Os 15cc gas/glow
Hi all, I just got the os 15cc ggt, Im planning on putting this engine on my u can do 3d, Do this engine runs well inverted? Thanks!
From what i have seen in our club. Put it on a test stand inverted. When you find it does not work use a different engine. A DLE 20CC WILL WORK. The OS days are gone. the same way as Satio.
I love the DLE20 and own two of them. Have also owned the u can do. It would be very difficult to install the 20 in that airframe. Even if you did shoehorn it in there, you’d still struggle to find a home for the ignition module in the narrow fuselage. In this rare case, I’d stick with a glo engine in that airframe. |
