ZDZ60-can I use penzoil aircooled?
Reply
Old 09-04-2010, 12:24 PM
flyerdave
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ZDZ60-can I use penzoil aircooled?
Just got this engine and the previous owner has been using bel ray @ 50:1 with mid grade gas. Just wondering if I use penzoil air cooled, will this be as good. Also, I was told that ZDZ's liked 91 octane better than 87 or 89 because of higher compression ratios. Is this correct? Thanks
flyerdave is offline
Old 09-04-2010, 04:35 PM
flyinrazrback
flyinrazrback's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ZDZ60-can I use penzoil aircooled?
Pennzoil will be just fine. If I remember correctly ZDZ does not recommend any leaner ratios than 40:1, at least that is what I remember from my ZDZ days. Yes the ZDZ's are a bit higher compression so I would use premium, but that is just me.
flyinrazrback is offline
Old 09-04-2010, 04:41 PM
ec121
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a ZDZ80. I run it on 40/1 Pennzoil 91/93 octane(whichever I can get). No problems. I just use the same gas on all my gassers,( 26cc to 85 cc) and let the loose ends drag.
ec121 is offline
Old 09-04-2010, 04:53 PM
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you change to Pennzoil ,find the for"air cooled" engine type. Not the outboard. You can mix it 32-1 for more power & protection. Remember to retune your engine after changing oil brands or ratios. Let it run for a bit and get new fuel in...old fuel out. Then tune. Capt,n
captinjohn is offline
Old 09-04-2010, 04:57 PM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is suprising how many switch oils, ratios and even props but keep the same old engine tune.
Karol
karolh is offline
Old 09-04-2010, 05:20 PM
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Karol
I know what you mean about that retunning. Did it get kinda wind near you the last few days? Capt,n
Old 09-04-2010, 09:57 PM
jack19345
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Please explain how an engine internals can tell what is being used to cool it? Have asked this question many times with no answers that were definitive.
Regards
jack19345 is offline
Old 09-04-2010, 10:42 PM
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not what cools it - but how cool?
w8ye is offline
Old 09-04-2010, 10:55 PM
Tired Old Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Feeling arguementative again Jack? We both know an engine is cooled a multitude of ways. It doesn't care how so much as how well or how quickly. Oil carries btu's out the the exhaust, along with all that nasty wear and carbon stuff. More oil passing through an engine carries more btu's. Now oils designed for air cooled engines break down at higher temperatures than oils designed for water cooled engines. Water cooled engines depend more on a water jacket for engine cooling than an oil mixed with te gasoline.
As for altering tune, oils have different viscousities and differnt combustability so they affect the tune. Of course a change in oil ratio would affect the state of tune.
Tired Old Man is offline
Old 09-04-2010, 11:39 PM
jack19345
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No arguement, Just asked a question, Assume, from your reply, an engine does not know how its being cooled, which must be the correct answer. Thanks for the input.
Cheers
Old 09-05-2010, 07:10 AM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: captinjohn
Karol
Yes it did Capt,n but was not quite as bad as was predicted.
Karol
karolh is offline
Old 09-05-2010, 10:49 AM
Kweasel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jack19345
Regards
It not about how its being cooled but all about the peak temperature of the head and piston. Outboards dont get hot enough to vaporize the oil so they use an ashless detergent. Aircooled engines often get hot enough to vaporize the oil on the combustion chamber, piston face, and ring lands. Particles are added to "aircooled" oil that form ash after the oil vaporizes. The ash that is left behind keeps carbon from sticking to the surfaces. Aircooled oil also use lighter base so it tends to produce a dry exhaust soot where outboard oil makes a greasy mess. You will see high performance watercooled engines, like snow machines specifying aircooled oil. Marketeers are forced to do the best they can with simple words.
Kweasel is offline
Reply
Display Modes
