Fuji 32
Some rpm numbers on two Fuji 32 conversions..Weight 3 lbs 6 oz..
Fuel 100LL, Amsoil 100-1 Temp 72 Altitude 6800 No muffler on one, a Bennett on the other. 18-6W APC 8000 18-8 APC 7500 18-8 Mejzlik 7600 18-6 Mejzlik 8500 20-8 Zinger 6200 Fixed timing, no problem hand starting, idling about 1400...:D The two engines were within 100 rpm on all props.... |
RE: Fuji 32
Did you mix the Amsoil at 100:1 or 80:1?
RE: Fuji 32
100-1
RE: Fuji 32
fuji 32 a walbro carb wt 407 18/6 pk prop 7800
new fuji 32 b walbro wt 690 same prop 7100 runs teribule in mid range think they have gone back-wards 737 |
RE: Fuji 32
My PK props routinely turn less rpm than the others, but may pull as well or better...The size of the carb should have no effect on rpm, as most are bigger than they need to be anyway...Except for the dinky carbs on some of the weedeaters...:D
