MVVS has?
I have one, the 35cc Red Head Gasser with the same muffler, but I think mine is newer, and that Carb is different than mine, is that the 26cc engine ?
the 35cc is a strong engine, it will turn a Zinger 20X8 over 7600, and a 3W 20X8 at 7250 tuned for flight, and pull a heavy 15 pound, 82" span GeeBee Y straight up rather well, an acrobatic plane of this size should be a pond lighter than my GeeBee was, a 21X6 or 5 would be better for a big Cub or some other high wing,
Jim
Jim
My Feedback: (9)
Jim I'm not sure what size it is. Just looking at the physical size of the head it's in the 1.20 range. But that's only a guess. I lost by best flying bud a while back and I just recently cleaned out his shop. This was in there. I don't remember him ever bringing this to the flying site so I am in the dark with any knowledge about it.
Selling in the forums is against RCU policy but you can PM or email me if you have any interest. [email protected]
Thanks for your input. The MVVS glow engines I've seen were real screamers. I figured the gasser was the same.
David
David
David, I just measured my 35 for you, here they are for you
bottom of the Case to the top of the head Fins... 5&3/4 inches,,, measured at the back of the engine..
Cylinder Head diameter... 2&3/4 inches,
Crank Shaft Length.. just over 2&1/2 inches, measured from the Case, NOT the Prop Drive
Carb Number.. WT561 (450),
as I compare your Carb to mine, I think your engine is the 35cc,,, you should keep it, it's a very good engine, and if you update it with a newer CH Ignition it will even be a better engine.
BTW, after that engine has sat a while, I had found that you should power up it's Ignition and let it set a while before trying to start it, maybe 3, 4 or 5 minutes or so.
Jim
Jim
My Feedback: (9)
Wasp it looks like this gasser might be smaller than yours. For starts the cylinder head is 2-1/2" and the top of head to bottom of crankcase is just over 5". If I compare it to the 30cc on the MVVS website my cylinder is the same diameter. If I recal yours is 1/4 bigger. If I was a little smarter I would have checked the size of the prop on it but that's no guaranty that prop was flown on it. The Walbro carb has these markings. WT 481D 313.
I'm going to advertise it as a 30cc with the appropriate disclosure and try and sell it. I already have a spare DLE35RE that I really like so funding a new bird seams more logical.
yee-up, they dropped the 26 and now make a 30cc,, but it should say 30 on the side of the head
MVVS 30 SP IFS
see the Dimensions here
http://www.mvvs.cz/docMVVS/MVVS30.pdf
Jim
MVVS 30 SP IFS
Jim
