If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 225 of 274 FirstFirst ... 125175215223224225226227235 ... LastLast
Results 5,601 to 5,625 of 6835
  1. #5601
    Falcon32's Avatar
    Join Date
    May 2006
    Neath, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
    Hi John
    If you want to quiet it down try here http://www.gashanger.com/index.php?o...d=68&Itemid=75
    A bit expensive and you will loose about 300 RPM but it does work.
    Falcon
    I’d rather be twiddling my thumbs.
  2. #5602
    Join Date
    Jan 2002
    Westhampton Beach, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Troy Built Models has something like that as well, and its only $20.
    http://www.troybuiltmodels.com/items...0SILENCER.html
    Bill S.
    Goldberg Tiger Club #17
    Citabria/Decathlon Brotherhood # 18
    Carl Goldberg Ultimate Brotherhood #56
    SIG Brotherhood #69
    Balsa USA Brotherhood #127
    Ultra Sport Brotherhood #135
    http://radiocontrolhobbies.freeservers.com
  3. #5603
    tailskid's Avatar
    Join Date
    Nov 2001
    Tolleson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just bought one..should be here next week....
    We are here on earth to do good unto others. What the others are here for, I have no idea.
    ~ WH Auden
  4. #5604
    Join Date
    Aug 2008
    Waterford, Mi/Citrus Springs, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: acdii
    Well, I had my second flight with the 4* the other night. I switched the prop to an APC 16X6 and it woke it up. Β*I did not touch the needles on it, and it ran good. No transition issues like the first time with the MAS, temp was about the same, except lower humidity. Β*It idled down good, a quick touch o throttle got the RPM's up and it idled down nice again during my final, so looks like I got the engine dialed in well for the next gallon or two until it is finally broken in. When I landed after a 9 minute flight, the engine was cool, as in if I touched it I wouldn't get burned. Β*Has a little burble to it at high end, but no performance issues. I think the 4* has a 12-14 ounce tank and I used 1/4 of it for the 9 minute flight, which should relate to 30 minutes of flight to the tank. Wow! Β*Big difference between the APC and MAS props on this plane. Β*The MAS used much more fuel. I burned up a whole tank in 15 minutes with the MAS on.Β*
    Hooked now on APC props, have them on 3 of my planes that used to have MAS K. Β*All three fly much better.Β*
    The 20's really like the APC 17x6. If you get the chance they are definitely worth a try. Going that way will load the engine a little more, and might even help clear up that burble? -Al
  5. #5605
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    All the LHS had was a 17x4, otherwise I would have tried it.  For now I will fly with the 16x6 and order the APC when I have other items to order.   Once I get my landings smoothed out where I stop bouncing and knicking the prop, I will go to the larger one.
    SIG Brotherhood # 3
    Mustang Brotherhood # 6
    Corsair Brotherhood # 86
    Kadet Brotherhood # 24
    http://www.facebook.com/pages/B-17e-...18159428244374
    I don't crash I just land wrong
  6. #5606
    Join Date
    Jul 2012
    Scotland, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Falcon32
    Hi John
    Falcon
    Thanks Falcon, that's interesting and will maybe try this option if I don't have any luck with Lifer's suggestions, didn't know anyone was doing these here in the UK, I'm very envious of the availability and prices of RC stuff that are available to people in the States.
    Thanks also to Twin-flyer, but as I previously posted we are being really hard hit by customs and excise on buying anything from the States, a few years ago this was not a problem but now it is. As an example about a year ago I mail ordered a Aeroworks Prox .60-.90, after paying postage, import duty, vat, and, insult to injury handling charges it cost me around £240.00 thats around $375.00.
    Cheers,
    John
  7. #5607
    Join Date
    Jan 2002
    Ringgold, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Make sure your fuel tank's vent line is unobstructed, i.e., no kinks.
    Ed Cregger
    \"Practice makes prefect\"
    Saito Club Member #52
  8. #5608
    Join Date
    Apr 2007
    Lady Lake, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Something to look out for on these DLE 20s is the spring clip for the throttle shaft coming off. Then the spring pushes the throttle plate againt carb barrel side and distorts the plate. Had this happen twice. The sign was the engine wouldn't idle down. Too much fuel and air leaking through the distorted area. I tried to fix by hammering out the distortions and filing the edges down smooth. But couldn't get it close enough. Still leaks but will idle down slower. Need new carb but every one is "out of stock".
  9. #5609
    tailskid's Avatar
    Join Date
    Nov 2001
    Tolleson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oops, I took my spring OFF - hope that doesn't hurt anything.....
    ~ WH Auden
  10. #5610
    Join Date
    Jul 2011
    MacleanNew South Wales, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Suggest putting the spring back on as it is needed but do not hook it on to the arm.
    ORIGINAL: tailskid
    β€œIn order to fly, all one must do is simply miss the ground.”
  11. #5611
    tailskid's Avatar
    Join Date
    Nov 2001
    Tolleson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That will be tricky....but I'll try. Thanks for the advice...
    ~ WH Auden
  12. #5612
    mach2's Avatar
    Join Date
    Nov 2011
    bakersfield, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rhd-RCU
    Flying fields have been lost because of the noise. What we like and what the rest of the community likes are two differnt things.
    Completely understandable, but I think this conversation started as a "what I like" thing. So that's where my side of it is coming. So to tell eachother that this sucks, or that sucks is different. That is simply opinion.
    The 20 is perfect for the old man next door who stole my trash can and dumped the trash on my lawn because he feels my trash can should be behind my fence so he doesn't have to see it! I need to do some tuning today for a matter of fact.....
    Jeremy
    86" Aeroworks Extra 300, RCGF 60cc
    70" Revolver, DLE20
    57" The World Models P-51, TT.61 pr
  13. #5613
    rhd-RCU's Avatar
    Join Date
    Jan 2002
    burlington, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I said nothing about sucks. I just stated a fact and also how I feel.
    rd
  14. #5614
    mach2's Avatar
    Join Date
    Nov 2011
    bakersfield, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rhd-RCU
    Oh, no. I was talking about someone else's comment about the volume. Sorry for the miscommunication. Its kind of a dead subject now. I just hadn't been on in a few days so i didnt see that the topic has changed to a tuning question. I was just saying that i understand what you are saying and that I feel there is two sides of the noise issue. One side is how we as flyers like or dislike the sound of our planes, and then on the other side of the coin is the issue of nuisance to the community. Luckily I fly in a remote location so its a non issue.
    Jeremy
    70" Revolver, DLE20
  15. #5615
    mach2's Avatar
    Join Date
    Nov 2011
    bakersfield, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    does anyone have a good source to buy the spinner adapter nut? I ordered one from horizon a while back but I dont like the way the threads feel on it. The 8x1 nut is kinda hard to find.
    Jeremy
    70" Revolver, DLE20
  16. #5616
    Join Date
    Aug 2009
    Newaygo, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tower H
  17. #5617
    Lifer's Avatar
    Join Date
    Aug 2008
    Kansas City, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tower sells one that is part of the .60-size P-47. You also might pick up a tap and clean up the threads on the spinner nut you have. Bye the way, the DLE 20 is a GREAT fit for the Top Flight P-47. Flies great with a 16x8.
    AMA #77967/CD/LM
  18. #5618
    mach2's Avatar
    Join Date
    Nov 2011
    bakersfield, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ill do some more searching on TH. their search function can be kinda finicky, but I can find it. thanks.
    Oh, and the DLE20 is apparently a great motor for a lot of planes! Ive used it in my 70" revolver and its awesome. ive seen videos of it in a P51, a Zero, Extras, Edges, and Ive seen it in a stinkin' trainer!  Ive just put it in my Goldberg Egde 540. It is an awesome little engine, and in my opinion its a Glow motor killer in anything from a 60 to 120 size plane....
    Jeremy
    70" Revolver, DLE20
  19. #5619
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got the spinner nut and flat nut for the DLE from TH, but the flat nut didn't fit, the threads dont look correct, so thinking it was mislabeled. So I used one stock nut and the spinner nut. Makes it easy to start, and added a little nose weight.
    SIG Brotherhood # 3
  20. #5620
    Join Date
    Aug 2010
    Leander, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thank you for the info-had not tried changing the low speed-howeverwhen I went lean about 1/8th turn it now idles smooth and retards promptlyabout 1800 rpm-thanks again-
  21. #5621
    Join Date
    Aug 2010
    Leander, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't have the part number handy but I called Tower and told them what I wanted-they shipped one that works perfect on the DLE 20 withe the spinner that comes with the Revolver
  22. #5622
    Join Date
    Dec 2008
    New Delhi, INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: mach2
    Jeremy
    hobbyking has 8x1 used many of them..... thru a friend i managed to get some 8x1 nylocks...they rock.
    Cheers....
    Sandy Jain
  23. #5623
    mach2's Avatar
    Join Date
    Nov 2011
    bakersfield, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Cactus463
    www3.towerhobbies.com/cgi-bin/wti0001p
    70" Revolver, DLE20
  24. #5624
    tailskid's Avatar
    Join Date
    Nov 2001
    Tolleson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    30:1 ratio is about 4 oz of oil per one gallon of fuel - right?
    ~ WH Auden
  25. #5625
    mach2's Avatar
    Join Date
    Nov 2011
    bakersfield, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yep. I run 30:1 Maxima 927 castor oil. Motocross race oil. Smells way better than any mix ive ever smelled. I used it for a decade when I raced motocross, so I enquired to DLE about it and they said it would be a good oil.
    70" Revolver, DLE20
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
