RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Gas Engines (http://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Any problem with Mintor22 (http://www.rcuniverse.com/forum/gas-engines-142/11380856-any-problem-mintor22.html)
okinox 01-23-2013 01:39 AM
<span style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(245, 245, 255);">Hello;</span><br style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(245, 245, 255);" /><span style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(245, 245, 255);">I bought a Mintor22. I like to know if anyone has had a problem with the engine.</span><br style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(245, 245, 255);" /><span style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(245, 245, 255);">I appreciate your answers</span><br style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(245, 245, 255);" /><span style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(245, 245, 255);">Kind regards.</span>http://www.rcuniverse.com/forum/js/f.../thumbs_up.gif
karolh 01-23-2013 06:27 AM
RE: Any problem with Mintor22
Sent you a PM.
Karol
Charley 01-26-2013 05:23 PM
Quote:
ORIGINAL: karolh
Sent you a PM.
Karol
This bodes ill....
CR
karolh 01-26-2013 06:28 PM
Quote:
ORIGINAL: Charley
Quote:
ORIGINAL: karolh
Sent you a PM.
Karol
This bodes ill....
CR
Not really
Karol
Ernie Misner 01-28-2013 10:39 PM
I think he means we'd like to see what you said in the P.M. for educational purposes.
karolh 01-30-2013 07:56 AM
Quote:
ORIGINAL: Ernie Misner
Ok for what it's worth here it is.
" Okinox, the M22 is a real marvel of engineering and machining and is as beautiful on the inside as it is on the outside. That said, a few of the earlier models were supplied with slightly undersized pistons and rings of questionable quality which caused a low compression problem.
Several complaints from disatisfied customers forced Mintor to take a hard look at their operations and based on their findings they took the decision to suspend all manufacturing and restructure their operations with greater emphasis on processes and Quality Control. If you purchased your engine recently then I believe you have nothing to worry about. Much more information on the Mintor 22 is available from an on going discussion on the F***** **** site, so check it out."
Karol
captinjohn 01-30-2013 01:33 PM
Hi Karol &amp; Ernie. Tis Capt,n John here. Yes take a look see on the FG site. I am sure most others do. http://www.rcuniverse.com/forum/js/f...wink_smile.gif
okinox 01-30-2013 03:16 PM
1 Attachment(s)
Received&iexcl;&iexcl;&iexcl;
Granpooba 01-30-2013 03:34 PM
Port machining does not appear very quality oriented in my poor eye sight. :)
okinox 01-30-2013 03:49 PM
Correct the cylinder seems not fine grinding.<div>Do not know much about mechanics but fails to convince me.</div>
bcchi 01-30-2013 10:11 PM
Quote:
ORIGINAL: Granpooba
Not poor eyesite,looks like it was done by a hand grinder.
BC
okinox 01-31-2013 04:42 AM
<div>Concerning the internal engine polished'm a little scared because it's the first time I see a bad cylinder polished.</div><div>Could polish better internally what interesting. I think I mention that mechanics do not know much, but my cousin is a mechanic and I'm sick of seeing motors inside.</div><div>Not if the shooting refine that.</div><div>Well I have been lucky to meet this morning to a shareholder of club buddy Castellar is, this gentleman has been foreman of the Mercedes for several years. He says he has touched 2T racing engines and the same grinding, not to worry.</div><div>In the shoot rotating refine shirt.
No problem with the engine running perfect wrath.</div><div>My old boss said if you know of one thing it is best to keep quiet.</div><div>Slds.</div>
AJsToyz 01-31-2013 06:09 AM
The whole cylinder remarks are funny to say the least. The DL50 ran very well and had one of the worst looking cylinders when it hit the market yet no one complained. ;)
okinox 01-31-2013 06:20 AM
<span style="font-family: Arial;">Pardon for my english indian translator.I was a fool not to learn English.</span>
captinjohn 01-31-2013 06:37 AM
1 Attachment(s)
Mintor 22cc engine.
Whistling Death 01-31-2013 06:54 AM
Quote:
ORIGINAL: AJsToyz
Because nobody expected a cheap Chinese engine to be flawless. For Mintor to take the time to CNC machine the whole engine and the muffler but not finish the cylinder is very odd.
okinox 01-31-2013 07:13 AM
Will the nickaasil that covers everything. It does not seem quite right to me either.
AJsToyz 01-31-2013 09:26 AM
Quote:
ORIGINAL: captinjohn
Mintor 22cc engine.
This cylinder looks fine, I know this engine runs good!
TimBle 01-31-2013 11:14 AM
I can't see what the problem is?
okinox 01-31-2013 12:03 PM
The engine has not rolled. I do not see what the problem according to a good mechanic and have seen them and not spend anything.
Ernie Misner 01-31-2013 12:04 PM
Nice pictures Capt'n. In the first one it shows nicely the finger or open porting on the two ports opposite from the exhaust. That would give those ports more flow area for sure.
toolmaker7341 01-31-2013 01:37 PM
Needs a new ring. It's not round not even close to sealing and there is no gap (no wall tension)
TimBle 01-31-2013 02:10 PM
AND YOU CAN TELL THIS HOW?
captinjohn 01-31-2013 02:22 PM
Actually the ring had a lot of outward tension. Also a big end gap (a place for compression too leak) and one area of the surface of the ring seemed to be void of contact...maybe caused when the ring was finished up.
TimBle 01-31-2013 02:56 PM
and how pray can you tell that.....?
