If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 232 of 275 FirstFirst ... 132182222230231232233234242 ... LastLast
Results 5,776 to 5,800 of 6851
  1. #5776
    vertical grimmace's Avatar
    Join Date
    Mar 2004
    ft collins , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
    Thanks guys.
    Let's just say, they will be satisfied with less. " Ming the Merciless
    BUSA Bro # 13
  2. #5777
    rcguy59's Avatar
    Join Date
    Jul 2008
    tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I finally got to run my DLE 20's today! One fired right up and the other needed the diaphram wetted before it would pump fuel and start. Both started right up on the factory settings which turned out to be pretty close. On the 2nd tank(s), I tached them. One was turning 9300+ and the other was 9400+. The props are 14-10 APC's. Right now I have the idles at 2000 rpm, but they need to be much lower as they still pull pretty hard. Is 9300-9400 rpm too high? I'd hate to blow one of these little guys up. The airplane is a KMP P-38.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    "Never wound a problem. Kill it dead." Clarence "Kelly" Johnson
    "Speed is great, speed works. Where would we be as a species without speed? You know, we'd still be eating mud." Jeremy Clarkson
  3. #5778
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    9400 on new engines, seems high, unloaded may put them past their rev limit. I think 14-10 is too small a prop. Maybe if you went to a 3 blade you would be in the correct RPM range.
    SIG Brotherhood # 3
    Mustang Brotherhood # 6
    Corsair Brotherhood # 86
    Kadet Brotherhood # 24
    http://www.facebook.com/pages/B-17e-...18159428244374
    I don't crash I just land wrong
  4. #5779
    rcguy59's Avatar
    Join Date
    Jul 2008
    tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks. How low of an idle can I reasonably expect?
  5. #5780
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I use an APC 16x8 or 15x10. I'd think a 14x10 is under-propped for this engine.
  6. #5781
    Join Date
    Jul 2011
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi
    16x8 is a better option. Like the others have said.
    BC
  7. #5782
    rcguy59's Avatar
    Join Date
    Jul 2008
    tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks, guys. I'll give it a try.
  8. #5783
    Ernie Misner's Avatar
    Join Date
    Jul 2002
    Tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Did you squirt fuel into the carb to wet the diaphram?
    Thanks, Ernie
  9. #5784
    rcguy59's Avatar
    Join Date
    Jul 2008
    tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I can't get to the intake-side of the carb. I had to cut a hole in the firewall for the carb to go into. That also allowed me to install the tanks from the front. Otherwise, the only access to the inside of the booms and cockpit pod are through the wheel wells. A real PITA. Because the carb is angled, I had to pull the engine to remove the diaphram cover. On this airplane, NOTHING is easy!
  10. #5785
    MetallicaJunkie's Avatar
    Join Date
    Sep 2006
    Donna, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: microdon2
    +1 on a 15x10 ...that will haul butt
    \"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space\" George Aldrich
  11. #5786
    tailskid's Avatar
    Join Date
    Nov 2001
    Tolleson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just flew my H9 Pulse 125 w/ DLE 20 up front all last week....what a sweetie engine! Pulled over 9000 and would ldle at 1900. That is one great combo... I flew it on Wed, Friday and on Saturday I started it three different times with only one flip of the Evolution 16-6. Yesterday it ran just fine but needed to use the choke on the first start. After that one flip and she was off and running!
    We are here on earth to do good unto others. What the others are here for, I have no idea.
    ~ WH Auden
  12. #5787
    Join Date
    Jul 2002
    Tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Awesome tailskid! I loved my smaller Pulse. What's your battery setup? Tank moved back to the CG?
    Thanks, Ernie
  13. #5788
    tailskid's Avatar
    Join Date
    Nov 2001
    Tolleson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have the tank as far back as it will go on the 'tray' and have both nicads up front - and the plane is right on the suggested CG - which means it is nose heavy ....I'm going to move both batteries back and see if I can fly inverted without much down elevator as is now the case. H9 likes to be very conservative on the CG. You have to LOVE that hatch and it's attachment method - good engineering.
    ~ WH Auden
  14. #5789
    Join Date
    Mar 2004
    ft collins , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rcguy59
    Put 16-8 Xoars on them. You will be very happy
    BUSA Bro # 13
  15. #5790
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Had a wreck today and lost the ignition module somewhere. It was still attached when I retrieved the plane, or what was left of it, but dragging it through the corn field I lost it somewhere, so, I need a replacement, so what should I replace it with?  Up until the wing snapped off, the engine ran great, and worked perfect on the 4*120.  This thing went in nose first into hard dirt, but I had killed the ignition well before impact. Anything I need to do to the engine?
    SIG Brotherhood # 3
  16. #5791
    Join Date
    Jul 2002
    Tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gosh, so sorry about loosing the 4*. What do you think happened?
    Tailskid, darn but you got me thinking about a giant pulse too. They still make them, right? How do you like that Dubro? soft mount? Running two batteries huh - what size?
    Thanks, Ernie
  17. #5792
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The right wing snapped off doing mild aerobatics. It was an ARF, so my guess, poorly built. I had already removed the covering and thought I had repaired the wing structure so the wings were solid, but apparently not. Poor construction is my guess. I will know more when I find the other wing. It got too dark to see in the corn field to look for it. Gonna need a new plane to put the gear in. Ijust hope the engine is OK and nothing got bent when it hit the dirt.
    SIG Brotherhood # 3
  18. #5793
    rcguy59's Avatar
    Join Date
    Jul 2008
    tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I planted a DLE30 at over 100 mph when the whole tail blew off of my GP RV-4 during a high-speed pass. The engine was buried past the cylinder and the airframe was pulverized. The DLE came through just fine, as did the ignition. Ordered a new RV-4 the next day. It's amazing the abuse these engines survive, with a bit of luck.
  19. #5794
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wish I could say the same for my ignition module but it is lost, all I have is the pickup harness and the spark plug cable.  I lost the box somewhere between where the plane was discovered and the truck, in the corn field.  That was a big plane, and even with half the fuse smashed, it was still a chore getting it through the corn.  The engine was running great too, and man was I enjoying the flight, just doing lazy rolls and loops, practicing immelmans, split s',  cuban 8's, hammerheads, and not at full throttle either, mostly half throttle.
    My low passes looked good too, the wings appeared stable. I was quite surprised when it snapped off.
    SIG Brotherhood # 3
  20. #5795
    Join Date
    Aug 2008
    Waterford, Mi/Citrus Springs, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: acdii
    Had a wreck today and lost the ignition module somewhere. It was still attached when I retrieved the plane, or what was left of it, but dragging it through the corn field I lost it somewhere, so, I need a replacement, so what should I replace it with?Β* Up until the wing snapped off, the engine ran great, and worked perfect on the 4*120.Β* This thing went in nose first into hard dirt, but I had killed the ignition well before impact. Anything I need to do to the engine?
    Sorry to hear about your plane! Regarding your module, do some shopping. You're looking for a module that fits a CM-6 plug. I would not buy a DLE #3 or #4 (20cc/30cc) module, but anything else is fine, will plug right in.
    Pick the dirt out of the cooling fins and anywhere else you see it and give it a try! I've been pretty lucky after some unfortunate "arrivals" as well.
  21. #5796
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I did kill the ignition before it hit the ground, so the engine was stopped when it hit.  The PITTS muffler has a few dents in it though, but the choke and throttle move smoothly still.  Going to need a new fiber arm for the throttle, it snapped off.
    So this one works? http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXYND5
    SIG Brotherhood # 3
  22. #5797
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Same here - I've "planted" my DLE 20 a couple of times and it came through fine. Pretty strong engines.
  23. #5798
    Join Date
    Jul 2011
    MacleanNew South Wales, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If the prop survived and there is no dirt in the carb, just give the prop shaft a gentle turn and note if their is a bearing problem. If not then run it on the test stand and you should be good.
    β€œIn order to fly, all one must do is simply miss the ground.”
  24. #5799
    Join Date
    Apr 2009
    Whitestone, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    "... if the prop survived ..." - GOOD one!!
  25. #5800
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That one would be perfect, but I'm pretty sure you can stay state side and do better regarding the price? Like here:
    http://www.rcextremepower.net/ignitions.html (one of the more knowledgeable Rcexl guys around, he's also a distributor/warranty center for them)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
