Zenoah G38 coil
Hey Guys
I need an ignition coil for a Zenoah G38. If anyone has one they don't need I would be real interested. Thanks Ron |
RE: Zenoah G38 coil
RE: Zenoah G38 coil
You can use your existing spark plug boot and spark plug connector on this new coil
RE: Zenoah G38 coil
Or check with Ralph here on the groups, He has done a lot of conversions and probably has a few laying around.
Milton |
RE: Zenoah G38 coil
Yup :D
RE: Zenoah G38 coil
Can I use the one from my 55 Chevy?
RE: Zenoah G38 coil
Go for itT.o.m. you got my blessing on that set-up!http://www.rcuniverse.com/forum/js/f.../thumbs_up.gif
RE: Zenoah G38 coil
Can some one tell me how to install the cap and spring on a G38. Do the barbs on the spring go through the insulation of the plug wire? Then do I just push it through the back of the cap? Will a heat gun make pushing the spring through the plug cap easier?
RE: Zenoah G38 coil
It works best to run the plug wire all the way through the cap and out the plug end.
The insert the connector into the wire in the proper orientation to connect with the spark plug Then slip the wire with connector back inside the cap while seating the connector in the top of the cap |
RE: Zenoah G38 coil
Man do I feel dumb, All these years I have been using electric lub and pushing them in from the other end. LOL
Milton |
RE: Zenoah G38 coil
I use spit instead of electric lube. Wire pulling soap works well but I usually don't have it near me. Silicone lube is hard to get off your hands.
They can be done either way |
RE: Zenoah G38 coil
Crisco makes for a fair wire pull grease.
RE: Zenoah G38 coil
WD40
RE: Zenoah G38 coil
Skip1320
Dang! got there too late it haas been sold, but thanks for the info. Who is Ralph? Anyone else have any leads? Thanks Ron |
RE: Zenoah G38 coil
Ralph is the guy who posted just before your last post - Antique - PM him
RE: Zenoah G38 coil
Could call him Ralph-tique....the engine man!http://www.rcuniverse.com/forum/js/f.../thumbs_up.gif
RE: Zenoah G38 coil
Thanks captinjohn
Ron |
I know this is old thread... trying to figure out my G38. Plug wire came out of the coil... anyone have pics/tips on fixing it? not sure if it’s the same as discussed above and thought I’d ask before I break my coil by fooling with it blindly... thanks in advance! |
