DLE 20cc Gasser! (Data & Links 1st Post)
#777
My Feedback: (44)
TN
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
if i am not mistaken, i saw a .52 gas engine from magnum engines, that is approx 8cc if i figure right. by the way i got my DLE 20 FROM TH TODAY AND CRANKED IT UP, SWEET AND SMOOTH.
#778
You guys might be interested in seeing the Revolver 70 with a DLE-20 video. Part of his comments on Youtube are quoted below.
[link=http://www.youtube.com/watch?v=BllA1VnwsSg&feature=related]DLE20cc and Revolver 70[/link]
Plane all up weight is 10.17 pounds. Top RPM is 9900 and the thrust is 11.22 pounds. Fuel tank size is 16oz and i can fly for 15 min and come down with a little over half full.
#779
My Feedback: (14)
ORIGINAL: Richard D Bahmann aka/Wrongway
Well whatever you do....dont go over to the Florida Huckfest this weekend.....there are about 40 of the planes from 30 to 42 percent size flying this setup.....no issues...
ORIGINAL: NM2K
I wasn't worried about current consumption. I'm worried about RFI from the ignition system getting back into the receiver via the shared circuitry. Folks tend to over estimate 2.4 GHz rigs ability to reject RFI, IMHO.
Ed Cregger
Ed Cregger
It is very hard to argue with success. I'll get over it.
Ed Cregger
#780
My Feedback: (14)
ORIGINAL: Phoenex
Thanks for the tip. That Revolver sure is pretty and the engine runs like a watch. It even sounds like a sporty glow engine.
Ed Cregger
#781
My Feedback: (7)
IN
ORIGINAL: krayzc-RCU
yeah i see it needs a curve sort of on or off if not
I tried altering geometry, but had it worse.
I'll fine tune the curve after several flights.
Regardless, this is a very spirited 20cc engine!!!
#782
IN
I've been working on getting the DLE 20 and Syssa 30cc engines tuned where I like. The Syssa was nearly perfect out of the box and, in fact, I didn't even have to change the short throttle arm out to get more throttle resolution.
The DLE 20 is another beast. It has what I'm told is a normal on/off lower throttle range where the throttle is very sensitive at the low end. I've changed the throttle arm out to a 3/4" long arm from WrongWayRC and that helped. I've tuned the lower end and have been playing with throttle curves as well to help this. The throttle curves have helped the most and I still have a lot more that i can adjust here (this coming weekend I hope). I will also change over to Redline synthetic oil the next flights at the recommended ratios (30:1 for the DLE 20, 40:1 or 50:1 for the Syssa). I know a bit of this can be prop related as well and I continue to try new props.
My question is why are two-stroke gassers, in general, sensitive on the low end throttle range? Something to do with the carbs, reed valves, timing? Are there any solutions such as intake manifolds, velocity stacks, etc. that can resolve this w/o the use of throttle curves (many radios still don't have TC's)?
#783
ORIGINAL: guinnb
#785
WY
The carb sensitivity is simple, to much carb. Its a matter of how much air an engine needs at any RPM. With a large carb the % of air flow change is huge at very small throttle openings.
Its all based on the mfg's having to playing the numbers (HP) game of power at WOT, mines bigger than yours, so they can sell more engines.
On several engine I've gone to a smaller carb, lost a 100 rpm or so at WOT, but gained a much more linear response
#786
IN
ORIGINAL: tkg
Thanks Tkg. Makes sense. I also got the following response which helps me understand this a bit better:
"It really has to do with the archaic carbs that we are using. The carbs are designed to run balls out. Lower throttle response is touchy because the cross sectional area of the throat opening of a butterfly valve has the most change per angle of rotation at the initial opening, and conversely the least change at the high end.
For a linear response we need the exact opposite.
You can do a little mechanical expo in the system to fix this, by setting up the servo arm so that it has the least linear movement on the low throttle area and maximum movement at the high end."
So, I guess we are limited by the butterfly valve type carbs used on these engines. I'll keep working on the linkage and throttle curves.....
#787
My Feedback: (41)
ORIGINAL: guinnb
''It really has to do with the archaic carbs that we are using. The carbs are designed to run balls out. Lower throttle response is touchy because the cross sectional area of the throat opening of a butterfly valve has the most change per angle of rotation at the initial opening, and conversely the least change at the high end.
You can do a little mechanical expo in the system to fix this, by setting up the servo arm so that it has the least linear movement on the low throttle area and maximum movement at the high end.''
ORIGINAL: tkg
#788
My Feedback: (19)
ORIGINAL: tkg
Good engines all .... you just have to understand them. Had I kept the Syssa, I was considering using a smaller carb to make it run more to my liking, The DLE came along, runs the way I want it to run out of the box so I never looked back.
#789
IN
Joe,
Tx for the diagram. That explains why the Syssa was so much smoother and linear on the throttle than my DLE 20cc...it's in the linkages. The Syssa setup has the throttle in a different place and the linkages are much more like the diagram. I'll rework the DLE and get it better!
#790
Yes, that is a nice diagram and should explain the geometry of throttle setup quite effectively for a lot of people. Good post!
AV8TOR
P.S. However, one time I made a throttle arm that was .8940" long instead of the .8939", and it didn't work well at all. (Just kidding. .8939"?)
AV8TOR
#791
My Feedback: (41)
ORIGINAL: av8tor1977
AV8TOR
P.S. However, one time I made a throttle arm that was .8940'' long instead of the .8939'', and it didn't work well at all. (Just kidding. .8939''?)
AV8TOR
#793
NH
Getting close to flying it, weather permitting:
It weighs 4-5 oz less than the RCGF 20cc, even with the aluminum engine mounts.
#794
My Feedback: (44)
CO
Hey guys.....Looking for some advice. I have a Goldberg Ultimate 120 ARF and am considering the DLE 20cc for this plane. It should weigh around 9 to 9.5 plounds when finished. I fly at 5500 ft altitude. My last Ultimate was powered with a YS 120 FS and weighed 10.5 pounds (Heavy I know, but it was real strong). I have seen the videos of the DLE 20 flying a 10 pound plane and it looked good. Just not sure what altitude they were flying at. I am looking for input from people that have flown with this engine. The local flyers here think that the DLE 20 won't have enough power but there isn't anyone using this engine here yet. Any input would be great.
Thanks in advance.
Thanks in advance.
#799
My Feedback: (44)
CO
That's the prop I was thinking of trying. If the DLE 20 will fly an Untimate 120 like a YS 120 FS I will be happy. I haven't flown planes for about 3 years, been playing with helis. I want to get back to planes and the Ultimate is the airframe that I have. It is framed up and ready for an engine.
Thanks so much for your help.
#800
My Feedback: (14)
You expect an equal displacement (1.20) gas engine to produce the same power as a YS 1.20? Nope, it doesn't work that way. Gasoline/petrol as a fuel produces less energy than alcohol/nitro fuel. That is why Jody recommends the 30cc engine over the 20cc engine.
Ed Cregger
Ed Cregger
