DLE 20cc Gasser! (Data & Links 1st Post)
Old 08-17-2012, 06:53 PM
  #5701
mach2
mach2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Hey Spinner. What size P51 did you put it in? Ive got the .46 size and I am running a Thunder TIger .61 Pro in it. I love that little plane (Miss America).  I picked it up from a guy getting out of the hobby for $100 bucks. I know guys put big motors in them for racing. I actually thought for a second about putting a DLE20 in it.  It would land at 1000mph, but it would be a blast in the air!
Jeremy
mach2 is offline
Old 08-18-2012, 05:23 AM
  #5702
SpinnerRow
SpinnerRow's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mach2
[link=http://www.airborne-models.com/html/productdetails.asp?ProductID=56]World Models .60 sized P-51[/link] that I bought from Airborne Models. I plan to soon get their giant scale P-51 (80") and put that new DLE 35RA in it. I think that would be a killer combo.
SpinnerRow is offline
Old 08-18-2012, 06:33 AM
  #5703
microdon2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Spinnerrow - I picked up an H9 P51 150, 80", with a MVVS 35 inside. On the maiden I dropped it down to the ground too abruptly and tore off one of the gear. Need to fix and reinforce both wing areas around the gear - there's actually not much there for reinforcement.
I also need a muffler - this thing had (I bought it used) only a header - no muffler - so it's loud as hell. Problem is finding a muffler that'll fit inside that narrow cowl. I read on Youtube that another owner got a custom muffler made from JTec.
After I rebuild my other Rev 70 \ DLE 20 this P51 repair is my next project.
microdon2 is offline
Old 08-18-2012, 07:30 AM
  #5704
SpinnerRow
SpinnerRow's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: microdon2
Spinnerrow - I picked up an H9 P51 150, 80'', with a MVVS 35 inside. On the maiden I dropped it down to the ground too abruptly and tore off one of the gear. Need to fix and reinforce both wing areas around the gear - there's actually not much there for reinforcement.
You are always finding deals on planes! I need some of that!
I would check out the Jtech Compact Wraparound Pitts mullfers. They narrower than their standard mufflers and made for narrow cowls. The good thing about the new DLE 35RA is that it is rear exhaust and you don't have to buy an expensive wrap around muffler for it.
Old 08-18-2012, 07:37 AM
  #5705
Falcon32
Falcon32's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Didn't think it would run with the choke "ON"
Mine takes about 10 - 12 flips with the choke "ON" before it pops and then 2 - 3 flips choke "OFF" before it runs.
Was just wondering if anyone had a "special" method to save my arm
Falcon32 is offline
Old 08-18-2012, 07:41 AM
  #5706
Falcon32
Falcon32's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Falcon32 is offline
Old 08-21-2012, 07:00 PM
  #5707
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine is finally breaking in. Started today rather quickly, then once it had run once, it fired off every time with one flip of the prop.
Tried something tonight on my 4*120, I swapped out the APC 16x6 after the first flight with the ZOAR 16x8, and flew it. It lost some speed, half throttle was slower, and it lost altitude, and top end was lower.  The take off was a bit quicker but thats about it.  I put the APC back on and it flew better.
One final test is to try out the XOAR 17x6 that I also have for it. I need to ream it, or would have tried it tonight.
acdii is offline
Old 08-22-2012, 06:05 AM
  #5708
coronabob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: FSFLYER
I was having trouble starting mine before the first flight of the day. Took something like over 60 flips to get it to pop with the choke on. I think it just doesn't have a strong fuel draw on choke. I have a fueling ''T'' in the line from the tank to the carb. I now fuel the tank until it spills a little bit out of the vent. Without removing the fueling line, I close the choke and with the ignition off, flip the prop 4-5 times. Disconnect the fueling line, turn the ignition on and flip with the choke on. It usually pops in a few flips. open the choke and its starts withing 4-5 flips. Nice thing is it sits sometimes over an hour between flights....it will usually start with one flip...no choke. Great little engine! I think my starting problem was that when I removed the fueling line I introduced air into the line. By choking with the fueling line still connected seems to be a simple fix. Would be interesting to see if this works for you too.
Thank you for THE tip, FSFLYER. I will give it a try. I had to read your post twice to catch the tip. With the T being really close to the carb, I can see how by not disconnecting the fueling line that the carb can pull fuel from a much shorter distance instead of sucking air out of the long line from the tank.
coronabob is offline
Old 08-22-2012, 06:07 AM
  #5709
coronabob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: FSFLYER
Old 08-24-2012, 04:42 AM
  #5710
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is it just me, or has this site slowed to a crawl again?  By the double posts, im guessing it aint just me.
acdii is offline
Old 08-24-2012, 08:50 AM
  #5711
Twin_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It NOT just you!
Took almost five minutes for the message to open!
Bill S.
Twin_Flyer is offline
Old 08-24-2012, 12:36 PM
  #5712
microdon2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And I thought it as ME! For seems like two weeks now this site does NOT respond! I've taken to opening the site just to "www.rcuniverse.com" and then going in to Threads and searching for the thread name. RCU - please clean this up!
Old 08-26-2012, 11:11 AM
  #5713
tailskid
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It has been terrible for me also.....
tailskid is offline
Old 09-02-2012, 10:15 AM
  #5714
skyriter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like this forum is no longer active.
I put in a ticket on it and got a reply that they were working on it, but nothing since.
Bruce
skyriter is offline
Old 09-02-2012, 10:29 AM
  #5715
Twin_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They have been working on the issue for months!
its NOT just this forum, but the entire website...
Bill S.
Old 09-02-2012, 12:21 PM
  #5716
tailskid
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It can take a LONG time to load on my phone.....shorter, but still a good minute to log on with my computer.......
tailskid is offline
Old 09-05-2012, 05:11 PM
  #5717
rcguy59
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's my KMP P-38. Twin DLE 20's. Should be ready in a couple of weeks.
rcguy59 is offline
Old 09-08-2012, 07:11 AM
  #5718
WindGap
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My dle 20 sat out for a season waiting for a home, and now that it has one, it won't start.
RCExcel a123 ignition kill switch
A123 2300mah
new spark plug
Could something have gummed stuck from sitting. When I pull the spark plug it smells of fuel, so it's getting fuel.
WindGap is offline
Old 09-08-2012, 08:48 AM
  #5719
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does it try to start when primed? Do you have spark?
ahicks is online now
Old 09-08-2012, 10:21 AM
  #5720
WindGap
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nothing. No pop. Fuel seems to be getting in the cylinder. It does smell of fuel when I pull spark plug. But am not sure if it's enough.
There can only be three things, air, fuel and ignition. How do you check for spark?
WindGap is offline
Old 09-08-2012, 12:03 PM
  #5721
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just pull the plug, insert it far enough into the spark plug boot for the hex section of the plug to touch the metal boot, and turn the engine over. You can go as slow as you want, if everything is working/turned on, it should spark every time the magnet passes under the sensor.
If you have no spark, the first and easiest step is to plug your battery directly into the ignition module to bypass any potential trouble with switches and connections. If you still don't have spark go here, post #24 down near the bottom of the first page, for a comprehensive troubleshooting guide.
http://www.rcuniverse.com/forum/m_8673009/tm.htm
Old 09-08-2012, 03:15 PM
  #5722
WindGap
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Boy that link was invaluable. Totally helped me out. As it turns out, my sensor(magnetic pickup) was fubarred. I got spark when the wire was wiggled one way and not the other. Well, that's unacceptable. Appreciate everyone's help. A new sensor will be ordered shortly. Anywhere in particular/suggestions?
WindGap is offline
Old 09-08-2012, 05:22 PM
  #5723
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tower Hobbies?
http://www3.towerhobbies.com/cgi-bin...?&I=LXANVV&P=Z
Old 09-08-2012, 05:24 PM
  #5724
rcguy59
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ValleyView has the sensors. Just make sure you install it correctly, because if it's upside down, it won't work.
rcguy59 is offline
Old 09-08-2012, 09:59 PM
  #5725
boostoman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys i would like to share my futur DLE20 future build. this is an Epic LT 120 from Nitro planes it seems that it is a great frame for the DLE20 plus it lands really slow. one of the main things that drew me to this plane was the fact that you can really put alot of scale details on the plane. The plane aready comes with fitted lights plus you can setup a really good scale retract setup. and using a pits muffler i wouldnt be butchering the cowling.
there are some vids on youtube of this plane with a DLE20 on it. go check it out.
boostoman is offline
Display Modes
