Length of Time Fuel Stays Fresh
TX
How long will 2 gallons of fuel in a 5 gallon plastic can stay good, if stored in an temperature controlled environment? I have a ZDZ 80 that is running slightly rough (missing every +/-5 seconds at 1/4-1/2 throttle), but noticed the fuel I'm using was mixed on 9/04/09, almost one year ago. I figure it definitely could cause an issue, correct? (I leaned it, but the missing did not improve and made the idle rough and hard to start.)
WA
RE: Length of Time Fuel Stays Fresh
I figure that any fuel in an opened container should NOT be stored more that a few months. Gas does go bad over the winter.
TX
Thanks for the responses. The fuel in question is now slated for the weedeater. Bought new gas tonight and will hopefully give it a test tomorrow.
Fuel can go bad fast if container is not airtight. Do not buy only the amount you will use up right away. Buy fresh & search for good gas in the first place....some is crap or next to it in west Mich Smooth Landings Capt,n
NC
ORIGINAL: captinjohn
How long will 2 gallons of fuel in a 5 gallon plastic can stay good . . .
I keep a one gallon can for the field and a two gallon can to mix in or divy up with assorted chainsaws, tiller, snowblower and an outboard. They all get the same mix except when I am breaking in an engine. Keeps things fresh.
