If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 254 of 274 FirstFirst ... 154204244252253254255256264 ... LastLast
Results 6,326 to 6,350 of 6835
  1. #6326
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
    757jonp,
    Thanks for the input. I'd keep ya guys updated on my next flights!
    It's great2 keep flying invariably. Hitec Aurora9 2.4 GHz, Yak 54-120 XYZ 20, MXS-R RCG 20 (AMA Member)
  2. #6327
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guys,
    I forgot to ask y'all about my maiden flight. As I flew my plane at a huge retention pond, I had one nose over while taking off as it has still lots of twigs laying around and slightly taller grass. Prop tip has not broken but the edge has gotten slightly serrated? Prop is Xoar 17X6 beechwood, and I did balance it before I installed it. Do I have to replace the prop or do I use it the way it is. Do you think Vess or Bambula are any good props especially for DLE20, only beechwood ones?
    Mody
  3. #6328
    Join Date
    Aug 2009
    Newaygo, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    DONT use it any more props are cheep body parts not so much !!!
    you have one of the best props going JMO but dont take a chance if you have never seen a prop BLOW up
    it takes only 1 time and you would not be asking usthat !!!! R/L
  4. #6329
    Join Date
    Aug 2008
    Waterford, Mi/Citrus Springs, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mody, without seeing your prop its hard to say? Replacing it is the safe answer for sure...
    That's why I run APC props. I fly from grass (always), sometimes rough grass, and I love screwing around with tail wheel first landings and "Harrier" type approaches. Less than gracefull "arrivals" not that uncommon, pretty regular actually. Wood props simply won't handle that abuse, seldom surviving even one encounter. APC's often go an entire season. Run what you like....
  5. #6330
    Join Date
    Sep 2008
    williamsburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    10-4 on the nylon props for rough duty! I managed the whole season on the same wood prop on the Mojo (on grass), but that was just sheer luck.
  6. #6331
    Ernie Misner's Avatar
    Join Date
    Jul 2002
    Tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    acii, the deposits on your plug are worrisome and could have caused the deadstick. What kind of oil and how much are you running? What kind of gas? I've seen weird deposits in the past from gas with lead in it but that would not be from todays standard pump gas. It hasn't been running way too rich or lean has it?
  7. #6332
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RiverLarry,
    I thought that I should stick with Xoar, no doubt they're great props. For the gas motor I was told by my hobby guy to use APC, but if I'm to use APC, probably I'd go for MAS. In the first place, I went for Xoar, I mistakenly bought Zinger 16X6 or 16X7, which I never used it. I'm gonna keep it for my other motor for break in either DLE20 or XYZ20 or RCGF20. I was told that beechwood prop breaks easily resulting in not damaging the crank of the motor. I stick with Xoar.
    ahicks,
    I have now looked at the prop again, it's barely negligible jagged edges little rough, barely noticeable only upon touching it. So I guess I don't have to freak out anymore since it's barely noticeable. To be on safe side, I'm gonna buy another Xoar 17X6 for back up in case.
    My motor would take time I'm sure as I started off directly with Synthetic oil, not non synthetic oil and I used the same Xoar 17X6 beechwood prop for break in and flying.
    Mody
  8. #6333
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Ernie Misner
    Never had a dead stick with the DLE, had a wing snap off though, which led to a crash, but I had cut ignition long before it struck, so the plug is oil soaked from that. Engine ran great up til then.
    SIG Brotherhood # 3
    Mustang Brotherhood # 6
    Corsair Brotherhood # 86
    Kadet Brotherhood # 24
    http://www.facebook.com/pages/B-17e-...18159428244374
    I don't crash I just land wrong
  9. #6334
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Guys,
    Last Saturday I went to fly my Yak 54 with DLE20 on it. A week ago I already had a maiden on it which I enjoyed very much. As I spoke to y'all about tweaking the LSN and HSN of the motor. I had made few changes and following things happened on that day within total 3 flights despite I had a plan to have at least 5 to 6 flights on it.
    The first flight was good, and at the time of landing, I could not get the plane to land slow as the RPM was at least 2,400 + or -, I had hard time landing the plane, but I managed to land it.
    On second flight, I decided to tweak on both LSN and HSN. I turned both of them to the close position and turned both 1/8 turn on both of it, I did not get the right rpm on full throttle. I may have turned it to 2/8 then I was getting a good rpm and sound was telling me it's running right and idle seemed to be running OK. It flew well, and when time came to land the plane, same issue, idle was high, despite I did do some adjustments on my Aurora 9 TX with EPA and throttle adjustments, the plane would come down very hot and I had missed 3 to 4 landings and I had to fly the plane away, finally I made the final approach for landing and ended up land pretty distant which ended up breaking the prop, which was Xoar 17X6 on it. I thought as unfortunately I did not have a back prop except for Zinger 16X6 which is no doubt a crappy prop, but I guess good for bench run or something. As I wanted to fly, I reluctantly changed the prop and installed Zinger 16X6 on it which was there. My LHS is always outta items which I need most so, I have to wait for a week.
    Anyway I prepared for the 3rd flight and I knew I had to tweak both HSN and LSN. I started the motor and as I advanced it to full throttle, it would bog down and try to quit, I would pull the stick back and on half to 3/4 of throttle I was getting the sound of WOT and I adjusted the HSN which didn't seem to be a good idea but I got the right sound for the right rpm, and idle was seemingly working OK at that time. I took the plane off, and after 6 minutes, It started sputter on half throttle and on high too, then I felt that now motor is struggle so hard to run and plane started losing the altitude and I kinda knew that it may be overly rich on HSN, as I thought to land it and struggled it to keep it flying and close to the landing approach, here comes the important part DLE20 QUIT IN THE AIR/ DEAD STICK, Can anyone explain it to me? Yak 54 ain't good in gliding, a dead stick makes this plane a dead weight up in there however, I managed to land it and barely itty bitty damaged the landing gear which I've fixed already as Yak 54 120 from Nitro planes didn't go good job on landing gear and the bottom of the plate where landing gear is screwed bolted.
    After that I didn't even try to fly it, I saw other people's flying and I called it a day. One of the guy who turned out to be best flier and happens to own a LHS, he said I'd recommend you to use Vess props, Xoar props are OK, since he sells Vess so he was recommending that.
    Now when it comes to DLE20 which props are best for it. Xoar, Vess, Bambula all beechwood or APC, MAS nylon props. Why the idle is not getting stable as I want to, upon cranking up the motor it seems to be working fine, but after one or two advancement of throttle, it seems after even 10+ seconds it does not slow it down?
    What's wrong with it? I'd appreciate y'all detailed explanations.
    Mody
  10. #6335
    Join Date
    Sep 2008
    williamsburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mody... Glad you didn't have any major damage. I've had exactly the same problem you're having, you're in the landing pattern and the dang thing will not slow down! What's going on is you're experiencing the same situation that folks have been talking about with that unusual timing curve on the ignition. On the ground the engine responds to the throttle normally, but in the air it's a different ballgame. When you hold the plane on the ground the prop is constantly under a load, but when in the air it unloads, and when you bring the engine down to idle,(while flying) the speed of the plane through the air is now unloading (windmilling) even the prop even further. Full advance timing is somewhere around 2500-3000 rpm, and you need to get under that to achieve a normal idle. Depending on the airframe and you're skllls, it can be a booger to get a nice...normal...landing. But you adapt to it once you understand what's happening.
    I had one plane that weighed 14 lbs that the only way I could get a good "normal" landing was to really stretch out the landing glide on it allowing the speed to bleed off enough to get it to idle for a landing...tricky at best. Sometimes it would get to the point where it would suddenly come down to full idle before you really wanted it to, resulting in a rough landing if you weren't careful.
    That Yak should be a "floater" and should glide forever if you have the CG setup right. If you've got it setup nose heavy, it'll tend to land "hot" and that'll aggravate the problem.
    Regardless of what others say, no amount of fiddling with the carb will eliminate this characteristic of this engine...
  11. #6336
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Some of the videos, please bear with me. These videos were shot by a flier at the field used HTC One X phone.
    https://www.youtube.com/watch?v=DSBgmKgNPqY
    https://www.youtube.com/watch?v=_ssReu8r73A
    https://www.youtube.com/watch?v=FAkoNG_8W9U
    https://www.youtube.com/watch?v=ikVuM1aJSXE
  12. #6337
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    757jonp,
    Thanks for the reply. One thing I'd like to ask you which prop are you using on you DLE20. This time should I go with Vess? As I already asked my LHS to get me two Xoar 17X6 props, or at least I'd get one. My LHS does not sell Vess props. About the idle timing, I'd have to play with it again once' I've gotten the prop, I'd balance it and put it on the motor. My flying skills are pretty good as those people saw me flying they say it, and pretty impressed with it. CG is absolutely perfect, it was done by my mentor and I found not a single problem with it neither nose heavy nor tail heavy, it's perfect. I have fixed the landing gear, and since it can take little rough landing but abuse of it would easily pop 'em out. In all my landings I landing the plane very smoothly and Yak 54 does come hot but with correct landing approach it lands sweet.
    Any thoughts about props? Vess or continue with Xoar, I don't wanna use APC.
    Mody
  13. #6338
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Please excuse my typos and some grammatical mistakes, since I type so fast I just look at the screen sometimes hand and mind coordination gets outta sync
  14. #6339
    Lifer's Avatar
    Join Date
    Aug 2008
    Kansas City, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sounds kinda lean to me. Sorry about the troubles you are having.
    AMA #77967/CD/LM
  15. #6340
    Guys, go back to page 246. Take another look at my posts and videos...
    My planes now idle down when I ask them while in the air.. and it is not just me... I have customers that I sell the Rcexl standard ignition to with warbirds and other non 3D planes that say it makes a difference.
    One tip, when using the standard ignition that comes with the DLE 20... bring it back to what you consider your normal idle on downwind, on base and final try doing a mild cross control slip... This will force the airframe to slow down and at some point, the ignition timing curve will allow then engine to reach idle... try it up high if necessary to see the reaction, I dont make the turn from base to final while still in the slip... so I am in and out of the slip bleeding off endergy from the decent and the higher rpm...I always stop my side slip before I get to within one wingspan of the ground... it depends on the plane though really...
    Before I swapped my ignitions and re timed, I had a 7 pound profile plane that was way too light for this engine idled up and this is where I got to figures out some of this stuff..
    Vess are good props, I use the Xoar though.. Either is perfect, use what you like for availability or price..
    I Am WrongWayRC
  16. #6341
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I started with MAS 16x8, then switched to an APC on mine. It ran better with the APC.  Tried a XOAR, but since it was 17" it flew too slow.   A lot of it depends on the plane too. I have flown it on a 4*120, and a deweyville. Dont recommend  it on that last plane, it may look like a big enough plane for it, but it cant handle the power. It is more of a 70 size plane.
    It flew the 4* nicely, but never had enough flights in it to test various props when the wing snapped off.   I have a new one built and just need to complete the motor installation and it will be ready to fly.
    SIG Brotherhood # 3
  17. #6342
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mody, if it quit, it's probably too lean. The fact you can't get it to idle down in flight is saying the same thing. When adjusting the LS needle, don't try to get the idle real smooth/even sounding - that's almost always lean. If it's right the idle should be kind of lumpy/uneven.
    When you get tired of breaking props, the APC works fine. Regarding the "bent crank" stories, if you manage to hit hard enough to bend a crank, it's not going to make much difference what prop you had on it.....
  18. #6343
    Join Date
    Jan 2011
    Capron, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: ahicks
    That is so true. Even an APC or MAS will snap before bending a crank, APC moreso than the MAS. Snapped several so far and all my cranks still crank.
    SIG Brotherhood # 3
  19. #6344
    Join Date
    Jan 2010
    London, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So I could basically switch to a RCEXEL ignition and leave my timing as factory at 35'? Will this do away with the weird throttle step and hang before idle?
    Wes
    ORIGINAL: ahicks
    Bottom line, no need to mess with it when switching to a different module - unless you're concerned about the 28 vs. 35 degree timing - which is a totally different issue. Has nothing to do with the ign. module swap.
  20. #6345
    Join Date
    Sep 2008
    williamsburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wesjon... Basically if you want the engine to act "normal", changing out the ignition seems to be the only way to do it. I checked the timing on both of mine and found it to be set at 28-30 degrees and that's where I'm running them.
    Cheapest way to do it I found was to order from Hobby King, around $30 or so. (last time I looked about a month ago it was backordered, it is a Rcexel unit)
  21. #6346
    Join Date
    Sep 2008
    williamsburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Her ya go...this will do it just fine!
    http://www.hobbyking.com/hobbyking/s...s_Engines.html
  22. #6347
    Join Date
    Jan 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks! Will check it out. Are the arms on the supplied hall sensor long enough to set it at 28 - 30'?
  23. #6348
    Join Date
    Sep 2008
    williamsburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I didn't even change the sensor, just checked the timing while I was changing the ignition unit. There is room for adjustment though. Remember, the ignition fires as the sensor LEAVES the magnet. I think a lot of folks get confused about that resulting in mistiming their engines by several degrees.
  24. #6349
    Join Date
    Aug 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: wesjon
    Wes
    You know, this question is one I have a tough time with, because the answer is yes and no? So many of us have run into this problem - which isn't helped a bit by this timing issue, admittedly - but a lot of guys (most?) have been able to adjust it out by running the low end on the rich side.
    So to explain, closing the throttle (eliminating the fuel that WAS helping to cool the engine) is what starts this chain of events. A hot 2 stroke with no load on it (prop is free wheeling as the plane slows) can "run away", requiring no ignition to run (that fact takes the module right out of the picture, no?). "Running away" often is what is happening here to some degree, but this isn't unique to this engine at all. Any 2 stoke can do it? Usually on our plane engines it's something temporary. After a few seconds it cools down, and drops back down to the idle speed we're expecting. The 2 things to help minimize the potential for this issue are an idle speed as low as reasonably possible (something under about 1900 here?) and a mixture rich enough to help cool the engine quickly when the throttle is closed (that's the big one).
    So yes, you sure can make the engine a LOT less sensitive to the issue by swapping to an ign. module that doesn't have a step in it, but no, you may still not cure the "hang" problem completely? Hope that helps. -Al
  25. #6350
    armody's Avatar
    Join Date
    Aug 2005
    Magnolia, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lifer, Richard, acdii, ahicks
    What I've understood so far is LSN is too lean. ahicks, you're right I turned the LSN to that point where I found out that now idle is smooth and at some point it also started getting uneven or lumpy and then I tried to adjust it thru my TX's throttle trim. So I'm gonna make sure that it's not lean I'd turn LSN it to 1/8 and I'd see if it works fine. As far as ignition is concerned, I'm not sure how to change it, if it's just a breeze I may
    About the props, I appreciate your opinion, either Xoar, Vess, Menz, Bambula, APC, MAS, these props would behave different way but won't make much of a difference. As far as 17 size is concerned, it's pretty fast for me, at the moment, I wanna fly my plane not with a zapping speed. I'd get the Xoar prop as soon as it gets to my LHS. Does replacing the ignition of DLE20 make noticeable difference in timing?
    Mody
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
