RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Gas Engines (http://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Rcexl for ZENOAH GT-80 (http://www.rcuniverse.com/forum/gas-engines-142/11360850-rcexl-zenoah-gt-80-a.html)
Speedy-Gonzales 01-07-2013 06:25 PM
When converting the ZENOAH GT-80 to Rcexl ignition can the stock sparkplugs be downsized to CM-6's and still retain good performance. I am assuming all you have to do is put CM-6 boots/caps on the leads and thread reducers in the heads? I am wondering if the CM-6 plugs will reach into the combustion chamber to the correct depth for good ignition and/or if the compression ratio will be compromised to any significance.
I need to lose a little width between plug caps so I can keep completely inside cowl. All I need is about a 1/4".
Speedy-Gonzales
Truckracer 01-07-2013 07:00 PM
RE: Rcexl for ZENOAH GT-80
You can probably get the 1/4" you need by downsizing to the BPMR6F plugs with their associates slightly smaller caps. These plugs have the 5/8" hex compared to the normal 3/4" hex and they are shorter than the normal GT-80 plugs. Yes, I have seen the CM-6 plugs used but I have no experience with them in this engine.
Tony Hallo 01-08-2013 03:24 AM
I converted mine to CM 6 plugs and ran fine but really if you are looking for ultimate performace, you might want to look at other options. The other issue I have with the GT80 is the amount of fuel it spits out. After 1 season my airframe needed redone, I replace the engine with a D&B 5.1.
captinjohn 01-08-2013 05:21 AM
Speedy, how are you doing on the Kavan 50cc twin conversion? Thanks, Capt,n
Speedy-Gonzales 01-08-2013 02:00 PM
Capt'n,
I didn't know I was doing a conversion on a Kavan 50cc!!!!! Enlighten me............
How did your walbro WT540 work for you?
Truckracer 01-08-2013 02:39 PM
Quote:
ORIGINAL: Tony Hallo
Yes, they do spit! I always thought a long velocity stack on the carb would contain the spit but never tried one.
Speedy-Gonzales 01-08-2013 02:47 PM
The spitting or "reguritation" as I call it...... can this be a sign off too much back pressure from a restrictive muffler system?
Truckracer 01-08-2013 02:59 PM
Quote:
ORIGINAL: Speedy-Gonzales
The spitting or ''reguritation'' as I call it...... can this be a sign off too much back pressure from a restrictive muffler system?
Don't know! None of my exhausts were overly restrictive so I don't think that was the case for my engines. I just considered it normal for a piston ported engine. All piston ported engines do it to some degree depending on the intake timing.
Speedy-Gonzales 01-08-2013 03:09 PM
I'll tell you what.......I would much rather deal with a little fuel in my cowl than have a set of reeds go bad. I think the easiest solution to carb regurgitation is to clean your engine and cowl area after every flying session.
My ZDZ's spit fuel and my Webra Bully's spit fuel.
My glow racing engines spit fuel.
Conclusion......I would rather have an engine that "spits" rather than have one "puke"! :)
Tony Hallo 01-08-2013 03:37 PM
1 Attachment(s)
The problem with the GT80 is that it spits right on the firewall, doesnt take long to soak the airframe.
w8ye 01-08-2013 04:51 PM
There msay be a problem with too much piston clearance on the intake side of one of the pistons?
The pistons of piston ported engines seem to wear a lot at the lower edge of the skirt on the intake side and if you run the piston until this area gets too thin, the skirt will breakoff.
tkg 01-08-2013 04:59 PM
Your turning it to slow. Regardless of the noise issue the engine is ported to run at a certain rpm.
Speedy-Gonzales 01-08-2013 05:20 PM
Quote:
ORIGINAL: w8ye
I believe this is a condition even with NEW engines right out of the box.
The Ghost 01-08-2013 06:25 PM
Why not just seal the ariframe with epoxy like we used to do. I seal mine with a coat of polyester resin. It stops or slows down any problems.
Cheers
Speedy-Gonzales 01-08-2013 06:44 PM
Agreed! I'll go for that.
captinjohn 01-08-2013 07:00 PM
Capt'n,
Yup....wrong guy...it was a Galves in another forum. Sorry about that. The engine that was going to get the WT 540 got pushed back ...maybe next summer, Capt,n
w8ye 01-08-2013 07:12 PM
Quote:
ORIGINAL: w8ye
TKG says, you are not letting the enine turn up the rpm it is supposed to.
I guess I'm guilty of that too as I fly around half throttle most of the time.
apalsson 01-08-2013 08:15 PM
Tony, have you had a look at the alignment of the metering valve?
A metering valve that is too open (sits too high) often leads to the carb spitting fuel
Scota4570 01-08-2013 09:32 PM
Most of my conversion engines spit back out the carb to some extent. I play with them on a test stand regurarly and do not like my hand covered in stinky gasoline. I have found, adding a velocity stack will cure it. I make mine out of conduit of aluminum tube as needed. If you make it long enough it will stop the spitting up. It looks like you could drill a hole in the firewall box to allow the stack in. Make the hole significantly larger than the stack. Drill other holes in the side of the box to let air in. If you have something in the box it obviously won't work.
Tony Hallo 01-09-2013 03:11 AM
Quote:
ORIGINAL: w8ye
Quote:
ORIGINAL: w8ye
This is the reason this engine is only useful in racing!
Tony Hallo 01-09-2013 03:14 AM
Quote:
ORIGINAL: The Ghost
Cheers
I beleive slows down is more correct here,I findit impossible to seal, the bolt holes are the first to show problems.
Tony Hallo 01-09-2013 03:15 AM
Quote:
ORIGINAL: apalsson
The stock carb and the newly rebuilt SDC80 did the same thing. I used the W gauge to set the height.
mrdhud 01-12-2013 09:22 AM
Hello all,
I have a question about the GT80. Mine is vary hard to prim the carb with the choke closed it take about 25 turns of the prop to get fuel to the carb. If I cover the carb with my thumb it primes vary fast so why does the choke have that small area ground out of it?
BarracudaHockey 01-12-2013 01:05 PM
Mine pops in 5 or 6 flips, so either your choke plate isn't seating or you're sucking air somewhere.
Speedy-Gonzales 01-12-2013 02:02 PM
Can you run any size plug cap on a Rcexl ignition module? As far as I know you can but the smaller CM-6 plugs require a inline resistor right off the end of the plug lead since the CM-6 is not a resistor type plug. Other than that I am thinking the modules will work on any size plug? yes / no ?
I have a guy ( will not name names here ) who is telling me I will have to send my engine and ignition to him for the plug cap conversion which I think is pure BS. [:'(]
