G-38 Plug in engine case
My Feedback: (23)
I could not figure out why my G-38 was acting up when it always ran perfect!!! Had a dead stick and it woud not start. I pulled the cowl off and was checking the fuel lines. I then noticed the plug in the crank case was missing. It looks like 10mm is it pipe thread. I have a 10mm bolt in iot right now but I did not want to over tighten it. Can I get a plug any where that will fit it. Lucky find and a nice safe dead stick1
RE: G-38 Plug in engine case
Is it in the top of the crankcase or the bottom?
If it is in the top - maybe you are missing a sparkplug
Ok - sorry, I have no idea what the actual thread is.
Maybe it is the option takeoff for a pulse tap for smoke or another type of carb. losing it would cause your cylinder base pressure to go away and thus no transfer of fuel/air mix to the piston top. Perhaps the G-38 parts breakdown schematic will give you the thread of the plug.
Regards, Richard
Regards, Richard
My Feedback: (16)
http://www.horizonhobby.com/Products...D=ZEN312013510 $4.95 case plug
There's a gasket that goes under it http://www.horizonhobby.com/Products...D=ZEN313013520 $.99
In the second picture, you can see where it goes
Insure that the bolt is not so long that it interferes with the crankshaft counterweight. Use locking and sealing compound as others have said.
Or, get a smoke kit and make smoke!
Regards, Richard
Regards, Richard
