DLE 20cc Gasser! (Data & Links 1st Post)
Old 10-04-2012, 03:17 PM
  #5826
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Quote:
ORIGINAL: Guijs
Acdii, do you mean it will kill the engine, or, it will be "very nice"?Just to be sure!
Ernie Misner, I bought the JTEC muffler just to add a better look to my scale plane! Not sure how much it will help on performance. But I will try to find out!
Very nice. Underpropping would more likely kill the engine. Over rev one and it could go boom.
Quote:
ahicks - I wasn't commenting on the performance of the three-blade prop, just that the engine would not be underpropped. The 14x9 prop would probably produce the same load as a 15x10. But agreed - everything I've read says that three-blade props are not as effecient (due to increased turbulence?) as a two blade.
I'm thinking its the other way around, a 15x9 vs 14x10 would be about the same load. The lower pitch would give higher revs.
As far as fine vs coarse pitch, Im still confuzzled on that. Iam not sure which does what for what in flight, Coarse for take off and power, fine for cruising and economy? Which works best for speed, which gets you going faster? eh, all I know is, the bigger the prop and higher the pitch, the more load it produces on the motor.
On my Kadet LT40, I had wrecked it on a landing where a cross wind caught the wing and flippped it. My bad, was coming in too slow. ANyhow, I had busted the motor ount and could not find a replacement SIG one, but had a Magnum 52, same size as the OS that was on it, and it was on a SIGmount. Iput it on the Kadet after Irepaired it, and got it running and the servo trimmed for it. Tuned it and flew it and noticed it wasn't flying as well as with the OS, it seemed a little slow. Ilanded it and was looking through my props for a 12x6, Ithought I had an 11x7 on it, all I found was my wood 12x8 and an 11x7. Igrabbed the props, went to the plane and discovered I forgot to swap out the prop from the other plane, it was a 12x6. Iput the 11x7 on and took off and bingo, flying like it did with the OS. Larger prop, lower pitch = slower flight, smaller prop, higher pitch= faster flight. <- see confused.
acdii is offline
Old 10-04-2012, 04:15 PM
  #5827
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Think of pitch like the gears in your car. The more pitch the higher the top speed. Not good to take off from a red light in 5th gear though. I do not like high pitch. No more than 8 for me generally. It makes it tough to slow down for landing. I find it best to hang in a 6-8 pitch and then load the engine with diameter from there.
It has been established which props this engine likes. 17-6 thrust or 16-8 for speed.
Diameter is considerably more efficient thrust than pitch.
vertical grimmace is online now
Old 10-04-2012, 04:42 PM
  #5828
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK makes sense now.  That explains why the 16x8 flew the 4* better than the 17x8.  a 17x6 may have done a better job, but I was satisfied with the APC 16x8 I was using.
acdii is offline
Old 10-04-2012, 05:30 PM
  #5829
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ahicks
Ernie - nothing as far as performance, a little different, maybe muted slightly, exhaust note. That's me though, and nothing very scientific for a test one vs. the other.
microdon2 - switch to that 3 bladed prop at the field while 2 blade performance is still fresh in your head. Betting you won't leave the 3 blade on for long. Looks cool, but you take a big performance hit...
microdon - I wrote this in a hurry, addressed this note to you when it was meant for acdii. Apologize for any confusion.
ahicks is online now
Old 10-04-2012, 05:40 PM
  #5830
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: vertical grimmace
Nicely said, I agree. Higher pitch props are also pretty good at blowing control surfaces off 3D types. Not much upside to running over 8" of pitch on those.
Old 10-04-2012, 06:07 PM
  #5831
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a 17x4 APC marked as a 3D prop. so that makes more sense now.
acdii is offline
Old 10-04-2012, 07:56 PM
  #5832
microdon2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, for 3D planes you want wider props with lower pitch, which produce more torque at lower RPM's.
Vertical Grimmace - when you say "Diameter is considerably more efficient thrust than pitch" doesn't that depend on what you want to do? If you want to go fast you choose one gear ratio (as you said). If you want to pull the plane \ car off the line fast you choose a completely different gear. Not sure how you're saying one "gear" is more efficient than another - they're doing very different jobs, and each has their max-torque-pull RPM range. Would you not agree?
microdon2 is offline
Old 10-04-2012, 08:58 PM
  #5833
Ernie Misner
Ernie Misner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Heey, how about that 17x4W APC for 3D profile planes and the 20cc? If indeed that's what it is a W (wide) prop it should be enough load for 3D it seems.
Ernie
Ernie Misner is offline
Old 10-05-2012, 04:42 AM
  #5834
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ernie I think a 20cc would overwhelm that 17x4w. It might work better on a smaller engine? I tached my well broken in DLE at 8700 on an APC 17x6 the other day. Going with less pitch would let the engine rev way too high. What might work better would be if they had something like an 18x4w - assuming you had the prop clearance? 30cc engines love some of those larger (18") "W" series props though...
There's a ton of science regarding props - but there's as much or more trial and error as well? The rules regarding finding more speed differ from those looking for more thrust. Thrust generally does favor "the more the merrier" when it comes to diameter. Consider the size of the props used on an indoor free flight plane (sticks and that clear film?) as an extreme. When it comes to speed though, all that diameter might be viewed as unnecessary drag? Props are just like many other things when it comes to aviation - they're almost always a compromise. -Al
Old 10-05-2012, 08:34 AM
  #5835
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Al. The reason I still might try that 17x4W is that the Wide type APC props load an engine way more that the same diameter and pitch APC in a standard prop. At least with my glow experience so far. My OS 55AX looses about 1,500 rpms when going from a 13x4 to a 13x4W APC. Still, it couldl be under propped like you suggested and that wouldn't be good.
Ernie
Old 10-05-2012, 10:28 AM
  #5836
vertical grimmace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: microdon2
Vertical Grimmace - when you say ''Diameter is considerably more efficient thrust than pitch'' doesn't that depend on what you want to do? If you want to go fast you choose one gear ratio (as you said). If you want to pull the plane \ car off the line fast you choose a completely different gear. Not sure how you're saying one ''gear'' is more efficient than another - they're doing very different jobs, and each has their max-torque-pull RPM range. Would you not agree?
Since we do not have constant speed prop options, we have to settle on a happy medium on prop selection. High pitch props are tough to land without killing the engines. Ask any Pylon racer. It is about compromise.
If you look into the aerodynamics, If I remember right, diameter is 4 time more efficient than pitch. Of course you need pitch. Unless your racing, not as much as most think.
Old 10-05-2012, 02:25 PM
  #5837
SigMan
SigMan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i would like to see a comparison review of the DLE 20cc and the XYZ 20cc engines. im sitting here looking at my new XYZ 20 getting ready to go into my new GP Revolver. looks awesome. will be late winter, early spring B4 i get it together and ready to go. sadly.
SigMan is offline
Old 10-05-2012, 03:57 PM
  #5838
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Sig man, there's a thread I started under gas engines about the xyz 20cc, looking for information. That might be a good place to tell us a little something like where you bought it, how much, what they told you about it in comparison to the DLE 20cc, etc.
Would be much appreciated.
Thanks loads,
Ernie Misner
Old 10-06-2012, 04:45 AM
  #5839
SigMan
SigMan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks Ernie. i'll try that.
SigMan is offline
Old 10-06-2012, 04:18 PM
  #5840
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ahicks, good call on the shaft moving.  I tore the DLE down today, and after getting the back cover and cylinder off, I spun the shaft and thats where I felt the resistance. The hub was stuck on tight, had to pry it off, which was difficult since I didn't want to mar up the case, but finally got it off. I then put the case in the vise, so the shaft was hanging down, and the vise supporting the case, and gave a couple whacks with a brass drift and dead blow hammer and the resistance was gone. Turned smoothly.  I put the engine back together, and then discovered I couldn't turn the crank, the rod pin was hitting the back cover.
I took it all apart again and this time removed the key and drove the shaft out of the case, cleaned everything up and then reassembled the engine again, this time everything went back together smoothly and spins nice and smooth.
Replaced the fuel nipple with some brass tubing. Soldered up some 1/8 tubing inside some 5/32 tubing, put a bulb of solder on the end for the fuel line, gave it as close to a 90* bend that I could so the throttle arm clears, and pressed it into the carb with some lock sealer that I had that is used for locking a seal ring onto crank pulleys, its like red locktite but thicker.
And then I tore into the ignition module. The high voltage lead had been pulled out of the case, so I took my dremel and ground out the epoxy so that I could get to the connection for the center lead, stuck the cable back in, soldered it in place, then soldered the ground of the cable to the case, and sealed it up with 5 minute epoxy.
Now I need to put a test stand together and see if the engine kicks over and runs. The only thing I still need is a new fiber arm for the throttle.
acdii is offline
Old 10-06-2012, 04:33 PM
  #5841
rcguy59
rcguy59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like you're on a roll. A new throttle arm can be made from a large servo horn. I've made several that way.
rcguy59 is offline
Old 10-06-2012, 05:31 PM
  #5842
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, I'll give it a try, I have a few laying around from the Hitec servos I got for the 4* that I am not using.
acdii is offline
Old 10-06-2012, 10:42 PM
  #5843
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow, good progress acdii. Even with all you did with your crank and bearings it seems easier than the motorcycle 2-strokes where the 2 crank halves were pressed onto each side of the crank pin. Then you'd have to use a brass hammer and dial guage to whack the two crank halves straigt with each other. The Yamaha 100cc twin used a "labrinth" seal in the crankcase between the two crankshaft halves. The labrinth seal was aluminum and not rubber, so no drag. Anyone ever seen one?
Ernie Misner
Old 10-07-2012, 04:34 AM
  #5844
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Re: labrinth seal yes, familiar with them. They used those on some early ('70's vintage) snowmobile twins as well. Kawasaki maybe? Holy cow, that was a looong time ago... 100cc Yami was from that same era too?
acdii - that's good news! Nice to hear you at least tried to be "creative" regarding the ign. module too. Hope that goes as well, best of luck!
-Al
Old 10-08-2012, 09:08 AM
  #5845
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, the labrinth seals on the old Yami twin was from the late 60's. Guess no one uses them any more?
Old 10-08-2012, 09:15 AM
  #5846
microdon2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Along with the piston rings I recently received from Frank Bowman he also sends out a sheet with recommendations on how to deal with the reed valves of Chinese-made gassers. From owning the DLE 20 and 30 and having issues with low-idle on both, I'm thinking his recommendations make LOTS of sense. I"m going to be doing this to the DLE 20 soon (along with replacing the ring). Will let you know the results. Instruction sheet from Frank Bowman is attached.
File Type: pdf
Old 10-08-2012, 09:23 AM
  #5847
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, he says the reed blocks need to be cleaned up so the reeds seal well at rest. Makes good sense for a reliable idle.
Right now Tower has the DLE for $215 and free shipping if you are a saver club member. Good deal!
Ernie Misner
Old 10-08-2012, 10:25 AM
  #5848
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hmm $215......    I do need an engine for my Mustang. The DLE was originally for it, but I am not convinced yet that its the right one for it.  I'm thinking more along the lines of a 1.20 4 stroke for it. The DLE just doesnt sound right for the mustang.
acdii is offline
Old 10-08-2012, 10:37 AM
  #5849
microdon2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
acdii - if you want more power go DLE 20 and, for sound, get a JTec Pitts-style muffler.
Old 10-08-2012, 10:49 AM
  #5850
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the DLE20, I just dont like the way it sounds.  A P-51 that sounds like a weedwacker just doesn't thrill me.  The 4 stroke OS though sounds good.  Especially swinging a 3 blade prop.  My friend is using a graupner 3 blade on his P-39 and it sounds wicked.
acdii is offline
Display Modes
