DLE 20cc Gasser! (Data & Links 1st Post)
#6001
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
You dont need the loop when flying, but when you have the plane upside down on a stand to work on it and you have fuel in the tank, it will make a mess when you flip the plane over. Discovered that the hard way and wore gas soaked pants for a day.
#6004
Hey guys, here's one for you. My engine has 1 gallon of fuel through it and I am battling to get it running properly. I have noticed that the low speed needle has a very noticeable bend in it! Is this normal and could it be this causing my reliable idle issues?
thanks
Wes
thanks
Wes
#6005
Pull that needle out and if it is definitely bent replace it ASAP. Yes, sure could be causing your UN reliable idle issues, even sucking air at the needle 0-ring.
#6006
My Feedback: (205)
MI
Well guys I finally got another plane to put my DLE 20 after dumb thumbing the last Extra 260 into the ground[:@]. While setting it up and we all know about how the #4 ignition won't let it go right back to our idle rpm's for a few seconds - right. I've tried the richer lower needle as others have suggested, but not to much avail so....Tried something and it seems to be working at least on the ground and for about 12 practice landings tonight. What I've done after reading in one of the post and remembering exactly what he was talking about. I had experienced the same problem with my racing sleds (snowmobiles)...that by bumping the throttle after letting off would take the engine back to low idle immediately..with that in mind I set up on my Futaba 9c to do the same only with a switch rather than the throttle stick, which worked now and then for me at least..I used the trainer switch to be exact, with it being spring loaded, if one looses their train of thought for a split secong, just by letting go of the switch everything goes back to normal..I went in and to the engine idle window activated it, set the percentage at 10(which was just right for my engine set-up, yours might be more or less of that percetrage rate. Set it to be off when Switch F is in it's normal position, would be activated when holding the switch forward. ...by doing this bumping the switch forward for about the count of ONE moves the trottle servo more to the low or closed position causing the engine to decelerate more, by restricting the gas/air flow..seems to be working so far and I just recieved my new ignition today to replace the #4..might not need it now..will keep everone posted...If anyone here tries this let be know your results if you would please..
#6007
ORIGINAL: Ernie Misner
Thanks Ernie, also for spotting my typo!! Damn predictive text! Will pull the needle and upload a photo for you guys to see.
Cheers
#6008
ORIGINAL: saintcreed
#6009
My Feedback: (10)
Gents... I'm a return noob to RC Warbirds and a first time gasser...
I have a DLE 20 in a BH FW190a and love it. starts easy... idles great... plenty of speed for low passes... sound awesome!
My problem (that even the engine guys are scratching their heads on) is after 8 or 9 minutes of half to 3/4 throttle flying the engine bogs down and cuts. Now I love deadstick practice as much as the next guy but I'd love to land one of these days with the engine running.
I don't think it's a mixture issue... idles great.. transitions to WOT easily... I've never touched any of the screws by the way. but after ahwile in the air you can hear the engine bog down dramatically and then cut after 5 or 6 seconds... no throttle response really.
one of the guys thought it was a fuel tank clunk issue... after taking apart the fuel cell (again) it was fine... someone offered it was a pressure issue but the bleed line is clear...
I think its a heat issue... but don't know how to fix it... there are no extra holes in the cowl except for the one for the exhaust pipe. Someone in the BH FW190a thread said that the builtin vents in the fuse would be enough... (1/2 inch wide and 2 1/2 tall on both sides of the fuse)
should i cut holes in the bottom back of the cowl near the fuse? someone mentioned blocking some of the front cowl (seems counter intuitive)...
as always, i appreciate any info you've got! thanks
BTW.. the melted spinner is the result of the professional assistance from the flightline... he was convinced he could simulate airflow with his starter
#6010
Pull the plug and inspect it immediately after one of those dead sticks. If it is whiteish instead of brown then you're on the right track of overheating for some reason. Any cowling would be suspect. Good news is that if that is the case someone can offer a fix for that.
#6012
Your clearly overheating, been there done that and I can see from your pics that you have no baffling directing air to your head. see thissite for excellent info on baffling
http://www.prme.nl/forum/viewforum.php?f=18Pe really knows his stuff and once you get the proper setup your problem should be solved. Take the cowl off and run it to see how it goes, and you will need to adjust the needles some after a while, you will be surprised how little you turn the needle to change from a lean run to cool run. Good luck and keep us posted on what happens.
#6013
Hopefully you haven't seized it up or scored the cylinder yet if you've been running good oil. It might be a candidate for a new ring though when you get it sorted out. Does the compression still feel good?
#6014
I believe a lot would be improved if you blocked off all the openings in the front of the cowl except for the area directly in front of the cylinder. Additional openings on the bottom of the cowl would be the traditional next step.
#6015
ORIGINAL: sparky4lawndart
#6016
My Feedback: (10)
I'm going to try the baffling (blocking off the cowl except a few spots in front of the cylinder head... I hope the 2.5 X 0.5 inch slots in the fuse on both sides of the cowl will be sufficient for letting the hot air out? Might have to buy a pyrometer this week (any reason to go to harbor freight is a good reason).
Flying without the cowl? didn't think of that... that's weird... seems logical but I'm gonna try the baffling first...
also.. the DLE has been swinging a 16X8 zoar... any thoughts on an APC 15.5X12 4blade... It was on sale and bought it... others have mentioned it in the thread but no real pro's and con's
#6018
My Feedback: (10)
here's the baffling i did... simple balsa sheet cut into pieces, painted black, glued in... I'll dress it up later...
I've also cut up the spinner and put the 4 blade prop on there.
#6019
4-blade on a FW-190?
Apart from scale issues it will load up an already stressed engine. Stick to the 2-blade until you get the cooling issues sorted and once smooth and reliable get a nice 3-blade prop and paint it black.
Nice plane!
Nice plane!
#6020
Your baffling looks good and I'm sure it will help. You can go even further by adding some pieces to create a more direct flow onto the head. Those spokes in the cowl look like they lend themselves to that really well. I agree on the 4 blade prop; too much load on the engine, I have found the 17x6 zoar is the sweet spot on this engine for good tourqe and rpm as was tested back in the begining of this thread. Taking the cowl off is just a way to test if your overheating. Real airplanes use all kinds of baffling to direct cooling air over the engine and it's not always true that you need to have a great big exit hole to solve the issue, it's more important to get air moving directly over the head and then right out the exit area. You can have a large exit area and still overheat because there is turbulence around the exit area that prevents the hot air from being drawn out. This can be solved by creating a small air dam in front of the exit area.
#6021
I'm putting a DLE 20 in a bashed Tiger 60, also raising the engine 1" but ground clearance is the issue. Question, what is shortest prop at what pitch would be a good choice, I have a 14 x 10 and I have'nt bought the gear ( tail dragger ) yet, main gear that is as I need to know the height with 2 & 1/2" wheels. Thanks
#6023
One person used main gear from a large UCanDo I think, nothing fancy just large size aluminum gear. With something like that and really big wheels I don't think you'd have to change the engine mount location. For example I put a Saito 125 on a 60 size Ultra Stick. Just by going to 3 1/2 or 4 inch lightweight foam Dave Brown wheels I was able to run a 16" prop easily on that big Saito. I am not happy with small high pitch props usually; they don't fit my flying style, but maybe yours? but I hate the way they don't want to slow down for landings either.
