RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Gas Engines (http://www.rcuniverse.com/forum/gas-engines-142/)
-   -   maloney engine??? (http://www.rcuniverse.com/forum/gas-engines-142/1160305-maloney-engine.html)
eyalu540 09-25-2003 05:51 AM
maloney engine???
hi
has anybody heard about this company (maloney),
and give me details of 35 cc engine??
Hobbsy 09-25-2003 07:12 AM
RE: maloney engine???
If you're talking about the Maloney 125, I have one, it turns a 15x8 at around 7,200. It is fairly heavy and needs to be started with a starter unless you put an electronic ignition on it, which I did. It will however run a really long time on a 16 oz tank. They also made a 100 which was one cubic inch and the 125 is one and a quarter cubic inch disp.
Antique 09-25-2003 09:05 AM
The plastic block under the carb tends to leak..If you have trouble drawing fuel take the block off and sand both sides on a flat surface..Be careful, the material is soft and will strip easily...
Unless they made a larger one, the Maloney 125 is about 20 cc.....
Hobbsy 09-25-2003 09:55 PM
Ralph, so far mine has not leaked and I lucked out as it came with a round piston ring. It has great compression, some came with oval shaped rings that took forever to seat.
Antique 09-25-2003 11:39 PM
The few I had here had out of round cylinders...A few passes on the Sunnen hone fixed it, round and straight within .0001 :)
Hobbsy 09-26-2003 06:59 AM
I guess if you tried to wear in an oval shaped cylinder it would then be wore out.:) I have thought a lot about puting a Davis Diesel head on mine and running it with out the flywheel but some say the flywheel partly balances the crank. Mine came with the key in the flywheel being too tall and making the flywheel wobble.
Frank C. Bowman 11-06-2003 01:27 PM
I have new piston rings for this engine + over 200 more model engine rings. Email for details. Thanks Frank Bowman
frankbowman@mylifeline.net
gadix 07-04-2004 06:17 AM
eyal shalom
please call me regarding the maloney engine.
thx
gadi.
054-5952320
[8D]
gadix 07-04-2004 06:18 AM
hi and shalom from israel.
do u know the manufacturer, maloney, web site address, if any?
thx
Antique 07-04-2004 10:16 AM
Made by a company in Taiwan or Korea No web site...Imported by Jim Goad when he owned ISC International..Haven't been available (or even made) for many years....Same company made the Horner twin, also extinct....:D
Hobbsy 07-04-2004 11:35 PM
They were made in Korea and imported by John Maloney of World Engines.
Texastbird 07-05-2004 04:09 AM
I picked up a 125 at a swap meet and it starts right up. But it surges when I try to lean out the mixture. Any guesses on what I could try. Running a 15X6 MA on it. Thanks.
Hobbsy 07-05-2004 08:07 AM
John Maloney only used a 15x8 for all his developement work on the 125, it is a 7,000 rpm engine, you may be turning it too fast.
thamby0612 11-13-2008 06:00 PM
Hi, i have a meloney 100 that is nib there is none on ebay what would it be worth to someone on here? make offers thanks, i dont post here much so if you could email me thamby0612@gmail.com if you wish i will sell it to you on ebay so you will know iam not trying you or any thing.
flyoz 09-10-2010 08:33 PM
1 Attachment(s)
Cant believe it.
I recently converted my Maloney 125 to Electronic ign (Thanks Hobbsy for some advice) yesterday I pulled an old RCM mag out and found an engine report from Clarence Lee re the Maloney 125.
Just in case any one seeks some literature I have posted it here :D
Texastbird 09-11-2010 11:03 AM
Could you give me an idea of what you did to convert to elctronic igniton?
flyoz 09-12-2010 12:32 AM
Yep. I removed the rear flywheel it Prizes off ie straight out and has a small semicirle key in shaft.
Then I rempurchased this http://www.hobbyking.com/hobbyking/s...idProduct=6292 Plus a sensor pickup elsewhere same site a Lipo Battery and Voltage reg to keep it at the required 6V max and a tiny rare earth magnet
I drilled an 1/8th hole in the prop waher/base aluminium boss on the shaft and epoxied the magnet in flush.
The sensor can be flipped over in its plastic holder to get the right Mahgnetic pole.
The sensor is mounted so it is just over the magnet. When the shaft and magnet rotate the sensor is activated and initiates the spark.
You need to figure 26 Degrees BTC (I yhink) to find wher to mount the sensor an magnet. see http://www.rcextremepower.net/ignitions.html
The sensor can be adj a s bit each way with the 2 mounting screws
To Set up the spark angle see http://www.youtube.com/watch?v=GBXFpxWg7vY
All done :D
93octane 09-12-2010 09:43 AM
Quote:
ORIGINAL: flyoz
All done :D
I have 9 of these engines! I like them, yes they are a bit heavy..but with a few internal mods and some lightening they run excellent!! with stock ignition or aftermarket cdi...can you post some pics of your conversion? thanks:D
Texastbird 09-12-2010 11:34 AM
So it runs ok with the flywheel removed? That is probably a lot of weight gone with the coil too. I already have an ignition module I think will work, I just need to find some of the little magnets.
93octane 09-12-2010 02:32 PM
Quote:
ORIGINAL: Texastbird
Yes sir runs just fine..spools up alittle quicker saves abunch of weight..radio shack has the rare earth magnets 1/8 in diameter...they work fine...
appy2day 11-17-2010 12:05 PM
Nice to find this thread on the Maloney engines. I have a few of these and some spare parts. The weight has kept them off my planes, but the CDI conversion looks
like the answer. I'll have to order some ignition parts and give it a try. Any pictures of the converted engines?
Happy Flying,
appy
Duayne P 01-04-2011 08:14 PM
I have one of these engines and I will post pics as soon as I can get my camera back. I bought the ignition from syssa and I also bought a new and better piston ring. It has awsone compresion and runnns like a champ. I payed under $200 for the engine and all the mods. WELL WORTH THE MONEY. I would love to get more of them.
rcnats 01-10-2011 12:30 PM
I had a Maloney 125 that I converted to diesel (Bob Davis, Davis Diesel) and the engine became lighter (no magneto) and it turned an 18x6 prop. Sold it...should have kept it [&o].
STUKA BARRY 01-10-2011 01:31 PM
I purchased one way back in 1985 along with the first shipment of Model Tech Dragon Ladies. The engine is heavy, but ran like a sewing machine. It never let me down. It did require an electric starter, but once it started, it did'nt stop. Very fuel efficeint too just not a powerful engine. Its been along time, but I think I got the whole package from Jim Goad for $200. The Dragon Lady was an awesome flying plane. I'd luv to have that one back.
rightname 01-31-2012 08:54 PM
I have a Maloney 100 that my father bought new many years ago. It has only been run for a while on a test stand. Any offers?
