If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 243 of 274 FirstFirst ... 143193233241242243244245253 ... LastLast
Results 6,051 to 6,075 of 6835
  1. #6051
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
    Turf tires are out, adding a block under the gear does'nt fair well, the engine has'nt been ran yet so I suppose testing props after break in is in order. I figured some of you have delt with this issue and I was looking for a short cut. There is alot of info on this engine so I'll go back and read more before I do the break in. Thanks all.
  2. #6052
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Short cuts usually wind up as short lives.   Listen to the advice given, it will save you cash down the road.
    SIG Brotherhood # 3
    Mustang Brotherhood # 6
    Corsair Brotherhood # 86
    Kadet Brotherhood # 24
    http://www.facebook.com/pages/B-17e-...18159428244374
    I don't crash I just land wrong
  3. #6053
    Join Date
    Aug 2009
    Newaygo, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    + 1 on that !!!! ACDII
    And dont scemp out on parts
    I all ways try to give my build the best chance I can cutting a corner can cost you a bird !!!
    save a $1.00 and it could cost you $100.00 in the long runor more !!!! My 0.02 R/L
  4. #6054
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just one question regarding DLE20 popped up in my mind. When it comes to glow motor, it's OK to fly it on full-throttle throughout the flight time and I had been doing that like 5 years ago not anymore. What about gas motor, it does not have methanol to cool the motor of, is it OK to fly it continuously on full-throttle and it won't affect the motor? Or do we have to keep making the sporadic changes in throttle like idle to half to 3/4 etc?
    Mody
    It's great2 keep flying invariably. Hitec Aurora9 2.4 GHz, Yak 54-120 XYZ 20, MXS-R RCG 20 (AMA Member)
  5. #6055
    rcguy59's Avatar
    Join Date
    Jul 2008
    tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I fly my DLE's at full-throttle 98% of every flight. They seem to thrive on it. As long as the cooling is adequate, go for it.
    "Never wound a problem. Kill it dead." Clarence "Kelly" Johnson
    "Speed is great, speed works. Where would we be as a species without speed? You know, we'd still be eating mud." Jeremy Clarkson
  6. #6056
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cool,
    Thanks rcguy59, I'd try to do that [8D]
  7. #6057
    Lifer's Avatar
    Join Date
    Aug 2008
    Kansas City, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    armody,
    I've been accused of flying 2-speed engines; full blast and approach speed. Go for it!
    AMA #77967/CD/LM
  8. #6058
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The DLE pretty much has 2 speeds. Once you get past half throttle, it pretty much is running full blast.  The only suggestion is to have telemetry on it to show the head temps in flight. Came with my DX8, so I gave it a shot.
    SIG Brotherhood # 3
  9. #6059
    Join Date
    Nov 2010
    Rocky Mount, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rcguy59
    +1 on that! Been screaming my DLE20 in a Revolver 70 at full throttle for about 2 years now. Occasionly pull it back to half and putt around a couple times then boredom sets in and its back to full throttle until landing time. Chop it to idle on approach and bring it in slow or fast depending entirely on how high Iam when the throttle goes to idle. Using cheap Pro Mix oil from Lowes at 32:1 the whole time. Love this engine/plane combination!!
  10. #6060
    rrengineer's Avatar
    Join Date
    Jul 2004
    San Bernardino, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just got this ignition from Hobby King that is supposed to be for 55CC motors. Just wondering if anyone had ordered this ignition after it was mentioned a while back here in this thread and installed it yet. Just wondering if it will cure the idle "step" using the #4 ignition that came with my DLE 20. For 24 bucks it was worth a shot.
    Mike
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  11. #6061
    Join Date
    Aug 2008
    Waterford, Mi/Citrus Springs, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Assuming that the "idle step" really was causing what's ailing your engine, sure! I'm assuming the spark plug boot is the right size?
  12. #6062
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It means that DLE20 can be run on full-blast and there is gonna be no harm to it, pretty cool Thanks Lifer, acdii, afjetmech!
    The synthetic oil I'm using is Klotz, that's what I found and with this motor I'd continue to use it. Since I'm planning to get another plane & engine, I might use a different synthetic oil or probably the same Klotz, so I do not have to use two different gas cans
    Time for some questions
    1. Once a gallon ran through the motor with Klotz mixed synthetic oil on the motor. Next fuel can be mixed with Red Line or Stihl or Penzzoil, would it make a difference in motor's performance? Yes or No? Is it better to stick with the same oil mix as you started off in the first place?
    I'm also using STA-BIL fuel stabilizer for the same fuel
    http://www.goldeagle.com/brands/stabil/
    2. When we run the motor on the ground either on the stand or installed on the desired plane, why it is said that do not run a lot on the ground is it true or not? Is it OK to run a whole gallon on DLE20 being on the ground? Why is it different running the motor on the ground as compared to flying it, is it due to temperature variations?
    3. How do we know that carb needs cleaning, since DLE20 does not come with Walbro carb. I was also told to take care of some of the part of the carb or clean it before you fly it, I apologize I do not remember what part of carb was that.
    4. Throttle comes with a spring factory fitted why is it advised to remove it?
    5. When would we know it's time to change the plug?
    Guys, those are a lot of questions, and honestly it would take a lot of time to answer that, but a lot of y'all may have gone through all those experiences, since I'm Newbie gasser especially on DLE20 so I'm trying to get as much data as possible
    Thank y'all
    Mody
  13. #6063
    rrengineer's Avatar
    Join Date
    Jul 2004
    San Bernardino, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have not even checked the spark plug boot yet. Just got it in the mail yesterday. Not going to change it out right away. The "idle Step" is really not a big deal, just wanted a back up ignition replacement and this was very cheap.
    Mike
  14. #6064
    Lifer's Avatar
    Join Date
    Aug 2008
    Kansas City, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oil choice is fine, stick with the mfg. recommended percentage.
    Run it in the air after the first tank.
    Clip the tang off the spring, but leave the spring itself there to keep the butterfly in tension.
    Replace the plug with a CM-6. Gap it with an xacto blade.
    Leave the carb alone unless it gives you trouble. Factory needles are a STARTING point, you will need to adjust!
    Read up on the entire DLE 20 thread!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
    AMA #77967/CD/LM
  15. #6065
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mody, many of us are running the DLE 20 required 32:1 mix in everything, even though 40:1 (or less) oil is required in some of the bigger stuff - for the reason you mention - not having to deal with more than one can of fuel. Keeping it simple avoids confusion and the potential to grab the wrong one...and the extra oil run through the bigger ones isn't hurting a thing. Using just one jug also helps keep the fuel fresher. I'm of the notion that a quality oil includes fuel stabilizer, but that's an opinion. I don't use Stabil or anything else in mine and have had no trouble. Your mileage may vary....
    I buy oil off the shelf, wherever it's handy. Anything that says "approved for use in air cooled engines" is good enough for me.
    Running the engine on the ground cannot duplicate the loads or cooling that will be realized in the air. For the same reasons, carb settings cannot be expected to stay the same - ground vs. in flight.
    There was a leave it connected/disconnect it string regarding that spring earlier. MANY opinions stretched across quite a few pages. What I learned from it are there are pretty good arguments to go either way. So, your call. It would appear you can't possibley be wrong!
    You would change the plug or clean the carb when you can't get it running right. Logic would have you check the easy stuff first....
    Stop worrying and asking questions and go fly that thing will ya! -Al
  16. #6066
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    When it comes to oil any 2 stroke rated oil that you get at the auto stores will be fine.  Avoid no name oils, or "specials".
     You can run it in on the ground for a few tanks, but why waste the gas when you can be flying.  You don't need to run it in like a glow, once you have it tuned, which is usually about one tank of gas, it doesnt have the tendency to conk out in flight like a glow does.
    As far as the spring, it puts tension against the servo when open, so you have to keep that in mind, I disconnected it on mine, no sense loading the servo.
    As for the rest, You'll figure it out as you play with it.    Also use the NGK plug.
    SIG Brotherhood # 3
  17. #6067
    Join Date
    Sep 2008
    williamsburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    rrengineer..
    I'm the guy that came up with the HK ignition, been running it now for a month or so, maybe 25 or 30 flights. Working just fine, has vastly improved certain 3D style maneuvers with my Mojo such as harrier landings. high alpha stuff, etc where you need to really work the throttle in the lower RPM ranges. Before I was often fighting that "step".
    Easy change. Comes with the plug for a CM-6, just unplug the old one, plug in the new one. No need to change the sensor.
    The #4 is now the spare!
  18. #6068
    Join Date
    Aug 2002
    hemet , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 20cc Gasser! (Data & Links 1st Post)
    has anyone used theevolution 10cc gas engine yet
  19. #6069
    rcguy59's Avatar
    Join Date
    Jul 2008
    tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    They'll need to release it first.
  20. #6070
    Join Date
    Aug 2009
    Newaygo, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    + 1 on getting the little motor out !!!
    I wonder if there will be 242 pages on it also !!!
    Armody Gas the 20 up and go fly it cant be that hard if it wont start then clean the carb !!!
    I wonder if any of thes people ever cut grass or cut wood ?????
  21. #6071
    Join Date
    Aug 2009
    Muscat, OMAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    are you talking about this engine
    http://hdflyer.com/meridian-10cc-arf...cc-gas-engine/
  22. #6072
    Join Date
    Jun 2009
    Idaho
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got the DLE20 hanging on the front of this Tiger 60 which is being bashed for it. With the gear and 2 3/4" wheels I have 2" of clearance with a 16" prop in the plane position, I think that will be enough but I may go with a little larger wheel.
  23. #6073
    rcguy59's Avatar
    Join Date
    Jul 2008
    tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The problem with the Evo 10cc as I see it is the requirement for 20:1 gas/oil mix. Needle bearings on the rod were a great addition, but the ABC P/L setup is a deal-breaker. With a ringed piston, the oil requirement would be considerably less, possibly even 32:1. I'd love to have a gasser that small, but the thought of yet ANOTHER fuel jug turns me off. As it is, I need one for 30% glow 1/2A's, one for 10% glow, one for 32:1 gas mix and one for kerosene/oil mix for my turbines. A guy's got to draw the line somewhere! Besides, I just can't help it that I like 'em all.
  24. #6074
    Ernie Misner's Avatar
    Join Date
    Jul 2002
    Tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Follow that link and it mentions that the ignition is half the size of most ignition units. Maybe it is setting a new standard there.
  25. #6075
    Join Date
    Jan 2010
    London, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys. I would like to swap out my ignition on my DLE20 (#4) with the standard one from RCEXL. Don't want to fly my warbird with that throttle step and can't seem to tune around it successfully. My question is: how do I set BTDC to 28' ,as the original hall sensor can only be retarded to 37'. I gather I need a hall sensor with longer attachment brackets? Does this come with the standard RCEXL ignition?
    thanks
    Wes
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
