RE: yeah, it's another what starter thread.
nice work anyways. this is the same thing I am shooting for as well , not going
to carry around a huge flight box anymore. I even went as far as going back to the hand crank on the fuel bottle seems to be working great and fills faster :D |
To tell the truth I use a few different kinds of fuels and end up hand cranking most of mine. I just have the one electric for the most common fuel 15 %
Dennis |
Sometimes you can find small metal project boxes that you can modify and fit your batteries and other stuff inside. You just have to bend up a few brackets so you can screw it to the ends of your starter and then to the box. http://www.boss-enclosures.com/Enclo...cast_and_Metal
Cool Thanks
Excellent starter. Turns my Saito 220FS over with no sweat.
I can see what you did with the small box under from the link but
how were the front and rear brackets made, machined ? |
O K you got me !!!! Do you have a PRINT on your system if so P/M Me
Or some better pic. R/L |
Went ahead and got this one.. http://www.swgiantscalemodels.com/el...-starters.html for $85.00 shipped (6.1 gear)
same one on tail dragger is $119.00 shipped. http://www.taildraggerrc.com/eme-gas...cessories.html ya gatta scrool down to view it. The guy at this place http://pacaeromodel.com/FieldEquipme...erPanel/PP.htm Does not answer my emails, I called him he says he is not shure if he has any PAM-1002B's or not was supposed to call back yesterday and never did. that starter is made in China as well. but only cost $59.00 (3.1) gear Thanks so much for all your help guys! Jeff |
I've been use the Dynatron/Makita setup for years. It works great and has been problem free. When the others are gone the Dynatron lives on!
http://www.afineredgemfg.com/ |
It kind of looks like Pac Aero is going out of business and just selling off stock. I have one of the 3:1 starters. It was (a little) low on power starting 30cc engines so I began using it with 22 volts. Then I tried starting a 36cc four stroke with it the other day and it wouldn't turn it over. I finally burned up the brush holder trying.... I have no false illusions about finding parts for it; ain't gonna happen. I looked high and low for the silicone inserts for it's odd size (2") cone. Finally found them at Miller Products for 33 bucks plus shipping!
I wouldn't buy one of those again. The starter I am using right now is out of an electric scooter/motorcycle. So far I am impressed with it. I wanted to see if it would work well first and it does, so now I'm going to make a nice handle and switch assembly for it. It even has left hand threads on the shaft which helps keep the cone nut tight. AV8TOR |
So if a starters says 12 to 18 volts I take it that 19.8 volts will fry it?
was thinking of 2 9.9 volts in series to much? Or just go with two 7.2 's 14.4 to be on the safe side? Or two 6.6 volts at 13.2 volts? am I looking for 2 c , 3c or what I am confused now LOL The "C" means how many cells correct? Thanks, |
I did find this bad boy LOL 19.8
http://www.hobbyking.com/hobbyking/s...arehouse_.html |
Awwww maybe one battery @ 16.4 volts ? (4200) LiFe
http://www.hobbyking.com/hobbyking/s...arehouse_.html AND 13.2 in one battery http://www.hobbyking.com/hobbyking/s...dproduct=26054 |
ORIGINAL: Ace Dude I've been use the Dynatron/Makita setup for years. It works great and has been problem free. When the others are gone the Dynatron lives on! http://www.afineredgemfg.com/ |
1 Attachment(s)
ORIGINAL: Cougar-RCU Went ahead and got this one.. http://www.swgiantscalemodels.com/el...-starters.html for $85.00 shipped (6.1 gear) same one on tail dragger is $119.00 shipped. Jeff Here are a couple photos of how I attach the batteries to the starter. Each 3 cell Li-Po is set-up the same. I simply invert the Dean's plug of one battery and install a shorted Dean's male plug between both battery plugs, in essence making a 6S battery |
And yet another great Idea :D
ORIGINAL: Cougar-RCU So if a starters says 12 to 18 volts I take it that 19.8 volts will fry it? was thinking of 2 9.9 volts in series to much? Or just go with two 7.2 's 14.4 to be on the safe side? Or two 6.6 volts at 13.2 volts? am I looking for 2 c , 3c or what I am confused now LOL The ''C'' means how many cells correct? Thanks, AV8TOR |
Thank You !
