Rcexl Tach
Has anyone had issues with the Rcexl Tach when connected to the rpm output signal wire on a DLE 20 ignition?I've only had this set up for 2 months and right out of the box the tach just reads zero's all the time (flashing or moving across). If I hook the tach right into the Hall sensor line with a Y harness it works fine. The instructions claims something to the effect of this telling that there is RF interference between the ignition and the tach. UMMMM, as far as I can tell the DLE ignitions are made by Rcexl and that RPM lead is meant for the Rcexl tach. Why doesn't it work? Or am I missing something? (Like "Do Not Remove the Throttle return spring"..... ooooops).
Broncoflyer |
RE: Rcexl Tach
also see it on my DLE 20 Ignition and that unit only. Don't know the answer to the question but confirm I have the same issue.<div>On the RCEXL Ign's fitted to my Mintors, the same tach works perfect. No issues.</div><div>
</div><div>Tried a different RCEXL tach, same problem. Something wonky with those #4 ignitions.</div> |
RE: Rcexl Tach
Yep, mine works sometimes, and then goes wonky, depends on how fast the engine is running too.
RE: Rcexl Tach
And so indicates some amount of radio interference.
