RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Gas Engines (http://www.rcuniverse.com/forum/gas-engines-142/)
-   -   zenoah g-62 w/electronic ignition (http://www.rcuniverse.com/forum/gas-engines-142/4476597-zenoah-g-62-w-electronic-ignition.html)
jake1 07-08-2006 08:30 AM
Moving-up to my first gas engine. What ideas/experiences/opinions will you share with me about purchasing a G-62 converted to an electronic ignition system.
davewallace 07-08-2006 09:08 AM
RE: zenoah g-62 w/electronic ignition
Jake,
If you get one fully moded by Ralph at RCIGN ignitions it will be lighter and easy starting.
Dave
GregG7 07-08-2006 10:52 AM
I agree with Dave. I am very happy with my G62 converted to electronic ignitinon by Ralph at RCIgnitions. It is about 1.5 lbs lighter than my other G62 with a spring starter. It starts very easy, has lower vibration levels at idle and runs great.
Greg
RTK 07-08-2006 01:04 PM
Yep,, Give Ralph a call @ http://rcignitions.com/ For about $150 dollars more you will have a better starting and lighter engine.
TIGITRIGHT 08-11-2006 11:01 PM
1 Attachment(s)
You could also do it yourself with a kit from Roy Sholl at http://cncengines.com
It replaces the stock heavy rotor with a lighter one.Has mounting bracket for hal switch and S&S 9600 elontronic ignition with built in advance.He also makes his own plug cap (cnc)aluminum.
RTK 08-12-2006 02:01 PM
TIGITRIGHT-- Ralph doesn't charge much more than that DIY kit and he removes more weight to boot.
TIGITRIGHT 08-12-2006 03:30 PM
Ralph uses the origenal zenoah rotor.How do you figure thats lighter than a drilled out billet rotor that Roy makes.Also,Does Ralph include the origenal Zenoah coil (the heavy one)?Roys entire unit weighs 4 oz.,,,,,,,,,,,,,,Noway dude.:eek:
Read post #50 in this thread link \|/
http://www.rcuniverse.com/forum/m_45..._2/key_/tm.htm
RTK 08-12-2006 04:06 PM
On mine the rotor is turned down with no magnets and the rear portion of the crank is removed. He also uses a billet aluminum hub that is fluted if you prefer. He does use the coil, but his ignition looks to be less than 1 oz. My G62 converted it 4lbs4oz. (with ignition,plug,prop washer,cup mount, no muffler) He has a light version which is less than 4lbs.
How much does Roy's conversion weigh? and what does it cost?
I am about to run mine and will tach it with my new TNC
TIGITRIGHT 08-13-2006 12:36 AM
Giv'em a holler,His number is on his site,http://cncengines.com He would be glad to help with the specs.
