exhaust plugs that are on offer from Valley View, but anything I've imported from the States recently has been hit with very high import duty, value added tax, and handling charges for the privalage of paying the duty/tax, whilst when buying from China it sails through at no additional cost, very strange!.
    Cheers
    John
  3. #5578
    Join Date
    Mar 2009
    Harrisburg, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guys, I highly recommend the J'Tec radiowave inverted muffler. They have a nice sized can on them and a heat treated finish. They are top notch and a little expensive, but they will hold up well and last you a lifetime. They are nice and quiet compared to the stock exhaust, which isnt a muffler its a piece of foil shaped in a tiny rectangle. I have some on my DLE 30 and my 20 and you won't regret buying them. I'm sure no one wants to be a contributor to losing not only your hearing but your flying field to save $80 because the DLE is too cheap to provide one. Kudos to OS for including a good muffler in the new 33!
  4. #5579
    Lifer's Avatar
    Join Date
    Aug 2008
    Kansas City, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, different sized holes create differences in sound and there is a small reduction in power, but what the heck! It cost a couple of bucks for the tube and you can make 4 different baffle sets. Have fun!
    I have several of the J-Tech mufflers and they work fine, but are louder than the modified factory version we discussed.
    AMA #77967/CD/LM
  5. #5580
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Even some of the Pitts mufflers are too loud. Although it has reduced he volume a bit, it is still loud on mine. I like the idea of making a car muffler out of the can with Tubing.
    SIG Brotherhood # 3
    Mustang Brotherhood # 6
    Corsair Brotherhood # 86
    Kadet Brotherhood # 24
    http://www.facebook.com/pages/B-17e-...18159428244374
    I don't crash I just land wrong
  6. #5581
    Join Date
    Jul 2008
    Destin, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can someone help with a DLE 20 Gremlin this has almost everyone at my field kind of stumped?
    Get to the field, choke engine, engine fires. Unchoke engine, engine fires!!! Idle for 30 seconds or so and then open throttle up. run throttle up and down, engine responds just fine.
    Now if I happen to get the plane in the air, it will run for maybe 5-8 minutes then uh oh Dead stick landing-happened twice, plenty of fuel left in the 14 ounce tank.
    Sometimes, I just pick the plane up after doing all the above keeping it level to place on runway engine dies
    Very difficult to get engine to start unless we let everything calm down for maybe 10 minutes or so then we go through the same problem.
    I've pulled the gas tank three times now, checked the plumbing, checked the clunk, redid the plumbing-no change.
    We pulled the screen on the carb, clean as a whistle.
    Bypassed the engine cut off still the same issue.
    New spark plug Twice
    It's like it either is running out of fuel (but tank is more than half full), or the ignition just stops working after a few minutes. Battery voltage is kept at over 5v and less than 6v. Checked every time.
    I'm gonna pull the engine off the plane and remove the carb I just don't know what is going on.
    One last thing, I did reverse this carb, 180 degrees before installing. But like I said, the engine has run for as long as 8 minutes before cutting out so I don't think it is the carb position.
    Engine bought from VVRC last December.
    Anybody have any thoughts?
    Thanks-
    Larry
  7. #5582
    Join Date
    Jul 2011
    MacleanNew South Wales, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Suggest looking at your electrics for a possible short or dry joint.
    β€œIn order to fly, all one must do is simply miss the ground.”
  8. #5583
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If using a 5 cell NIMH, switch to a 4 cell 2000mah pack instead. Sounds like the ignition to me too.  When the engine quits, and you cant get it started, is there fuel on the plug? That would be a good indicator of the ignition.
    SIG Brotherhood # 3
  9. #5584
    Join Date
    Jul 2008
    Destin, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm using a 4 cell Nimh which is 1650
    Thought that would be plenty
    And yes. The plug is wet
    I eliminated the cut off. Gonna look at the switch too
    Maybe just a bad ignition?
  10. #5585
    chandley43231's Avatar
    Join Date
    Apr 2010
    columbus , OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Okay guys I need an opinion about what prop I should put on my Topflite 60 corsair arf
    CORSAIR BROTHERHOOD #85
  11. #5586
    Join Date
    Aug 2008
    Waterford, Mi/Citrus Springs, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The hard starting suggests that your LS needle is too lean. If you haven't yet, I would be tempted to start your tuning process over again, right from the start, where the Low and High speed needles are set at 1.5 - 1.75 turns or so? While tuning, instead of trying to get it as lean as possible, suggest you go the other way. Keep it as rich as possible while still running cleanly (rich engines seldom quit).
    Assuming it has one, have you tried running it without a cowl?
    Best of luck...
  12. #5587
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That should be enough mah, I prefer higher only because of the lower voltage. The higher the voltage the lower the mah can be to get similar run times.  Have you put a battery checker on it after it quits? I have one from the LHS that loads the pack with 300 mah and reports back capacity.  One other suggestion, and I did this myself, cycle the pack a few times if you have a charger that can do it automatically. It increased the run time of the pack.
    SIG Brotherhood # 3
  13. #5588
    Join Date
    Jul 2008
    Destin, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yah. I have this 20 on a spacewalker 2 but as usual keep the cowl off for the first couple of tanks
    Running rpm is less than 8k at full throttle and slightly less than 2k at idle
    Yes it is a bit rich
    Is there a way to test the ignition under load?
    Battery voltage after it quits is just over 5v so I'm pretty sure the battery is doing the job
  14. #5589
    Doomking's Avatar
    Join Date
    Nov 2002
    North Ridgeville, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sounds to me that if it quits in the air and then you need to wait a while before it starts again, it might be overheating.
    In the air the plane will unload so whatever reading you get on the ground it might get leaner in the air.
    I agree with the other member. Take cowl off and set all the needles factory settings. Low Needle 1.1 turn High needle 1.5 turns and go from there.
    Also after one of those dead stick runs, did you look at the plug? The plug color will tell you a lot how you are running your engine.
    Good luck.
  15. #5590
    Join Date
    Jan 2002
    Westhampton Beach, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Does the engine support rotating the carb 180*?
    The port on the block woudl have to be in two places for it to match the carb being rotated, right?
    Just wondering...
    BIll S>
    Goldberg Tiger Club #17
    Citabria/Decathlon Brotherhood # 18
    Carl Goldberg Ultimate Brotherhood #56
    SIG Brotherhood #69
    Balsa USA Brotherhood #127
    Ultra Sport Brotherhood #135
    http://radiocontrolhobbies.freeservers.com
  16. #5591
    Join Date
    Jul 2008
    Destin, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Everyone I certainly appreciate the advice and ideas and I know it is kinda tough to troubleshoot without being here
    Let me say a little more
    The guys at the field know quite a bit about dle engines but as always can learn more
    The cowl has never been on the plane other then on the workbench to make the cuts. The guys at the field won't let me fly with cowl until at least two tanks thru the engine. The screw settings on the low side were changed and then changed back the high side was checked and never moved So I don't think overheating is the issue but Can't rule it out.
    I have been told that the carb can be rotated by folks on this forum and I dont know but suspect the engine wouldn't even run if the carb wasn't doing its job. At least partially. Of course. Who knows for sure
    The engine runs fine for the time it does and then it just cuts out. Just like I threw the cut out switch
    Its like No fuel. Or no ignition
    I think I have eliminated fuel draw out of the tank
    Wondering if the carb is messed up somehow or the ignition is quoting after working a while
    Just want to thank everyone for chipping in and trying to help
    All comments are appreciated
    Larry
  17. #5592
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: phakur
    Larry
    Larry, has anyone really adjusted this carb (adjust HS for max rpm, then set LS for good transition), or are you/they trying to run it on the factory settings? -Al
  18. #5593
    Join Date
    Jul 2008
    Destin, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yeah. We opened the low a bit to make sure we could get fuel into the engine. It being new. Didn't go much in the high side other then checking rpm. I think we gave it less then a quarter turn. The engine runs great for the several minutes in runs. No hesitation no stuttering. Up until the second it just quits Moved everything back to factory setting in an attempt to clear the problem
    I'm using lawn boy oil mix so we are seeing a small amount of deposit out the exhaust as you would expect
    It's just kind of wacky
    I'm pulling the engine and will have the guys at the field take a look at the carb this weekend but still don't know how to eliminate the ignition as a possibility
  19. #5594
    Join Date
    Sep 2004
    Mohave Valley, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I had a similar symptom caused by a loose wire in the battery connector. I finally noticed the " hot ignition" led was not lit.
  20. #5595
    Join Date
    Aug 2009
    Newaygo, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  21. #5596
    Lifer's Avatar
    Join Date
    Aug 2008
    Kansas City, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    As far as the question on the Corsair prop issue is concerned, you might try a 3 bladed 16x8 or 15x7 from Master Airscrew. I use both.
    AMA #77967/CD/LM
  22. #5597
    Join Date
    Aug 2010
    Leander, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My DLE 20 runs greatbut-it takes about 10 to 20 seconds to slow to low idle after running at a higher rpmwhen it does come down to low idle it is fine-transition to full throttlr is fine-runs great except for this quirk
  23. #5598
    Moderator w8ye's Avatar
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The low speed needle valve is set too lean
    Attended the CutFinger Institute of DirtNap University for years but never did graduate....
    Recipient, Mangledhand award August 2008
    Club Saito Member #7
    Original AMA #31261
  24. #5599
    Lifer's Avatar
    Join Date
    Aug 2008
    Kansas City, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Plus 1 on w8ye's comment.
    AMA #77967/CD/LM
  25. #5600
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, I had my second flight with the 4* the other night. I switched the prop to an APC 16X6 and it woke it up.  I did not touch the needles on it, and it ran good. No transition issues like the first time with the MAS, temp was about the same, except lower humidity.  It idled down good, a quick touch o throttle got the RPM's up and it idled down nice again during my final, so looks like I got the engine dialed in well for the next gallon or two until it is finally broken in. When I landed after a 9 minute flight, the engine was cool, as in if I touched it I wouldn't get burned.  Has a little burble to it at high end, but no performance issues. I think the 4* has a 12-14 ounce tank and I used 1/4 of it for the 9 minute flight, which should relate to 30 minutes of flight to the tank. Wow!  Big difference between the APC and MAS props on this plane.  The MAS used much more fuel. I burned up a whole tank in 15 minutes with the MAS on.
    Hooked now on APC props, have them on 3 of my planes that used to have MAS K.  All three fly much better.
    SIG Brotherhood # 3
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
