DLE 20cc Gasser! (Data & Links 1st Post)
#1978
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
ORIGINAL: skillet92
Great planes is coming out with a Stuka JU 87!!! I found the plane for my DLE 20!
#1979
My Feedback: (7)
IN
ORIGINAL: vertical grimmace
Where did you see this? They already discontinued one, are they bringing the same plane back? The old one looked like crap. Hopefully they started over. The Stuka to get is the ESM right now.
There seems to be several others from doing a Google search, from a 1.20 size (discontinued) to TBM 38-50cc size.
Which one are you referring to?
Gota link to it?
#1980
My Feedback: (7)
IN
ORIGINAL: SkyPilot101
Can't find it on Tower or GP, How about a link to the new Stuka!
I found it in 3 seconds.....
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXZW76&P=7]Stuka JU 87....[/link]
Take note;
REQUIRES: Engine: .61-.75 (10-12.5cc)(2-stroke) with standard muffler
OR .91 (15cc)(4-stroke) with standard muffler
Might fit if the cowl isn't used.....but I doubt it. Looks far to narrow.
#1981
Can't find it on Tower? Post the link please.
Sorry, not used to how links are posted here yet!
three seconds, you are just too good Jim. Thanks - Mike
#1984
AZ
ORIGINAL: skillet92
#1986
ORIGINAL: cahusker
Was this a Goldberg Ultimate? Got some pics of the install?
#1987
MI
high-torque OS Max Surpass 4-strokes.
Adjustable 60 to 120 size engine mount.
Q. Wouldn't that put it into the dle 20 possibility range? (might have to slant the engine or cut cowl a bit though)
#1989
My Feedback: (7)
IN
ORIGINAL: nute12
I have a DP ultimate i am going to convert, i want it to 3d well. will the 20 be enough? im ready to pull the trigger on a 30, but, if a 20 will do it.
If you're referring to the 1.20 size, then go with the DLE30, not this one.
I've owned both, and still have the .46 size model.
The 1.20 I had, had a Saito 1.50 4-stroke in it. Very spirited, but no good
for hovering.
#1990
My Feedback: (7)
IN
ORIGINAL: litterbug
[img][/img]
[img][/img]
You'd be very limited in how you might angle any mount.
IF you somehow did mount this DLE20cc, then you'd very likely have to really butcher the cowl.
A JBA .15 cc gas would be a better fit.
#1991
My Feedback: (7)
IN
You're welcome!
#1992
My Feedback: (42)
NJ
Opto kill switches are always a good idea for safety. There's an even better alternative in the form of the Tech-Aero Ultra IBECthat is very lightweight (0.6 oz), has an opto kill switch capability built in and also eliminates the need for a separate ignition battery and switch. The weight savings are considerable.
www.tech-aero.net
www.tech-aero.net
#1993
My Feedback: (7)
IN
ORIGINAL: NJRCFLYER2
#1994
I'm using the [link=http://www.valleyviewrc.com/42-Percent%20Products%20Opto%20Gas%20Kill%20Switch.ht m]42% Opto Kill Switch[/link]. I don't have a seperate battery for the ignition. I'm running the plane and ignition off of one A123 battery with two diodes wired in series to the ignition to drop the voltage in the 4.9-5.1v range. I put six flights on it Friday and it worked great.
#1995
WI
Well it flies! My Reactor Bipe
21 degrees out winds were 2-5mph. After a brief warm up it was time to fly. Take off was uneventful taking is kind of slow. It easily climbed to a mistake or two high and started to do some trimming. Form the original setup with the Saito 91 it took two clicks of down elevator and one of right aileron and that was it! I was using a 16x8 prop spinning at 8400 and idle at 1720rpm. In level flight this is to fast for this plane and I will go to a 17X6 on next flights. Over all flying was not much different, for 15oz heavier. Wing loading is around 15 which is good because It floats in on landing. Landing speed will be slower with the other prop, I was used to about a 10 foot roll out this was about 20. After fling this combination, I would recommend this to anybody wanting a small gasser! More flights to come but probably with skis as it beginning to feel like winter is coming!
#1997
Opto kill switches are always a good idea for safety. There's an even better alternative in the form of the Tech-Aero Ultra IBEC that is very lightweight (0.6 oz), has an opto kill switch capability built in and also eliminates the need for a separate ignition battery and switch. The weight savings are considerable.
www.tech-aero.net
www.tech-aero.net
I have a new, never mounted, still in plastic, 42% opto kill switch (from VV) I'm not going to use available reasonable. If interested, please pm.
#1998
My Feedback: (7)
IN
ORIGINAL: steinywi
Well it flies!
Well it flies!
Not all following might remember.
Need more photos, especially of the DLE20cc installation!
#2000
My Feedback: (42)
NJ
ORIGINAL: ahicks
I went this route too. The link you have leads to what appears to be an identical unit sold by Syssa - currently on sale for about 10.00 less than the price shown in your link?
www.tech-aero.net
www.tech-aero.net
