Club 20 pylonracing in Belgium
RE: Club 20 pylonracing in Belgium
Yeah... great fun, wasn't it?
And we got damned lucky with the weather too! You should see what it is like over here today, just one day later...
Kevin may disagree on the "great fun" part though... [X(] Losing two planes like that...
Paulus, did you get some good video, and are you going to put it up on your site?
MN
Great Pictures, looks like "most" everyone was having a good time. Those pictures look like they could have been taking at many of the fields I race at in the States.
I see I'm not the only one who likes Green Planes
Rudeboy,
I have a flight of Wim Lentjes on my computer. Looks pretty good. I'll have to compress it though. My flying buddy has quite a lot of video I think. Including one of the midairs of Kevin..[X(]
Daven,
That green plane does indeed look great. Thank god I didn't end up in the corn though..
HighPlains,
The most popular engine is the Irvine 20 ABC pylon. Other engines used are nova rossi's and OPS. No rear exhaust and a minimum venturi and outlet diameter. Speeds are around 130-140 Mph. Planes have a typical span of about 40-50 inch.
We yell OM!! (translates to TURN!!) or JA (YES) to the pilots...
Paul
Daven,
HighPlains,
Paul
Club 20 racing rules:
Engine: maximum 3.5 cubic centimetrs displacement, standard unmodified front intake - side exhaust, venturi diameter maximum 4.5 millimeters. The Irvines rule, but are no longer in production... they are getting pricey these days.
Prop: only a stock unmodified, commercially available, fixed pitch, reinforced nylon propeller is allowed. Most use an APC 7x6 or APC 7x6W is the engine can handle it.
Fuselage: minimal 70mm wide, 127mm high. These dimensions have to occur within the wing root chord, but do not have to be at the same place. The "cockpit" has to be minimum 32mm wide at a point 38mm below the highest point.
Wing: minimum area 0.194 square meters, min thickness measured directly besides the root fairing is 22mm, with a straight taper to a minimum of 16mm measure 50mm from the tip. Minimum wing span is 762mm.
Spinner: min 38mm diameter.
Weight: min 1134 grams less fuel.
Fuel: suplied by the race officials, 20% ricinus - 5% nitro
Exhaust: most use the Irvine magic muffler. Max exhaust diameter 6mm.
Fuel supply: you have to be able to stop the engine when the race officials ask you to do so. We use tanks without clunks, with a pickup at the bottom... negative "G" maneuvers are use to stop the engine.
Race Course: base pylons 36 meters apart, main pylon 150 meters from the base pylons (this is a shorter course than Qiuckie for instance).
