DLE 20cc Gasser! (Data & Links 1st Post)
Old 09-27-2012, 03:53 PM
  #5751
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Quote:
ORIGINAL: Fortyeight
I'm looking at the one Mile High sells, any opinions? I was originally going with mechanical until reading all this.
Wild guess, but thinking that might be the most popular opti switch available today.
-Al
ahicks is offline
Old 09-27-2012, 04:03 PM
  #5752
Ernie Misner
Ernie Misner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you still use 2 switches with this setup? One for rx and one for ignition? I'm thinking of using 2 LIFE battries from Tower, the 1100mah, very light weight, one for rx and one for ignition.
Ernie
Ernie Misner is offline
Old 09-27-2012, 04:53 PM
  #5753
afjetmech
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ernie Misner
Ernie
Your ingition will be controlled from the transmitter on an unused channel. You can use one battery for both if you get an ignition kill with an IBEC (ingition battery eliminator circuit). I use the one by Syssa. Love It and it saved me from flying around with a stuck throttle until my fuel ran out. The DLE 20's were prone to having the throttle butterfly come loose on the shaft. Mine did just that 2 minutes into my 3rd flight. Was stuck at about half throttle. Flew around a couple times, lined up on final and hit the switch. Floated right in for a perfect dead stick, right when and where I wanted it to.
afjetmech is offline
Old 09-27-2012, 05:04 PM
  #5754
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks a bunch, had been wondering exactly what IBEC stands for.
With the DLE (or Mintor 22cc) should I still use a voltage regulator for ignition when using a 6.6V LIFE battery?
Ernie
Old 09-27-2012, 05:24 PM
  #5755
afjetmech
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most have an adjustable regulator built in. Check this link. http://www.syssaaircraft.net/cart/pc...5&idcategory=2
Old 09-27-2012, 06:45 PM
  #5756
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most IBEC's have adjustable voltage output. An opti switch run on 6.6 volts generally uses a diode on the output side to drop the voltage enough to safely supply the ign. module. Set up this way, you can use an opti switch the same way you would use an IBEC.
ahicks is offline
Old 09-28-2012, 04:31 AM
  #5757
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use the Opti kill shown, and a 5V regulator
Works perfect.
acdii is offline
Old 09-28-2012, 07:44 AM
  #5758
JNorton
JNorton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: nomadmariner
Then there is the occasion when your plane decides to fall out of the sky ie, elevator problem etc. If you are quick enough you can cut the engine before gravity drives it into the earth and hopefully save the motor, and yes this has happened to me.
The idea of a dle 20 running about in the air with no throttle linkage is not good, these things run on the smell of an oily rag and it could take an awful lot of circuits before it cuts out.
20cc gasser versus a 120 glow? not a contest as the gasser has a lot more torque and yes when tuned right with a hot ignition, they will start with just a bump. Imagine the idea of working on your model in the pits with a hot engine?
Hmmm... Jody at the very first post has RPMs given for various props. Very similar to my Enya 120R or what I get with my Saito 125. A glow engine won't run with out the battery connected to the glow driver. UNLESS it's hot - there have been cases where they'll start up. A ignition will not run if the ignition is off, period. Why on earth would you be playing with any engine with the glow connected or the ignition switch on? Justify having an additional solid state switch all you want, but the primary safety circuit is between your ears.
John
JNorton is offline
Old 09-28-2012, 08:19 AM
  #5759
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That primary safety circuit fails fairly often? How many times have you seen hands stuck into props of a running engine for example? That's why back up plans are part of a good plan. Without an opti switch, all you need to do is forget to turn off your flight pack after returning the plane to the pits and you have a plane sitting there with a hot ignition. Bump the switch prepping for flight?
ahicks is offline
Old 09-28-2012, 08:57 AM
  #5760
JNorton
JNorton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay my last post on the subject. The same rational applies to any glow plug motor with an internal glow driver. I do not consider the switch a failure if it's not manually turned off. Guys do what you want - I simply do not consider it necessary on a 20cc motor that is properly set up. All my switches are push pull and all are off pushed in. In all my aircraft there is a voltwatch or other indicator that a switch is left on. Don't forget solid state switches can fail too. This forum is full of posts on the subject.
John
JNorton is offline
Old 09-28-2012, 02:12 PM
  #5761
nomadmariner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe as an idea to move forward there should be a form of optical switch for glow and electric. In other words a separate method for isolating motors with hand eating props. After all plenty of electric flyers have had their body parts chewed and they do not even restrain their planes when testing controls!
Petrol motors may have that extra edge in safety that perhaps should be required in all models as good practice.
nomadmariner is offline
Old 09-28-2012, 03:02 PM
  #5762
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the links to the optical switches, voltage regualtors, etc. guys. Some of us are kinda new to gas and it's really helpful. BTW, shipping is free at Sassya right now I just found out, with an email to them. Their optical switch / regulator (all in one) is a little more expensive but must be top notch. On the other hand the badbradgraphics place's stuff is crazy cheap, no kidding and shipping on the small stuff 3 bucks.
Thanks again, you guys are the best. Must be LOTSA interest in the 20cc gassers nowadays whic is very cool. Maybe more 20cc planes will be in the offering too.
Ernie Misner
Old 09-29-2012, 06:48 AM
  #5763
Fortyeight
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I ran the SAP Ultra IBE (Ignition Battery Eliminator) and Ignition Kill Switch - I'd be able to run one battery, I’d be able to kill ignition from my remote, and ignition would cut out if signal was lost.
This setup would provide all the essentials necessary for safe operation and the minimum weight due to fewer batteries.
Would the Hobbico LiFeSource LiFe 6.6V 2100mAh 10C Receiver U battery pack provide enough energy for flight?
Fortyeight is offline
Old 09-29-2012, 07:40 AM
  #5764
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would think that battery would work, the specs say it will, but have no experience with it myself. The A123 batteries like I'm using are the same/similar technology, and they work fine on my 20 and 30cc stuff in a single batt. setup. I'm not even using half of their capacity for a typical flying session.
That Ultra IBEC is simple, works great, but to toss a less expensive option out, the Rcexl Opti switch will work the same if a diode is installed on the output side of it to drop the voltage enough (.7v) to be safely used to power the ignition module. That setup is about half the cost of the Ultra IBEC? (switches are less than 20. and the diodes are .50 at Radio Shack) -Al
ahicks is offline
Old 09-29-2012, 08:04 AM
  #5765
Fortyeight
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New battery technology is amazing; I just haven’t been able to keep up with all the new varieties available.  I don’t want to buy anything that’s about to be obsolete.
Is the A123 newer than the LiFe? Which way is the battery trend going?
Old 09-29-2012, 12:02 PM
  #5766
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have about 4 years experience with that type of set up, and I have tracked power consumption. This type of set up used 20 mah per minute flying "warbird" style. Smooth passes and minimal control throws. The 20 mah per minute was very consistent. So, if you fly a 10 minute flight, likely you will use 200 mah, which is 10 percent of your capacity. Sounds like you would be okay with the setup. PM me if you need additional help or clarification.
Lifer is online now
Old 09-29-2012, 12:33 PM
  #5767
nomadmariner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can confirm lifer's report as I use the A123 2300mah battery in my cub. Just a single battery works fine and will give a good 6 flights of 10 to 15 minutes.
Old 09-30-2012, 08:10 AM
  #5768
sandyjain
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A123 and LiFe is the ssme thing....A123 is more to do with branding and LiFe is Lithium (Li) Iron (Fe) nano phosphate i.e.the chemistry of the cell.
They are here to stay till an easier to manage technology/ chemistry comes up. Life can be charged at 5C and do not have the exploding/ burning characteristics of LiPo (Lithium Polymer).
LiFe are a tad heavier per mah than LiPo BUT the easier handling more than makes up for that. Moreso they can be used with Rx without BEC as they give 6.6V over 80%+ of their life.This is another fact that makes them better - constant Voltage over 80% of their life.
More details can be found on wikipedia.....
sandyjain is offline
Old 09-30-2012, 08:27 AM
  #5769
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you're interested in coming up to speed regarding the newer type batteries, this might be a good read? (No BS batteries)
http://www.hangtimes.com/weightcompare.html
ahicks is offline
Old 09-30-2012, 10:25 AM
  #5770
Fortyeight
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lots of great help and that was a good read.
Thank you,
Scott
Old 09-30-2012, 06:45 PM
  #5771
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone know how many minutes this engine will run at full throttle on 1 ounce of fuel? I am trying to decide on my tank size.
vertical grimmace is offline
Old 09-30-2012, 11:45 PM
  #5772
nomadmariner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ahicks
Yes nice article puts things into perspective quite well.
Old 10-01-2012, 04:30 AM
  #5773
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not sure on one ounce, but on a 14 ounce tank I can get up to 30 minutes flying time at 1/2 to full throttle.Still breaking in the engine, so I dont fly full throttle all the time.
acdii is offline
Old 10-01-2012, 05:12 AM
  #5774
microdon2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So that's 1/2 an ounce a minute.
microdon2 is offline
Old 10-01-2012, 11:25 AM
  #5775
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds right since an 8oz. tank is more than enough for 20cc flights. Ain't gas nice?
Display Modes
